Safely updating duty cycle values during playback
The NRF documentation for nrf_pwm_sequence_t says:
When the sequence is set (by a call to nrf_pwm_sequence_set), the provided duty cycle values are not copied. The values pointer is stored in the internal register of the peripheral, and the values are loaded from RAM during the sequence playback. Therefore, you must ensure that the values do not change before and during the sequence playback (for example, the values cannot be placed in a local variable that is allocated on stack).
But the NRFX function nrfx_pwm_sequence_values_update is defined as
a Function for updating the pointer to the duty cycle values in the specified sequence during playback.
Does this mean that the user can update duty cycles using this function at any time, without worrying about a safe window?
    Thank you for your patience with this.
    To clarify this, this means that you must ensure that the pointer you provide actually points to the values for the playback at the time of the playback - for example, if the values only persist through the scope of an 'update_pwm' function, they may be overwritten by the time the playback actually happens, which is not a valid way to operate the PWM peripheral.
    On the other hand, if your playback sequence values are persistent throughout the duration of your PWM peripheral's operation - such as in the case of global variables - it will ensure that the pointer you provide to the PWM peripheral always points to the valid playback sequence values.
    No, because this function only update's the PWM's pointer - it does not perform any check to see if the location of the values will persist until the playback occurs.
    The issue arises if you supply a pointer that points to non-persistent playback sequence values. The 'safe window' in this case would therefor be the time in which you can guarantee that the sequence playback values that you have provided the pointer for does not change / are actually stored at the location.
    Please do not hesitate to let me know if any part of this still should be unclear! :)
    Karl
  • Thanks for the update. What I am not clear on, is at what point it becomes unsafe to change the values.... So. If I have an external trigger ( for example, an ADC read), that provides values for the PWM duty cycle, and when it completes, I want to update the PWM duty cycles. I know that the NRFX_PWM_EVT_END_SEQ0 or NRFX_PWM_EVT_END_SEQ1  Indicates that it is safe to update the values, but I'm not clear what event I should subscribe to that indicates that it is unsafe. nrfx_pwm_evt_type_t  only contains
    Enumerator
    NRFX_PWM_EVT_FINISHED
    Sequence playback finished.
    End of sequence 0 reached. Its data can be safely modified now.
    End of sequence 1 reached. Its data can be safely modified now.
    NRFX_PWM_EVT_STOPPED
    The PWM peripheral has been stopped.
    And NRFX_PWM_EVT_FINISHED  appears to occur at the same time as NRFX_PWM_EVT_END_SEQ0/1.
    Is the only way to do this using NRFX, to cache the new values until that NRFX_PWM_EVT_END_SEQ0/1 occurs, and then update then?
    I notice that NRF has a more compete set of events:
    Enumerator
    NRF_PWM_EVENT_STOPPED
    Response to STOP task, emitted when PWM pulses are no longer generated.
    NRF_PWM_EVENT_SEQSTARTED0
    First PWM period started on sequence 0.
    NRF_PWM_EVENT_SEQSTARTED1
    First PWM period started on sequence 1.
    NRF_PWM_EVENT_SEQEND0
    Emitted at the end of every sequence 0 when its last value has been read from RAM.
    NRF_PWM_EVENT_SEQEND1
    Emitted at the end of every sequence 1 when its last value has been read from RAM.
    NRF_PWM_EVENT_PWMPERIODEND
    Emitted at the end of each PWM period.
    NRF_PWM_EVENT_LOOPSDONE
    Concatenated sequences have been played the requested number of times.
    I presume that the safe window is defined as between SEQSTARTED and SEQEND? But these events are not available in NRFX?
    Is there a reason why some of these events are not exposed at the NRFX layer?
  • Hello again,
    No problem at all, I am happy to help!
    Yes, this is how you should do this, update the sequence as part of the END_SEQ event handling. The NRFX_PWM_EVT_FINISHED event will only be generated once a sequence playback has completed the specified number of times - generated when the LOOPSDONE event has been generated - while the SEQEND events are generated for each sequence end.
    No, that would be the unsafe window - the values should not be changed between SEQSTARTED and SEQEND, instead it should be between SEQEND and SEQSTARTED.
    These events are not exposed to the application layer, no - they are used by the driver directly, and then the driver will forward relevant NRFX events to the application layer event handler based on these. These
    Karl
