Problem using nRF Connect SDK devicetree GPIO definitions in code
I am just starting out creating a project to run on an nRF9160 on custom hardware. I have set up a development environment (v1.9.0) through nRF Connect for Desktop app. I have created a custom board configuration based on the thingy91_nrf9160 board files, and successfully built an example project (cloud_client) for this board configuration.
Now I want to add some GPIO of my own to setup connections to the rest of my system, but since I am new to device trees I am not sure that I am doing things correctly.
Starting out with a testpad on the pcb, I added a GPIO pin to the dts file as follows:
    /* model and compatible parameter defined here...  */
	tp: testpin {
		gpios = <&gpio0 22 0>;
	/* reserved memory defined here... */
/* some peripherals defined here... */
&gpio0 {
	status = "okay";
/* some more peripherals defined here... */
And I try to use the pin through a sourcefile that I have added to the src folder, using the nrf52840_reset.c code as an example:
#include <drivers/gpio.h>
#include <device.h>
#include <devicetree.h>
#define TP_NODE         DT_NODELABEL(tp)
#define TP_GPIO_CTRL    DT_GPIO_CTLR(TP_NODE, gpios)
#define TP_GPIO_PIN     DT_GPIO_PIN(TP_NODE, gpios)
#define TP_GPIO_FLAGS   DT_GPIO_FLAGS(TP_NODE, gpios)
static struct device *port = NULL;
void TestpinInit(void)
    port = DEVICE_DT_GET(TP_GPIO_CTRL);
    gpio_pin_configure(port, TP_GPIO_PIN, TP_GPIO_FLAGS | GPIO_OUTPUT_INACTIVE);
void TestpinToggle(void)
    if (NULL != port)
        gpio_pin_toggle(port, TP_GPIO_PIN);
Unfortunately this code creates quite some build errors; all similar. For example:
In file included from C:\_tools\v1.9.0\zephyr\include\toolchain\gcc.h:72,
                 from C:\_tools\v1.9.0\zephyr\include\toolchain.h:50,
                 from C:\_tools\v1.9.0\zephyr\include\sys\printk.h:11,
                 from C:\_tools\v1.9.0\zephyr\include\sys\__assert.h:11,
                 from C:\_tools\v1.9.0\zephyr\include\drivers\gpio.h:18,
                 from c:\_repo\project\nrf9160\cloud_client\src\testpin.c:32:
../src/testpin.c: In function 'TestpinInit':
C:\_tools\v1.9.0\zephyr\include\device.h:96:39: error: '__device_dts_ord_DT_N_S_testpin_P_gpios_IDX_0_PH_ORD' undeclared (first use in this function)
   96 | #define DEVICE_NAME_GET(name) _CONCAT(__device_, name)
C:\_tools\v1.9.0\zephyr\include\toolchain\common.h:132:26: note: in definition of macro '_DO_CONCAT'
  132 | #define _DO_CONCAT(x, y) x ## y
C:\_tools\v1.9.0\zephyr\include\device.h:96:31: note: in expansion of macro '_CONCAT'
C:\_tools\v1.9.0\zephyr\include\device.h:291:37: note: in expansion of macro 'DEVICE_NAME_GET'
  291 | #define DEVICE_DT_NAME_GET(node_id) DEVICE_NAME_GET(Z_DEVICE_DT_DEV_NAME(node_id))
C:\_tools\v1.9.0\zephyr\include\device.h:311:34: note: in expansion of macro 'DEVICE_DT_NAME_GET'
  311 | #define DEVICE_DT_GET(node_id) (&DEVICE_DT_NAME_GET(node_id))
c:\_repo\project\nrf9160\cloud_client\src\testpin.c:72:12: note: in expansion of macro 'DEVICE_DT_GET'
   72 |     port = DEVICE_DT_GET(TP_GPIO_CTRL);
C:\_tools\v1.9.0\zephyr\include\device.h:96:39: note: each undeclared identifier is reported only once for each function it appears in
I am not sure how to interpret these errors. To me it appears that the compiler creates a node name through the macros used, and it does not match the node name given in the dts file. I am having trouble getting out of this what name the compiler actually expects; where exactly have I made my error and what should I do to fix it.
Can anyone here point me in the right direction?
    Looks like the DTS configuration you have attached is missing the whole configuration, and you have only part of the configuration. E.g. look at nrf\boards\arm\thingy91_nrf9160\thingy91_nrf9160_common.dts
    From here you can see how they have configured the button connected to the nRF9160:
    buttons {
    	compatible = "gpio-keys";
    	button0: button_0 {
    		gpios = <&gpio0 26 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
    		label = "Button 1";
    &gpio0 {
    	status = "okay";
    Edit: You should also have a look at the basic button sample in Zephyr (zephyr\samples\basic\button\src\main.c)
    Øyvind
  • Hi Øyvind,
    Thank you for your answer. I have seen the button examples, but the trouble is I am not trying to implement a button here. I am implementing a GPIO pin.
    Looking at the Zephyr device tree documentation they make it seem like you can just create a node (which I named tp) and include a "gpios" parameter to it to define a gpio. All of the examples look like this, roughly..
    gpio1: gpio@... { };
    gpio2: gpio@... { };
    n: node {
            gpios = <&gpio1 10 GPIO_ACTIVE_LOW>,
                    <&gpio2 30 GPIO_ACTIVE_HIGH>;
    Looking at the nRF Connect view in Visual Studio Code under the devicetree tab the pin is also recognised as a GPIO node with the name tp, so sómething is happening..
    I have tried adding my own source file to the dts configuration, but that made no difference.
    testpins {
    	compatible = "testpin";
    	tp: tspn {
    		label = "TP42";
    How do I configure just a regular old GPIO in the devicetree (not tied button or led drivers) to use in my own code?
  • For future visitors, I have figured out what I was missing.
    I was unaware that the device tree file is only half of the story and that the system also needs a binding to link the dts configuration to a template which specifies the possible fields of a dts node. This binding is what you put in the "compatible" field.
    In my case I defined a file in my board folder under dts/bindings/eac,testpin.yaml, which contains:
    description: GPIO used as testpin
    compatible: "eac,testpin"
    include: base.yaml
    properties:
      status:
        required: true
      gpios:
        type: phandle-array
        required: true
        description: |
          GPIO to use as testpin.
    And added to my dts node:
    tp: testpin {
    	compatible = "eac,testpin";
    	status = "okay";
