Start stop button ?
Dear Members,
How can I make a start/stop button with 1 button ?
Here's my handler :
    switch (event)
        case BSP_EVENT_SLEEP:
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
				 case BSP_EVENT_KEY_0:
					 NRF_LOG_INFO("BSP_EVENT_KEY 0 PUSH ON\n");
            if (actual_state != BSP_INDICATE_FIRST)
                actual_state--;
						    //NRF_LOG_INFO("BSP_EVENT_KEY 0 PUSH ON\n"); //2Mar22 Rixtronix LAB
                actual_state = BSP_INDICATE_LAST;
						    NRF_LOG_INFO("BSP_EVENT_KEY 0 PUSH OFF\n"); //2Mar22 Rixtronix LAB
Any clues ?
Rixtronix LAB
  • Hi Karl,
    I pushed BSP_BUTTON_2, but on timeout handler I got :
    the log :
    nfo> app: BSP_BUTTON_0
    nfo> app: BSP_BUTTON_1
    nfo> app: BSP_BUTTON_2
    nfo> app: BSP_BUTTON_3
    Any ideas?
    Rixtronix LAB
    Rixtronix LAB
  • Hi Karl,
    Why isn't responding to
    bsp_button_event_handler on bsp.c, but only responding to bsp_event_handler in main.c ?
    Rixtronix
  • Hello again, Rixtronix
    Thank you for your patience with this.
    the log :
    This looks for me like a possible fallthrough in a switch case handling, could this be the case?
    I do not see any break statements at the end of the BSP_EVENT_KEY_2 case you have shared, at least.
    I notice that you are not checking the returned error code from you calls to bsp_event_to_button_action_assign, please make sure to do so to see if they are succeeding.
    I also notice that you are using the ant bsp init, bsp_btn_ant_init, could you elaborate on why you are using this, and what your intentions are for calling it multiple times in a row?
    The bsp init function should only have to be called once.
    Karl
  • Hi Karl,
    Thanks for the reply,
    Like this ?
    *********Button input 1Mar22 Rixtronix LAB********/
    void read_button()
    	ret_code_t err_code;
    	  err_code = bsp_event_to_button_action_assign(BSP_BUTTON_0,
        BSP_BUTTON_ACTION_PUSH,
        BSP_EVENT_KEY_0);
     	  err_code = bsp_event_to_button_action_assign(BSP_BUTTON_1,
        BSP_EVENT_KEY_1);//hardware not connected
      /************originally***********/
    	 err_code = bsp_event_to_button_action_assign(BSP_BUTTON_2,
        BSP_EVENT_KEY_2);
        BSP_BUTTON_ACTION_LONG_PUSH,
        BSP_EVENT_KEY_2);
    	/*************originally button 4*/
    	err_code = bsp_event_to_button_action_assign(BSP_BUTTON_3,
        BSP_EVENT_KEY_3);
      /*************Rixtronix LAB 17 Mar 22
        BSP_EVENT_KEY_3);
    So I need to use only
     bsp_init
    and don't have to use bsp_btn_ant_init, I took it from ANT example ?
    Rixtronix
  • Hi Karl,
        BSP_EVENT_KEY_2);
    	 //APP_ERROR_CHECK(err_code);
    	 NRF_LOG_INFO("Error code %u",err_code);
    I got "error code 7"
    what does it mean ?
    Rixtronix
