JLinkARM DLL reported an error with JLink Mini
Hi support,
I'm currently having issue trying to program a nrf52833 device using Jlink mini on mac. I have no problem programming the device using a pro Jlink on windows though.
I have tried both with nrfConnect and nrfjprog but can't get it to program with either. The device is reporting error with JLinkARM DLL on nrfjprog. I made sure that the board is powered on properly and I can also see the board name, NRF52833_xxAA_REV1, on nrfConnect.
I have also tried to run nrfjprog -f NRF52 --recover but that didn't seem to help
Here's the full log from nrfjprog
[2022-Mar-03 11:32:39] [ info] --------------------------------------------------------------------------------
[2022-Mar-03 11:32:39] [ info] nrfjprog -f NRF52 --program merged_file.hex --chiperase --verify --log log.txt
[2022-Mar-03 11:32:39] [ info] nrfjprog version 10.15.4 external
[2022-Mar-03 11:32:39] [ info] Load library at /Applications/Nordic Semiconductor/lib/libnrfjprogdll.dylib.
[2022-Mar-03 11:32:39] [ info] Library loaded, loading member functions.
[2022-Mar-03 11:32:39] [ info] Member functions succesfully loaded.
[2022-Mar-03 11:32:39] [debug] [ Client] - open
[2022-Mar-03 11:32:39] [debug] [ Client] - start
[2022-Mar-03 11:32:40] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 9cc8ba8c-f4f6-49c9-8cc4-fec62e394d8c.
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2022-Mar-03 11:32:40] [debug] [ JLink] - Logger sink registered in JLink logger
[2022-Mar-03 11:32:40] [debug] [ nRF52] - open
[2022-Mar-03 11:32:40] [debug] [ nRF52] - just_check_family
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - open_dll
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2022-Mar-03 11:32:40] [ info] [SeggerBackend] - Load library at /Applications/SEGGER/JLink/libjlinkarm.dylib.
[2022-Mar-03 11:32:40] [trace] [ Client] - Command open executed for 402 milliseconds with result 0
[2022-Mar-03 11:32:40] [debug] [ Client] - enum_emu_snr
[2022-Mar-03 11:32:40] [trace] [ Client] - Command enum_emu_con_info executed for 1 milliseconds with result 0
[2022-Mar-03 11:32:40] [debug] [ Client] - connect_to_emu_with_snr
[2022-Mar-03 11:32:40] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2022-Mar-03 11:32:40] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - dll_version
[2022-Mar-03 11:32:40] [ info] [SeggerBackend] - Segger dll version 7.62.a loaded.
[2022-Mar-03 11:32:40] [trace] [ Worker] - Command open executed for 315 milliseconds with result 0
[2022-Mar-03 11:32:40] [debug] [ nRF52] - enum_emu_con_info
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - is_connected_to_emu
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - enum_emu_con_info
[2022-Mar-03 11:32:40] [trace] [ Worker] - Command enum_emu_con_info executed for 1 milliseconds with result 0
[2022-Mar-03 11:32:40] [debug] [ nRF52] - connect_to_emu_with_snr
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - ---just_get_num_emus
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - Segger logging enabled.
[2022-Mar-03 11:32:40] [trace] [ JLink] - Firmware: J-Link EDU Mini V1 compiled Dec 7 2021 08:38:51
[2022-Mar-03 11:32:40] [trace] [ JLink] - Hardware: V1.00
[2022-Mar-03 11:32:40] [trace] [ JLink] - S/N: 801041403
[2022-Mar-03 11:32:40] [trace] [ JLink] - OEM: SEGGER
[2022-Mar-03 11:32:40] [trace] [ JLink] - Feature(s): FlashBP, GDB
[2022-Mar-03 11:32:40] [trace] [ JLink] - USB speed mode: Full speed (12 MBit/s)
[2022-Mar-03 11:32:40] [trace] [ JLink] - TELNET listener socket opened on port 19021
[2022-Mar-03 11:32:40] [trace] [ JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2022-Mar-03 11:32:40] [trace] [ JLink] - WEBSRV Webserver running on local port 19080
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 155.159ms returns "O.K."
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_HasError()
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_Lock()
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_GetHWStatus(...)
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.235ms returns 0
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.019ms returns 0x01
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.001ms returns 0x00
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.016ms returns 0x00
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_SetHookUnsecureDialog
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_SetHookUnsecureDialog(...)
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.021ms returns 0
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2022-Mar-03 11:32:40] [trace] [ Client] - Command connect_to_emu_with_snr executed for 279 milliseconds with result 0
[2022-Mar-03 11:32:40] [debug] [ Client] - read_connected_emu_snr
[2022-Mar-03 11:32:40] [trace] [ Client] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2022-Mar-03 11:32:40] [debug] [ Client] - read_device_info
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.732ms returns 0x00
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_SetSpeed(2000)
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.099ms
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_GetSN()
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.003ms returns 801041403
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - read_debug_port_idr
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - read_debug_port_register
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - coresight_configure
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_CORESIGHT_Configure()
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.716ms returns 0
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.386ms returns -1
[2022-Mar-03 11:32:40] [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - ---just_abort_debug_action
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.220ms returns 0
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.214ms returns 0
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x00)
[2022-Mar-03 11:32:40] [trace] [ JLink] - Value=0x2BA01477
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.268ms returns 0
[2022-Mar-03 11:32:40] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 279 milliseconds with result 0
[2022-Mar-03 11:32:40] [debug] [ nRF52] - read_connected_emu_snr
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_IsOpen()
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.005ms returns 0x01
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - read_connected_emu_snr
[2022-Mar-03 11:32:40] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2022-Mar-03 11:32:40] [debug] [ nRF52] - read_device_info
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.002ms returns 0x01
[2022-Mar-03 11:32:40] [debug] [ nRF52] - Just_read_device_version
[2022-Mar-03 11:32:40] [debug] [ nRF52] - Just_readback_status
[2022-Mar-03 11:32:40] [debug] [ nRF52] - Just_is_ctrl_ap_available
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - read_access_port_register
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - ---just_read_access_port_register
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.227ms returns 0
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
[2022-Mar-03 11:32:40] [trace] [ JLink] - Value=0x00000040
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.236ms returns 0
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - power_debug_region
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - ---just_write_debug_port_register
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x01, 0x50000000)
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.298ms returns 0
[2022-Mar-03 11:32:40] [trace] [ JLink] - Value=0xF0000040
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.389ms returns 0
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - ---just_select_access_port_register
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.239ms returns 0
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
[2022-Mar-03 11:32:40] [trace] [ JLink] - failed
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.236ms returns -1
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.234ms returns 0
[2022-Mar-03 11:32:40] [trace] [ JLink] - Value=0x00000000
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.242ms returns 0
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.259ms returns 0
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - read_u32
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - ---just_connect_to_device
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - is_connected_to_device
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_IsConnected()
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.003ms returns FALSE
[2022-Mar-03 11:32:40] [debug] [SeggerBackend] - ---set_coresight_ahb_ap_index
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_ExecCommand("CORESIGHT_SetIndexAHBAPToUse = 0", ...).
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.017ms returns 0x00
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_ExecCommand("device = nRF52", ...).
[2022-Mar-03 11:32:40] [trace] [ JLink] - Device "NRF52" selected.
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.561ms returns 0x00
[2022-Mar-03 11:32:40] [trace] [ JLink] - - 0.233ms returns 0
[2022-Mar-03 11:32:40] [trace] [ JLink] - JLINK_Connect()
[2022-Mar-03 11:32:40] [trace] [ JLink] - InitTarget() start
[2022-Mar-03 11:32:40] [trace] [ JLink] - J-Link Script File: Executing InitTarget()
[2022-Mar-03 11:32:40] [trace] [ JLink] - InitTarget() end
[2022-Mar-03 11:32:40] [trace] [ JLink] - Found SW-DP with ID 0x2BA01477
[2022-Mar-03 11:32:40] [trace] [ JLink] - Failed to power up DAP
[2022-Mar-03 11:32:40] [trace] [ JLink] - DPIDR: 0x2BA01477
[2022-Mar-03 11:32:40] [trace] [ JLink] - CoreSight SoC-400 or earlier
[2022-Mar-03 11:32:40] [trace] [ JLink] - AP map detection skipped. Manually configured AP map found.
[2022-Mar-03 11:32:40] [trace] [ JLink] - AP[0]: AHB-AP (IDR: Not set)
[2022-Mar-03 11:32:40] [trace] [ JLink] - AP[0]: Core found
[2022-Mar-03 11:32:40] [trace] [ JLink] - AP[0]: AHB-AP ROM base: 0xE00FF000
[2022-Mar-03 11:32:40] [trace] [ JLink] - ***** Error:
[2022-Mar-03 11:32:40] [trace] [ JLink] - DAP error while reading AIRCR.
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 295.327ms returns 0xFFFFFEFB
[2022-Mar-03 11:32:41] [error] [ JLink] - DAP error while reading AIRCR.
[2022-Mar-03 11:32:41] [trace] [ JLink] - JLINK_HasError()
[2022-Mar-03 11:32:41] [error] [SeggerBackend] - JLinkARM.dll reported error -1 at line 4633.
[2022-Mar-03 11:32:41] [trace] [ JLink] - JLINK_ClrError()
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.006ms
[2022-Mar-03 11:32:41] [error] [SeggerBackend] - JLinkARM.dll reported "-261", "Could not find supported CPU.".
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - ---just_abort_debug_action
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2022-Mar-03 11:32:41] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.458ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - JLINK_Connect()
[2022-Mar-03 11:32:41] [trace] [ JLink] - InitTarget() start
[2022-Mar-03 11:32:41] [trace] [ JLink] - J-Link Script File: Executing InitTarget()
[2022-Mar-03 11:32:41] [trace] [ JLink] - InitTarget() end
[2022-Mar-03 11:32:41] [trace] [ JLink] - Found SW-DP with ID 0x2BA01477
[2022-Mar-03 11:32:41] [trace] [ JLink] - Failed to power up DAP
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 272.050ms returns 0xFFFFFEFB
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.427ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - DAP error while determining CoreSight SoC version
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 167.819ms returns 0xFFFFFEFB
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.407ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - DPIDR: 0x2BA01477
[2022-Mar-03 11:32:41] [trace] [ JLink] - CoreSight SoC-400 or earlier
[2022-Mar-03 11:32:41] [trace] [ JLink] - AP map detection skipped. Manually configured AP map found.
[2022-Mar-03 11:32:41] [trace] [ JLink] - AP[0]: AHB-AP (IDR: Not set)
[2022-Mar-03 11:32:41] [trace] [ JLink] - AP[0]: Skipped. Could not read CPUID register
[2022-Mar-03 11:32:41] [trace] [ JLink] - ***** Error:
[2022-Mar-03 11:32:41] [trace] [ JLink] - Could not find core in Coresight setup
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 166.700ms returns 0xFFFFFEFB
[2022-Mar-03 11:32:41] [error] [ JLink] - Could not find core in Coresight setup
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.429ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - AP[0]: Core found
[2022-Mar-03 11:32:41] [trace] [ JLink] - AP[0]: AHB-AP ROM base: 0xE00FF000
[2022-Mar-03 11:32:41] [trace] [ JLink] - CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
[2022-Mar-03 11:32:41] [trace] [ JLink] - Found Cortex-M4 r0p1, Little endian.
[2022-Mar-03 11:32:41] [trace] [ JLink] - -- Max. mem block: 0x00002BB8
[2022-Mar-03 11:32:41] [trace] [ JLink] - CPU_ReadMem(4 bytes @ 0xE000EDF0)
[2022-Mar-03 11:32:41] [trace] [ JLink] - CPU_WriteMem(4 bytes @ 0xE000EDF0)
[2022-Mar-03 11:32:41] [trace] [ JLink] - CPU_ReadMem(4 bytes @ 0xE0002000)
[2022-Mar-03 11:32:41] [trace] [ JLink] - FPUnit: 0 code (BP) slots and 0 literal slots
[2022-Mar-03 11:32:41] [trace] [ JLink] - CPU_ReadMem(4 bytes @ 0xE000EDFC)
[2022-Mar-03 11:32:41] [trace] [ JLink] - CPU_WriteMem(4 bytes @ 0xE000EDFC)
[2022-Mar-03 11:32:41] [trace] [ JLink] - CPU_ReadMem(4 bytes @ 0xE0001000)
[2022-Mar-03 11:32:41] [trace] [ JLink] - CPU_WriteMem(4 bytes @ 0xE0001000)
[2022-Mar-03 11:32:41] [trace] [ JLink] - CPU_ReadMem(4 bytes @ 0xE000ED88)
[2022-Mar-03 11:32:41] [trace] [ JLink] - CPU_WriteMem(4 bytes @ 0xE000ED88)
[2022-Mar-03 11:32:41] [trace] [ JLink] - CoreSight components:
[2022-Mar-03 11:32:41] [trace] [ JLink] - ROMTbl[0] @ E00FF000
[2022-Mar-03 11:32:41] [trace] [ JLink] - CPU_ReadMem(64 bytes @ 0xE00FF000)
[2022-Mar-03 11:32:41] [trace] [ JLink] - CPU_ReadMem(32 bytes @ 0xE000EFE0)
[2022-Mar-03 11:32:41] [trace] [ JLink] - [0][0]: E000E000 CID B105E00D PID 000BB00C SCS-M7
[2022-Mar-03 11:32:41] [trace] [ JLink] - CPU_ReadMem(32 bytes @ 0xE0001FE0)
[2022-Mar-03 11:32:41] [trace] [ JLink] - [0][1]: E0001000 CID B105E00D PID 003BB002 DWT
[2022-Mar-03 11:32:41] [trace] [ JLink] - CPU_ReadMem(32 bytes @ 0xE0002FE0)
[2022-Mar-03 11:32:41] [trace] [ JLink] - [0][2]: E0002000 CID B105E00D PID 002BB003 FPB
[2022-Mar-03 11:32:41] [trace] [ JLink] - CPU_ReadMem(32 bytes @ 0xE0000FE0)
[2022-Mar-03 11:32:41] [trace] [ JLink] - [0][3]: E0000000 CID 00000000 PID 00000000 ???
[2022-Mar-03 11:32:41] [trace] [ JLink] - CPU_ReadMem(32 bytes @ 0xE0040FE0)
[2022-Mar-03 11:32:41] [trace] [ JLink] - [0][4]: E0040000 CID B105900D PID 000BB9A1 TPIU
[2022-Mar-03 11:32:41] [trace] [ JLink] - CPU_ReadMem(32 bytes @ 0xE0041FE0)
[2022-Mar-03 11:32:41] [trace] [ Client] - Command read_device_info executed for 1196 milliseconds with result 0
[2022-Mar-03 11:32:41] [debug] [ Client] - read_memory_descriptors
[2022-Mar-03 11:32:41] [trace] [ JLink] - [0][5]: E0041000 CID B105900D PID 000BB925 ETM
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 285.434ms returns 0x00
[2022-Mar-03 11:32:41] [trace] [ JLink] - JLINK_CORE_GetFound()
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.003ms returns 0xE0000FF
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - ---just_read_u32
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - ---just_invalidate_cache
[2022-Mar-03 11:32:41] [trace] [ JLink] - JLINK_ExecCommand("InvalidateCache", ...).
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.056ms returns 0x00
[2022-Mar-03 11:32:41] [trace] [ JLink] - JLINK_ReadMemU32(0x10000130, 0x1 Items)
[2022-Mar-03 11:32:41] [trace] [ JLink] - CPU_ReadMem(4 bytes @ 0x10000130)
[2022-Mar-03 11:32:41] [trace] [ JLink] - Data: 0D 00 00 00
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.411ms returns 1 (0x1)
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - read_u32
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - ---just_connect_to_device
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - is_connected_to_device
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.005ms returns 0x00
[2022-Mar-03 11:32:41] [trace] [ JLink] - JLINK_ReadMemU32(0x10000134, 0x1 Items)
[2022-Mar-03 11:32:41] [trace] [ JLink] - CPU_ReadMem(4 bytes @ 0x10000134)
[2022-Mar-03 11:32:41] [trace] [ JLink] - Data: 00 00 00 00
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.351ms returns 1 (0x1)
[2022-Mar-03 11:32:41] [debug] [ nRF52] - Just_decode_device_version
[2022-Mar-03 11:32:41] [trace] [ JLink] - JLINK_ReadMemU32(0x10000110, 0x1 Items)
[2022-Mar-03 11:32:41] [trace] [ JLink] - CPU_ReadMem(4 bytes @ 0x10000110)
[2022-Mar-03 11:32:41] [trace] [ JLink] - Data: 00 02 00 00
[2022-Mar-03 11:32:41] [trace] [ Worker] - Command read_device_info executed for 1196 milliseconds with result 0
[2022-Mar-03 11:32:41] [debug] [ nRF52] - read_memory_descriptors
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - is_connected_to_emu
[2022-Mar-03 11:32:41] [trace] [ JLink] - JLINK_IsOpen()
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.007ms returns 0x01
[2022-Mar-03 11:32:41] [trace] [ JLink] - JLINK_Lock()
[2022-Mar-03 11:32:41] [debug] [ nRF52] - Just_read_memory_descriptors
[2022-Mar-03 11:32:41] [debug] [ nRF52] - Just_readback_status
[2022-Mar-03 11:32:41] [debug] [ nRF52] - Just_is_ctrl_ap_available
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - read_access_port_register
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - ---just_read_access_port_register
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2022-Mar-03 11:32:41] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.227ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
[2022-Mar-03 11:32:41] [trace] [ JLink] - Value=0xF0000040
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.214ms returns 0
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - ---just_select_access_port_register
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
[2022-Mar-03 11:32:41] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.212ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
[2022-Mar-03 11:32:41] [trace] [ JLink] - Value=0x02880000
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.237ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.238ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.240ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.232ms returns 0
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.206ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - failed
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.211ms returns -1
[2022-Mar-03 11:32:41] [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.216ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.242ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.244ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.243ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.241ms returns 0
[2022-Mar-03 11:32:41] [ info] [ nRF52] - Protection status read as NONE
[2022-Mar-03 11:32:41] [debug] [ nRF52] - update_device_memory_list
[2022-Mar-03 11:32:41] [debug] [ nRF52] - Just_read_device_version
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.218ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.239ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.236ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - Value=0x00000001
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.230ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - JLINK_IsConnected()
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.003ms returns TRUE
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.006ms returns 0x00
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - ---just_write_debug_port_register
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.343ms returns 1 (0x1)
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.004ms returns 0x00
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.400ms returns -1 (0xFFFFFFFF)
[2022-Mar-03 11:32:41] [error] [SeggerBackend] - JLinkARM.dll ReadMemU32 detected a read error 1.
[2022-Mar-03 11:32:41] [error] [SeggerBackend] - This typically indicates the read was blocked by a memory protection mechanism.
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.594ms returns -1 (0xFFFFFFFF)
[2022-Mar-03 11:32:41] [trace] [ Client] - Command read_memory_descriptors executed for 8 milliseconds with result 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.347ms returns 1 (0x1)
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.350ms returns 1 (0x1)
[2022-Mar-03 11:32:41] [debug] [ nRF52] - Read memory description from family DLL: "Flash" [0x00000000-0x00080000] 128 pages (128x4kB) static ID0
[2022-Mar-03 11:32:41] [debug] [ nRF52] - Read memory description from family DLL: "Code RAM" [0x00800000-0x00820000] 18 pages (16x4kB,2x32kB) static ID8388608
[2022-Mar-03 11:32:41] [debug] [ nRF52] - Read memory description from family DLL: "FICR" [0x10000000-0x10001000] 1 pages (1x4kB) static ID268435456
[2022-Mar-03 11:32:41] [debug] [ nRF52] - Read memory description from family DLL: "UICR" [0x10001000-0x10002000] 1 pages (1x4kB) static ID268439552
[2022-Mar-03 11:32:41] [debug] [ nRF52] - Read memory description from family DLL: "RAM" [0x20000000-0x20020000] 18 pages (16x4kB,2x32kB) static ID536870912
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.221ms
[2022-Mar-03 11:32:41] [trace] [ Worker] - Command read_memory_descriptors executed for 8 milliseconds with result 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.005ms returns 0x01
[2022-Mar-03 11:32:41] [trace] [ Client] - Command read_memory_descriptors executed for 10 milliseconds with result 0
[2022-Mar-03 11:32:41] [debug] [ Client] - read_page_sizes
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.362ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.347ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.245ms returns 0
[2022-Mar-03 11:32:41] [trace] [ Client] - Command read_page_sizes executed for 0 milliseconds with result 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.393ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.231ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.203ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.215ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.219ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.233ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.271ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.387ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.273ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.002ms returns TRUE
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.008ms returns 0x00
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.228ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.735ms returns -1 (0xFFFFFFFF)
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.346ms returns 1 (0x1)
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.463ms returns -1 (0xFFFFFFFF)
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.703ms returns -1 (0xFFFFFFFF)
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.549ms returns -1 (0xFFFFFFFF)
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.495ms returns 1 (0x1)
[2022-Mar-03 11:32:41] [debug] [ nRF52] - Memory list already constructed. Skipping.
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.024ms
[2022-Mar-03 11:32:41] [trace] [ Worker] - Command read_memory_descriptors executed for 10 milliseconds with result 0
[2022-Mar-03 11:32:41] [debug] [ nRF52] - read_page_sizes
[2022-Mar-03 11:32:41] [debug] [ nRF52] - Just_read_page_sizes
[2022-Mar-03 11:32:41] [trace] [ Worker] - Command read_page_sizes executed for 0 milliseconds with result 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.004ms returns 0x01
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.033ms
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.022ms returns 0x01
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.017ms
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.003ms returns 0x01
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.020ms returns 0x01
[2022-Mar-03 11:32:41] [debug] [ Client] - erase
[2022-Mar-03 11:32:41] [debug] [ nRF52] - erase_file
[2022-Mar-03 11:32:41] [trace] [ Client] - Command erase_file executed for 70 milliseconds with result -104
[2022-Mar-03 11:32:41] [debug] [ nRF52] - init_device_info
[2022-Mar-03 11:32:41] [debug] [ nRF52] - read_device_info
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.452ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.309ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.288ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.303ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.291ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.283ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.275ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.221ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.249ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.262ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.211ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.355ms returns 1 (0x1)
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.394ms returns 1 (0x1)
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.003ms returns 0x00
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.409ms returns -1 (0xFFFFFFFF)
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.607ms returns -1 (0xFFFFFFFF)
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.464ms returns -1 (0xFFFFFFFF)
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.597ms returns -1 (0xFFFFFFFF)
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.542ms returns -1 (0xFFFFFFFF)
[2022-Mar-03 11:32:41] [error] [ nRF52] - Failed while reading device version
[2022-Mar-03 11:32:41] [error] [ nRF52] - Failed while reading device information.
[2022-Mar-03 11:32:41] [error] [ nRF52] - Failed while erasing file merged_file.hex.
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.059ms
[2022-Mar-03 11:32:41] [trace] [ Worker] - Command erase_file executed for 70 milliseconds with result -104
[2022-Mar-03 11:32:41] [debug] [ nRF52] - close
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.006ms returns 0x01
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - close
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - disconnect_from_emu
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - ---just_disconnect_from_emu
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.342ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - Value=0xF0000000
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - Disable trace before closing connection.
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - ---just_write_u32
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.209ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.204ms returns 0
[2022-Mar-03 11:32:41] [trace] [ JLink] - JLINK_WriteU32_64(0xE000EDFC, 0x00000000)
[2022-Mar-03 11:32:41] [trace] [ JLink] - Debug reg: DEMCR
[2022-Mar-03 11:32:41] [trace] [ JLink] - CPU is running
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 1.154ms returns 0 (0x00000000)
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - Shortcut, lock is on and debug region is powered.
[2022-Mar-03 11:32:41] [debug] [SeggerBackend] - unpower_debug_and_system_regions
[2022-Mar-03 11:32:41] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x01, 0x00000000)
[2022-Mar-03 11:32:41] [trace] [ JLink] - Value=0xF00000C0
[2022-Mar-03 11:32:41] [trace] [ JLink] - - 0.248ms returns 0
[2022-Mar-03 11:32:42] [trace] [ JLink] - - 0.224ms returns -1
[2022-Mar-03 11:32:42] [trace] [ JLink] - JLINK_HasError()
[2022-Mar-03 11:32:42] [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
[2022-Mar-03 11:32:42] [debug] [SeggerBackend] - ---just_abort_debug_action
[2022-Mar-03 11:32:42] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2022-Mar-03 11:32:42] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2022-Mar-03 11:32:42] [trace] [ JLink] - - 0.318ms returns 0
[2022-Mar-03 11:32:42] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x01, 0x00000000)
[2022-Mar-03 11:32:42] [trace] [ JLink] - - 0.260ms returns 0
[2022-Mar-03 11:32:42] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2022-Mar-03 11:32:42] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2022-Mar-03 11:32:42] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2022-Mar-03 11:32:42] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
[2022-Mar-03 11:32:42] [trace] [ JLink] - Value=0x00000040
[2022-Mar-03 11:32:42] [trace] [ JLink] - - 0.393ms returns 0
[2022-Mar-03 11:32:42] [trace] [ JLink] - - 0.003ms
[2022-Mar-03 11:32:42] [trace] [ JLink] - JLINK_Close()
[2022-Mar-03 11:32:42] [debug] [SeggerBackend] - Segger Backend closed.
[2022-Mar-03 11:32:42] [debug] [ nRF52] - nRF family DLL closed
[2022-Mar-03 11:32:42] [trace] [ Client] - Command close executed for 40 milliseconds with result 0
[2022-Mar-03 11:32:42] [debug] [ Client] - terminate
[2022-Mar-03 11:32:42] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
[2022-Mar-03 11:32:42] [trace] [ Worker] - Command close executed for 40 milliseconds with result 0
[2022-Mar-03 11:32:42] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
[2022-Mar-03 11:32:42] [trace] [ Worker] - Executed 20 commands for 1919 milliseconds
[2022-Mar-03 11:32:42] [debug] [ Client] - Worker process exited with code: 0
[2022-Mar-03 11:32:42] [debug] [ Client] - Tried to wait on already ended process: wait error: No child processes
[2022-Mar-03 11:32:42] [debug] [ Client] - Child process terminated with result 0
[2022-Mar-03 11:32:42] [trace] [ Client] - Executed 20 commands for 2006 milliseconds
Appreciate the help and thank you in advance,
Huy
