NRF5340 Internal Flash partition problems
    The DFU(reuse ota code) partition configuration file I got from your technical support is as follows,It divides Flash(1024K) into the following regions:mcuboot(48K)、mcuboot_primary(480K)、
mcuboot_secondary(480K)、EMPTY_0(8K)、settings_storage(8K)
EMPTY_0:
  address: 0xfc000
  end_address: 0xfe000
  placement:
    after:
    - mcuboot_secondary
  region: flash_primary
app:
  address: 0xc200
  end_address: 0x84000
mcuboot:
  address: 0x0
  end_address: 0xc000
  placement:
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0xc000
  end_address: 0xc200
  placement:
    align:
      start: 0x4000
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0xc000
  orig_span: &id001
  - app
  - mcuboot_pad
  sharers: 0x1
  span: *id001
mcuboot_primary_app:
  address: 0xc200
  orig_span: &id002
  - app
  span: *id002
mcuboot_secondary:
  address: 0x84000
  end_address: 0xfc000
  placement:
    after:
    - mcuboot_primary
    align:
      start: 0x4000
  share_size:
  - mcuboot_primary
otp:
  address: 0xff8100
  end_address: 0xff83fc
  region: otp
pcd_sram:
  address: 0x2006e000
  end_address: 0x20070000
  placement:
    before:
    - rpmsg_nrf53_sram
    - end
  region: sram_primary
rpmsg_nrf53_sram:
  address: 0x20070000
  end_address: 0x20080000
  placement:
    before:
    - end
settings_storage:
  address: 0xfe000
  end_address: 0x100000
  placement:
    before:
    - end
sram_primary:
  address: 0x20000000
  end_address: 0x2006e000
QS1:  I need about 64K space to store user configuration data, which cannot be erased after DFU,Please show me how to set up this partition?
QS2:  At first, I wanted to use partition "settings_storage" to store user data, but the technical support feedback said that this partition was dedicated to DFU. What are the detailed steps of our official standard DFU
  • $ ninja partition_manager_report
    [0/9] Performing build step for 'mcuboot_subimage'
    ninja: no work to do.
    [1/6] Performing build step for 'rpmsg_service_remote_subimage'
    [0/5] Performing build step for 'b0n_subimage'
    flash_primary (0x100000 - 1024kB):
    | 0x0: mcuboot (0xc000 - 48kB)                    |
    +---0xc000: mcuboot_primary (0x78000 - 480kB)-----+
    | 0xc000: mcuboot_pad (0x200 - 512B)              |
    +---0xc200: mcuboot_primary_app (0x77e00 - 479kB)-+
    | 0xc200: app (0x77e00 - 479kB)                   |
    | 0x84000: mcuboot_secondary (0x78000 - 480kB)    |
    | 0xfc000: EMPTY_0 (0x2000 - 8kB)                 |
    | 0xfe000: settings_storage (0x2000 - 8kB)        |
      otp (0x2fc - 764B):
    | 0xff8100: otp (0x2fc - 764B) |
      sram_primary (0x80000 - 512kB):
    | 0x20000000: sram_primary (0x6e000 - 440kB)    |
    | 0x2006e000: pcd_sram (0x2000 - 8kB)           |
    | 0x20070000: rpmsg_nrf53_sram (0x10000 - 64kB) |
     CPUNET flash_primary (0x40000 - 256kB):
    +---0x1000000: b0n_container (0x8800 - 34kB)--------+
    | 0x1000000: b0n (0x8600 - 33kB)                    |
    | 0x1008600: provision (0x200 - 512B)               |
    +---0x1008800: app (0x37800 - 222kB)----------------+
    | 0x1008800: rpmsg_service_remote (0x37800 - 222kB) |
     CPUNET sram_primary (0x10000 - 64kB):
    | 0x21000000: sram_primary (0x10000 - 64kB) |
    The current partition info
  • Hi Wang,
    I don't think the "settings_storage" is only dedicated for DFU, it's used for many other purposes, including storing user data.
    Could you please point me to where you get the information of " Technical support feedback said that this partition was dedicated to DFU "  ?
  • I got this message through telephone communication with FAE of Hong Kong HONESTAR TECHNOLOGY.   If not, could you please tell me how DFU uses these partitions? I want to know the detailed process.
    Back to the previous two questions,Where should I put the 64K partition?
  • Hi Wang,
    I don't think the information is correct. The settings_storage is independent from MCUBoot.
    As far as I know, MCUBoot stores the DFU progress in the metadata in the image header, not in the settings_storage.
    How do you plan to store your data ? If you are planning to use the settings module, then you can just increase the setting_storage size to the size of your need by defining: CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE
    By default CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x2000.
