Timer handler function is not called
 Hi, devzone!
 I'm trying to use a timer to periodically change the digital output but it seems that the handler function is not called.
 The whole code is based on the ble_peripheral/ble_app_uart and I added all the other functions and timer into that example. Following is the part related to a timer.
const nrf_drv_timer_t TIMER_ADC = NRF_DRV_TIMER_INSTANCE(2);
const nrf_drv_timer_t TIMER_INJECTOR = NRF_DRV_TIMER_INSTANCE(1);
void timer_handler(nrf_timer_event_t event_type, void * p_context)
    return;
void timer_handler_injector(nrf_timer_event_t event_type, void * p_context)
    nrf_gpio_pin_toggle(pin_injector_0);
    nrf_gpio_pin_toggle(pin_injector_1);
    nrf_gpio_pin_toggle(pin_injector_2);
    ret_code_t err_code;
    //timer_cfg.bit_width = NRF_TIMER_BIT_WIDTH_16;
    timer_cfg.frequency = NRF_TIMER_FREQ_16MHz;
    err_code = nrf_drv_timer_init(&TIMER_ADC, &timer_cfg, timer_handler);
    /* setup m_timer for compare event every us */
    uint32_t ticks = nrf_drv_timer_us_to_ticks(&TIMER_ADC, 50);
    nrf_drv_timer_extended_compare(&TIMER_ADC,
                                   NRF_TIMER_CC_CHANNEL0,
                                   ticks,
                                   NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                   false);
    nrf_drv_timer_enable(&TIMER_ADC);
    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&TIMER_ADC,
        NRF_TIMER_CC_CHANNEL0);
                                          timer_compare_event_addr,
                                          saadc_sample_task_addr);
void run_injector(void)
    err_code = nrf_drv_timer_init(&TIMER_INJECTOR, &timer_cfg, timer_handler_injector);
    uint32_t ticks = nrf_drv_timer_ms_to_ticks(&TIMER_INJECTOR, 1000);
    nrf_drv_timer_extended_compare(&TIMER_INJECTOR,
                                   NRF_TIMER_CC_CHANNEL1,
                                   ticks,
                                   NRF_TIMER_SHORT_COMPARE1_CLEAR_MASK,
                                   false);
    nrf_drv_timer_enable(&TIMER_INJECTOR);
 The TIMER_ADC is attached to the ppi and SAADC works without any problem, maybe because it does not use the handler. However, I need TIMER_INJECTOR to work with a handler.
 When I manually checked nrf_gpio_pin_toggle() instead of putting it in the handler, it worked well so the GPIO pin assignment is not the problem.
 I made a breakpoint in the handler function and found that it never called.
 While searching similar cases in the forum, I found may the app_timer prohibits timer handler but even though I changed TIMER_INJECTOR as app_timer it still did not work.
 I need some help...
