Start stop button ?
Dear Members,
How can I make a start/stop button with 1 button ?
Here's my handler :
    switch (event)
        case BSP_EVENT_SLEEP:
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
				 case BSP_EVENT_KEY_0:
					 NRF_LOG_INFO("BSP_EVENT_KEY 0 PUSH ON\n");
            if (actual_state != BSP_INDICATE_FIRST)
                actual_state--;
						    //NRF_LOG_INFO("BSP_EVENT_KEY 0 PUSH ON\n"); //2Mar22 Rixtronix LAB
                actual_state = BSP_INDICATE_LAST;
						    NRF_LOG_INFO("BSP_EVENT_KEY 0 PUSH OFF\n"); //2Mar22 Rixtronix LAB
Any clues ?
Rixtronix LAB
  • Hello Rixtronix,
    I see from your logging that it refers to 200 ms, while it sounds like you intend for long push to be 2000 ms. What is your configuration of BSP_LONG_PUSH_TIMEOUT_MS?
    Are you getting any other event in place of the long push event, or is the bsp module otherwise functioning as expected?
    For future reference, please use the Insert -> Code option when sharing code here on DevZone.
    Karl
  • Hi Karl,
    Thanks for the reply,
    #define BSP_LONG_PUSH_TIMEOUT_MS (1000) /**< The time to hold for a long push (in milliseconds). */
    Here's the complete event :
      ret_code_t err_code;
    	int32_t cnt;
        switch (event)
    					 /************START STOP BUTTON 3Mar22 Rixtronix LAB**************/
    									//NRF_LOG_INFO("BSP_EVENT_KEY 0 PUSH START\n");
    								   if(button0_state)
    												//START_function();
    											 NRF_LOG_INFO("BSP_EVENT_KEY 0 PUSH STOP\n");
    											  //beep_v9();
    											  app_timer_stop(m_repeated_timer_id);
    												button0_state = STATE_OFF;
    												//STOP_function();
    											  //NRF_LOG_INFO("BSP_EVENT_KEY 0 PUSH STOP\n");
    											  //beep_v10();
    											   app_timer_start(m_repeated_timer_id, APP_TIMER_TICKS(1000), NULL);  //3Mar22 Time of Ride Rixtronix LAB
    												button0_state = STATE_ON;
                    actual_state--;
            case BSP_EVENT_KEY_1:
                NRF_LOG_INFO("BSP_EVENT_KEY 1 PUSH STOP\n");
                if (actual_state != BSP_INDICATE_LAST)
                    actual_state++;
                    actual_state = BSP_INDICATE_FIRST;
    				 case BSP_EVENT_KEY_2:
    					 NRF_LOG_INFO("BSP_EVENT_KEY 2 PUSH ON\n");
    				   if(button2_state)
    																					cnt++;
    													 if ( cnt >= LONG_PRESS(10000))
    															 cnt = 0;
    															 NRF_LOG_INFO("Long Button press");
    												//ON_function();
    											  NRF_LOG_INFO("BSP_EVENT_KEY 2 PUSH ON==> LONG PUSH >200ms\n");
    											 //beep_v11();
    												button2_state = STATE_OFF;
    												//OFF_function();
    											   cnt = 0; // reset counter variable
    											  NRF_LOG_INFO("BSP_EVENT_KEY 2 PUSH OFF\n");
    											  //beep_v12();
    												button2_state = STATE_ON;
                    actual_state--;
            case BSP_EVENT_KEY_3:
                //NRF_LOG_INFO("BSP_EVENT_KEY 3 PUSH OFF\n");
    				     if(button3_state)
    												//ON_function();
    											  NRF_LOG_INFO("BSP_EVENT_KEY 3 PUSH ON==> LONG PUSH >200ms\n");
    											 //beep_v11();
    												button3_state = STATE_OFF;
    												//OFF_function();
    											  //beep_v12();
    												button3_state = STATE_ON;
                    actual_state++;
    I can't get 2000 mS long push, is the timer running ?
    Is it conflicting with BSP ant button ?
    static void utils_setup(void)
        //ret_code_t err_code;
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS,
                            bsp_event_handler);
        err_code = bsp_btn_ant_init(m_ant_hrm.channel_number, HRM_DISP_CHANNEL_TYPE);
        //err_code = ant_state_indicator_init(m_ant_hrm.channel_number, HRM_DISP_CHANNEL_TYPE);
    	  err_code = bsp_btn_ant_init(m_ant_bsc.channel_number, BSC_DISP_CHANNEL_TYPE);
    		err_code = bsp_btn_ant_init(m_ant_bpwr.channel_number, BPWR_DISP_CHANNEL_TYPE);
    	  //err_code = ant_state_indicator_init(m_ant_bsc.channel_number, BSC_DISP_CHANNEL_TYPE);
    		NRF_LOG_INFO("utils_setup\r\n");
    Rixtronix
  • Read button function :
    void read_button()
    	  err_code = bsp_event_to_button_action_assign(BSP_BUTTON_0,
        BSP_BUTTON_ACTION_PUSH,
        BSP_EVENT_KEY_0);
     	  err_code = bsp_event_to_button_action_assign(BSP_BUTTON_1,
        BSP_EVENT_KEY_1);//hardware not connected
      /************originally***********
    	 err_code = bsp_event_to_button_action_assign(BSP_BUTTON_2,
        BSP_EVENT_KEY_2);
        BSP_BUTTON_ACTION_LONG_PUSH,
        BSP_EVENT_KEY_2);
    	/*************originally button 4
    	err_code = bsp_event_to_button_action_assign(BSP_BUTTON_3,
        BSP_EVENT_KEY_3);
      *************Rixtronix LAB 17 Mar 22*/
        BSP_EVENT_KEY_3);
  • Hi Karl,
    Looks like it's not responding to :
    					 //NRF_LOG_INFO("BSP_EVENT_KEY 2 PUSH ON\n");
    				   if(button2_state)
    																					cnt++;
    															 cnt = 0;
    												//ON_function();
    											 //beep_v11();
    												//OFF_function();
    											  //beep_v12();
    How can I relate this code to timer as I can see in :
    https://devzone.nordicsemi.com/f/nordic-q-a/43506/how-to-use-bsp_button_action_push-and-bsp_button_action_long_push-on-the-same-button-with-two-different-functions
    or
    https://devzone.nordicsemi.com/f/nordic-q-a/37842/how-to-use-bsp_event_to_button_action_assign-function-to-assign-long-push-action-to-an-event
    Rixtronix
  • Hi Karl,
    I made ,
    Callback :
    				   //if(button2_state)
    												//ON_function();
    											   err_code = app_timer_start(m_button_action,
                                         APP_TIMER_TICKS(BUTTON_STATE_POLL_INTERVAL_MS),
                                         NULL);
    											 // NRF_LOG_INFO("BSP_EVENT_KEY 2 PUSH ON==> LONG PUSH >200ms\n");
    											 //beep_v11();
                    actual_state--;
                    //timeout handler
    void button_push_timeout_handler(void * p_context)
         uint32_t err_code;
         static uint32_t cnt;
         if (BUTTON_3==0)
             cnt++;
             if ( cnt >= LONG_PRESS(1000))
                 cnt = 0;
                                             NULL);
              NRF_LOG_INFO("Short button press");
    err_code = app_timer_create(&m_button_action, APP_TIMER_MODE_SINGLE_SHOT, button_push_timeout_handler);
    	      NRF_LOG_INFO("&m_button_action init Line2119...");
    Timer init :
    //long press button timer 16Mar22 Rixtronix LAB
    APP_TIMER_DEF(m_button_action);
    #define BUTTON_STATE_POLL_INTERVAL_MS  100UL
    #define LONG_PRESS(MS)    (uint32_t)(MS)/BUTTON_STATE_POLL_INTERVAL_MS
    I got always in :
    although I push long enough...
    What do we miss here ?
    Rixtronix
