GCC problem finding gcc_startup_nrf52.s
I've done a fair amount with the NRF51822 and Keil on Windows but decided it was time to switch to my native Mac instead of the VM!
Reading all the guides around the place and just stuck a little bit.
I've got all the cross compiling tools installed and paths setup (and I've modified the makefile.common)
I'm trying to compile the simple Blinky example for the new nRF52832 (yay!)
It seems to have trouble finding the gcc_startup_nrf52.s even tho the include paths are all there. I modified the make file to be quite verbose and I even 'ls' the file from the same folder..
Any help appreciated!
make
rm -rf _build
echo  Makefile
Makefile
mkdir _build
Compiling file: system_nrf52.c
arm-none-eabi-gcc -DCONFIG_GPIO_AS_PINRESET -DBOARD_PCA10036 -DNRF52 -DBSP_DEFINES_ONLY -mcpu=cortex-m4 -mthumb -mabi=aapcs --std=gnu99 -Wall -Werror -O3 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -ffunction-sections -fdata-sections -fno-strict-aliasing -fno-builtin --short-enums -I../../../../../../components/toolchain/gcc -I../../../../../../components/toolchain -I../../.. -I../../../../../bsp -I../../../../../../components/device -I../../../../../../components/drivers_nrf/delay -I../../../../../../components/drivers_nrf/hal -c -o _build/system_nrf52.o ../../../../../../components/toolchain/system_nrf52.c
Compiling file: main.c
arm-none-eabi-gcc -DCONFIG_GPIO_AS_PINRESET -DBOARD_PCA10036 -DNRF52 -DBSP_DEFINES_ONLY -mcpu=cortex-m4 -mthumb -mabi=aapcs --std=gnu99 -Wall -Werror -O3 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -ffunction-sections -fdata-sections -fno-strict-aliasing -fno-builtin --short-enums -I../../../../../../components/toolchain/gcc -I../../../../../../components/toolchain -I../../.. -I../../../../../bsp -I../../../../../../components/device -I../../../../../../components/drivers_nrf/delay -I../../../../../../components/drivers_nrf/hal -c -o _build/main.o ../../../main.c
Compiling file: nrf_delay.c
arm-none-eabi-gcc -DCONFIG_GPIO_AS_PINRESET -DBOARD_PCA10036 -DNRF52 -DBSP_DEFINES_ONLY -mcpu=cortex-m4 -mthumb -mabi=aapcs --std=gnu99 -Wall -Werror -O3 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -ffunction-sections -fdata-sections -fno-strict-aliasing -fno-builtin --short-enums -I../../../../../../components/toolchain/gcc -I../../../../../../components/toolchain -I../../.. -I../../../../../bsp -I../../../../../../components/device -I../../../../../../components/drivers_nrf/delay -I../../../../../../components/drivers_nrf/hal -c -o _build/nrf_delay.o ../../../../../../components/drivers_nrf/delay/nrf_delay.c
Compiling file: gcc_startup_nrf52.s
make: /Applications/gcc-arm-none-eabi-4_9/bin/bin/arm-none-eabi-gcc: No such file or directory
make: *** [_build/gcc_startup_nrf52.o] Error 1
Lets take a peek if its there (using the include path that the Makefile is using) and it is!
Chriss-MacBook-Pro:armgcc christopher$ ls ../../../../../../components/toolchain/gcc/
Makefile.common		arm_common_tables.h	core_cm0.h		core_cmInstr.h		gcc_startup_nrf51.s	nrf51_xxaa.ld		nrf52_common.ld
Makefile.posix		arm_const_structs.h	core_cm4.h		core_cmSimd.h		gcc_startup_nrf52.s	nrf51_xxab.ld		nrf52_xxaa.ld
Makefile.windows	arm_math.h		core_cmFunc.h		gcc_nrf51_common.ld	nrf51_common.ld		nrf51_xxac.ld		nrf5x_common.ld
Chriss-MacBook-Pro:armgcc christopher$ ls ../../../../../../components/toolchain/gcc/gcc_startup_nrf52.s
Here's it with the 'make -n' command as requested
make -n
rm -rf _build
echo Compiling file: system_nrf52.c
echo arm-none-eabi-gcc -DCONFIG_GPIO_AS_PINRESET -DBOARD_PCA10036 -DNRF52 -DBSP_DEFINES_ONLY -mcpu=cortex-m4 -mthumb -mabi=aapcs --std=gnu99 -Wall -Werror -O3 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -ffunction-sections -fdata-sections -fno-strict-aliasing -fno-builtin --short-enums -I../../../../../../components/toolchain/gcc -I../../../../../../components/toolchain -I../../.. -I../../../../../bsp -I../../../../../../components/device -I../../../../../../components/drivers_nrf/delay -I../../../../../../components/drivers_nrf/hal -c -o _build/system_nrf52.o ../../../../../../components/toolchain/system_nrf52.c
echo Compiling file: main.c
echo arm-none-eabi-gcc -DCONFIG_GPIO_AS_PINRESET -DBOARD_PCA10036 -DNRF52 -DBSP_DEFINES_ONLY -mcpu=cortex-m4 -mthumb -mabi=aapcs --std=gnu99 -Wall -Werror -O3 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -ffunction-sections -fdata-sections -fno-strict-aliasing -fno-builtin --short-enums -I../../../../../../components/toolchain/gcc -I../../../../../../components/toolchain -I../../.. -I../../../../../bsp -I../../../../../../components/device -I../../../../../../components/drivers_nrf/delay -I../../../../../../components/drivers_nrf/hal -c -o _build/main.o ../../../main.c
echo Compiling file: nrf_delay.c
echo arm-none-eabi-gcc -DCONFIG_GPIO_AS_PINRESET -DBOARD_PCA10036 -DNRF52 -DBSP_DEFINES_ONLY -mcpu=cortex-m4 -mthumb -mabi=aapcs --std=gnu99 -Wall -Werror -O3 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -ffunction-sections -fdata-sections -fno-strict-aliasing -fno-builtin --short-enums -I../../../../../../components/toolchain/gcc -I../../../../../../components/toolchain -I../../.. -I../../../../../bsp -I../../../../../../components/device -I../../../../../../components/drivers_nrf/delay -I../../../../../../components/drivers_nrf/hal -c -o _build/nrf_delay.o ../../../../../../components/drivers_nrf/delay/nrf_delay.c
echo Compiling file: gcc_startup_nrf52.s
'/Applications/gcc-arm-none-eabi-4_9/bin/bin/arm-none-eabi-gcc' -x assembler-with-cpp -DCONFIG_GPIO_AS_PINRESET -DBOARD_PCA10036 -DNRF52 -DBSP_DEFINES_ONLY -I../../../../../../components/toolchain/gcc -I../../../../../../components/toolchain -I../../.. -I../../../../../bsp -I../../../../../../components/device -I../../../../../../components/drivers_nrf/delay -I../../../../../../components/drivers_nrf/hal -c -o _build/gcc_startup_nrf52.o ../../../../../../components/toolchain/gcc/gcc_startup_nrf52.s
echo Linking target: nrf52832_xxaa.out
'/Applications/gcc-arm-none-eabi-4_9/bin/bin/arm-none-eabi-gcc' -Xlinker -Map=_build/nrf52832_xxaa.map -mthumb -mabi=aapcs -L ../../../../../../components/toolchain/gcc -Tblinky_gcc_nrf52.ld -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -Wl,--gc-sections --specs=nano.specs -lc -lnosys _build/system_nrf52.o _build/main.o _build/nrf_delay.o _build/gcc_startup_nrf52.o  -o _build/nrf52832_xxaa.out
/Applications/Xcode.app/Contents/Developer/usr/bin/make -f  Makefile -C ./  -e finalize
echo Preparing: nrf52832_xxaa.bin
'/Applications/gcc-arm-none-eabi-4_9/bin/bin/arm-none-eabi-objcopy' -O binary _build/nrf52832_xxaa.out _build/nrf52832_xxaa.bin
echo Preparing: nrf52832_xxaa.hex
'/Applications/gcc-arm-none-eabi-4_9/bin/bin/arm-none-eabi-objcopy' -O ihex _build/nrf52832_xxaa.out _build/nrf52832_xxaa.hex
echo ''
'/Applications/gcc-arm-none-eabi-4_9/bin/bin/arm-none-eabi-size' _build/nrf52832_xxaa.out
echo ''
