SAADC , BLE
 * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * Peripheral: SAADC
 * Compatibility: nRF52832 rev 2/nRF52840 rev 1, SDK 15.2.0
 * Softdevice used: S132 v6.1.0/S140 v6.1.0
 * This SAADC example samples on 4 different input pins, and enables scan mode to do that. It is otherwise an
 * offsprint from the standard ble_app_uart example available in nRF5 SDK 15.2.0
 * Works together with softdevice S132 v6.1.0 on nRF52832 and S140 v6.1.0 on nRF52840
 * Transmits SAADC output to hardware UART and over BLE via Nordic UART Servive (NUS).
 * Info on NUS -> http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v13.0.0/ble_sdk_app_nus_eval.html?cp=4_0_0_4_1_2_17
 * Info on hardware UART settings -> http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v13.0.0/uart_example.html?cp=4_0_0_4_4_41
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME                     "G"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                        /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
#define SAADC_SAMPLES_IN_BUFFER         20                   /* 50 ms de bir 100 sample = 2khz ,  100us-8000 sample*/
#define SAADC_SAMPLE_RATE               300                   //550 ye 10 sample putty  /**< SAADC sample rate in us. */
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
volatile uint8_t state = 1;
static const nrf_drv_timer_t   m_timer = NRF_DRV_TIMER_INSTANCE(3);
static nrf_saadc_value_t       m_buffer_pool[2][SAADC_SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t       m_ppi_channel;
static uint32_t                m_adc_evt_counter;
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            // Pairing not supported
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= m_ble_nus_max_data_len))
                if (index > 1)
                    do
                    } while (err_code == NRF_ERROR_RESOURCES);
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
    UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
    nrf_pwr_mgmt_run();
void timer_handler(nrf_timer_event_t event_type, void* p_context)
    nrf_drv_timer_config_t timer_config = NRF_DRV_TIMER_DEFAULT_CONFIG;
    timer_config.frequency = NRF_TIMER_FREQ_31250Hz;
    err_code = nrf_drv_timer_init(&m_timer, &timer_config, timer_handler);
    /* setup m_timer for compare event */
    uint32_t ticks = nrf_drv_timer_us_to_ticks(&m_timer,SAADC_SAMPLE_RATE);    //ms yi değiştirdim
    nrf_drv_timer_extended_compare(&m_timer, NRF_TIMER_CC_CHANNEL0, ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer, NRF_TIMER_CC_CHANNEL0);
    uint32_t saadc_sample_event_addr = nrf_drv_saadc_sample_task_get();
    err_code = nrf_drv_ppi_channel_assign(m_ppi_channel, timer_compare_event_addr, saadc_sample_event_addr);
        uint16_t adc_value;
        uint8_t value[SAADC_SAMPLES_IN_BUFFER*2];    // *2 , *4le değiştirdim
        uint16_t bytes_to_send;                      //   uint16_t bytes_to_send;
        // uint16_t val;
        float val;
        // set buffers
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAADC_SAMPLES_IN_BUFFER);
        // print samples on hardware UART and parse data for BLE transmission
        //printf("ADC event number: %d\r\n",(int)m_adc_evt_counter); //Bunu uncomment
        //printf("\rADC\r\n");
        //printf("ADC sample number: %d\r\n",(int)SAADC_SAMPLES_IN_BUFFER); //Bunu uncomment
        for (int i = 0; i < SAADC_SAMPLES_IN_BUFFER; i++)
            //printf("%d\r\n", p_event->data.done.p_buffer[i]); //Bunu uncomment
            adc_value = p_event->data.done.p_buffer[i];
            //adc_val = p_event->data.done.p_buffer[i];
            // Perform some calculations to convert this value back to the voltage
            //val = (adc_value * 2.8 / 4096 );
            //printf("\r%.2f\r\n" , val); //Bunu uncomment
            printf("%d\r\n" , adc_value);
            //NRF_LOG_INFO("Voltage Read: " NRF_LOG_FLOAT_MARKER "\r\n", NRF_LOG_FLOAT(val));
            value[i*2] = adc_value;
            value[(i*2)+1] = adc_value >> 8;
         // Send data over BLE via NUS service. Create string from samples and send string with correct length.
        //uint8_t nus_string[50];
        uint8_t nus_string[300];
           bytes_to_send = sprintf(nus_string, "%d\r\n" ,  p_event->data.done.p_buffer[i]);
        //bytes_to_send = sprintf(nus_string, "%d\r\n%d\r\n%d\r\n%d\r\n" ,
        //                                                  p_event->data.done.p_buffer[0], p_event->data.done.p_buffer[1],
        //                                                  p_event->data.done.p_buffer[2], p_event->data.done.p_buffer[3]);
                                                          //p_event->data.done.p_buffer[4], p_event->data.done.p_buffer[5],
                                                          //p_event->data.done.p_buffer[6], p_event->data.done.p_buffer[7],
                                                          //p_event->data.done.p_buffer[8], p_event->data.done.p_buffer[9],
                                                          //p_event->data.done.p_buffer[10]);
        //(nus_string, "CH0: %d\r\nCH1: %d\r\nCH2: %d\r\nCH3: %d", p_event->data.done.p_buffer[0], p_event->data.done.p_buffer[1],  p_event->data.done.p_buffer[2], p_event->data.done.p_buffer[3]);
        err_code = ble_nus_data_send(&m_nus, nus_string, &bytes_to_send, m_conn_handle);
        if ((err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_NOT_FOUND))
        m_adc_evt_counter++;
void saadc_init(void)
    nrf_drv_saadc_config_t saadc_config = NRF_DRV_SAADC_DEFAULT_CONFIG;
    saadc_config.resolution = NRF_SAADC_RESOLUTION_12BIT;
    nrf_saadc_channel_config_t channel_0_config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN4);     //P0.28
    channel_0_config.gain = NRF_SAADC_GAIN1_4;
    channel_0_config.reference = NRF_SAADC_REFERENCE_VDD4;
   // nrf_saadc_channel_config_t channel_1_config =
    //    NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN5);
   // channel_1_config.gain = NRF_SAADC_GAIN1_4;
  //  channel_1_config.reference = NRF_SAADC_REFERENCE_VDD4;
  //  nrf_saadc_channel_config_t channel_2_config =
  //      NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN6);
  //  channel_2_config.gain = NRF_SAADC_GAIN1_4;
  //  channel_2_config.reference = NRF_SAADC_REFERENCE_VDD4;
   // nrf_saadc_channel_config_t channel_3_config =
   //     NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN7);
   // channel_3_config.gain = NRF_SAADC_GAIN1_4;
   // channel_3_config.reference = NRF_SAADC_REFERENCE_VDD4;
    err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_0_config);
    //err_code = nrf_drv_saadc_channel_init(1, &channel_1_config);
   // APP_ERROR_CHECK(err_code);
   // err_code = nrf_drv_saadc_channel_init(2, &channel_2_config);
   // err_code = nrf_drv_saadc_channel_init(3, &channel_3_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAADC_SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1],SAADC_SAMPLES_IN_BUFFER);
/**@brief Application main function.
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    saadc_sampling_event_init();
    saadc_init();
    // Start execution.
    advertising_start();
    // Enter main loop.
    for (;;)
        idle_state_handle();
I use this code for sampling analog input with 3.3 kHz and send it over BLE to PC , i use dongle to to read the sampled datas on nrfconnect tool for desktop. I tried to collect data in string (nus_string)  before sending it via BLE . The SAADC block can sample the data but,  the problem is that probably ble_nus_data_send just sent one of the samples in string and other samples cannot be read on nrfconnect. Missing samples destroy my digital signal. How can i solve this problem ?
I would be really pleased to help me.
Best Regards.
    For sending large number of samples, it is better to send the actual raw samples as 16-bit integers, as converting it to/from string will be time-consuming and generate more data over the air.
    In an older version of the GitHub example, we actually sent the raw SAADC data over NUS, but too many people got confused when trying to read the received data on phone applications like nRF Toolbox UART. You can use this method, but you need to read the received values as int16_t on the receiver end, and not as string. To be able to achieve 3.3kHz sample interval over BLE, you need to configure quite low connection interval and/or increase the BLE packet length to send more samples in each transfer.
    Jørgen
    I solved this problem , but my new problem is now, the external power supply create noise on my signal. When i supply nrf with usb , the results are suitable but when i supply the nrf with 3.3V through external power supply pins, the analog signal which i want to convert to digital has noise on it.
    What is the reason of that? How can i solve it?
    Best Regards.
  • Normally, the USB would cause more noise than external supply. Is the voltage of your external supply stable? Are you using any switching regulators in the supply system?
    You can average out the noise by enabling oversampling in the SAADC peripheral, but this will increase the sample time for each result proportionally. Enabling BURST mode will allow you to do the oversampling as fast as possible.
