pin sinking current at poweroff
Dear Nordic,
we developed firmware based on S112 and SDK 17.1.0. We have a problem with poweroff routine: at poweroff the status LED is ON.
this is part of our circuit, its very simple:
and the code is short too:
#define		PIN_LED_R								22										// PIN		04 (P0.22)
#define		PIN_LED_G								23										// PIN		03 (P0.23)
#define		PIN_LED_B								24										// PIN		02 (P0.24)
#define		LED_PWM_INSTANCE						0										// value		PWM instance index.
#define		LED_PWM_IRQ_PRIORITY					APP_IRQ_PRIORITY_LOWEST			// value		Interrupt priority.
#define		LED_PWM_DUTY_MAX						1000									// value		max PWM duty value (800 = 625 Hz; 1000 = 500 Hz)
#define		LED_PWM_DUTY_FACTOR					255									// value		duty factor for % duty conversion
/* INIT di controllo del LED */
void vInit_StatLED( void ) {
	ret_code_t err_code;
	static const nrfx_pwm_config_t pwm_config = {
		.output_pins = {													// Pin numbers for individual output channels
			PIN_LED_R,
			PIN_LED_G,
			PIN_LED_B,
			NRFX_PWM_PIN_NOT_USED										// Use NRFX_PWM_PIN_NOT_USED if a given output channel is not needed.
		.irq_priority	= LED_PWM_IRQ_PRIORITY,						// Interrupt priority.
		.base_clock		= NRF_PWM_CLK_500kHz,						// Base clock frequency.
		.count_mode		= NRF_PWM_MODE_UP,							// Operating mode of the pulse generator c
		.top_value		= LED_PWM_DUTY_MAX,							// Value up to which the pulse generator c
		.load_mode		= NRF_PWM_LOAD_INDIVIDUAL,					// Mode of loading sequence data from RAM: 1st half word (16-bit) used in channel 0; 2nd in channel 1; 3rd in channel 2; 4th in channel 3.
		.step_mode		= NRF_PWM_STEP_AUTO							// Mode of advancing the active sequence.
	err_code = nrfx_pwm_init( &m_pwm_instance, &pwm_config, NULL );
	APP_ERROR_CHECK( err_code );
	seq_value.channel_0 = 0;											// Duty cycle value for channel 0.
	seq_value.channel_1 = 0;											// Duty cycle value for channel 1.
	seq_value.channel_2 = 0;											// Duty cycle value for channel 2.
	seq_value.channel_3 = 0;											// Duty cycle value for channel 3.
	// init dei PIN, stato GPIO
	nrf_gpio_pin_write( PIN_LED_R, true );
	nrf_gpio_pin_write( PIN_LED_G, true );
	nrf_gpio_pin_write( PIN_LED_B, true );
	return;
/* UNinit di controllo del LED */
void vUNinit_StatLED( void ) {
	// deInit PWM
	nrfx_pwm_uninit( &m_pwm_instance );
	// deInit GPIO
	nrf_gpio_cfg_default( PIN_LED_R );
	nrf_gpio_cfg_default( PIN_LED_G );
	nrf_gpio_cfg_default( PIN_LED_B );
	return;
/* power off the system */
void vUtil_System_PowerOFF( void ) {
	ret_code_t err_code = NRF_SUCCESS;
	vUNinit_StatLED();
	NRF_LOG_RAW_INFO( "%6ums\t%s(): powering off the system\n", xTaskGetTickCount(), __func__ );
	err_code = sd_power_system_off();								// Go to system-off mode (this function will not return; wakeup will cause a reset).
	while( 1 );
/**					MAIN Program														**/
int main( void ) {
	vInit_StatLED();
	// Initialize clock
	err_code = nrf_drv_clock_init();
	SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;								// Activate deep sleep mode.
	err_code = nrf_sdh_enable_request();							// Initialize the SoftDevice and the stack event interrupt.
	ASSERT( nrf_sdh_is_enabled() );									// sanity check for SoftDevice Initialized
	while( 1 ) {
		   do some stuff
		vUtil_System_PowerOFF();
The issue is that when I call the vUtil_System_PowerOFF() function, the CPU turns off but the LED is turned ON at full bright.
Please could you help me?
Thanks!
