I am working on integrating wireless-timer-synchronization into the HCI_RPMsg sample provided with nRF Connect SDK. My goal is to synchronize ADC sampling between BLE Peripheral devices all connected to a single central device. The central device transmits sync packets and the peripherals listen for them. I followed the updating to the mpsl timeslot interface post to update the timer synchronization code to use mpsl timeslots and it is working for the most part.
nRF Connect SDK: v1.9.0
Board: nRF5340DK v2.0.0
The code runs as expected when running on the peripheral device (Rx mode), but when I run the exact same image on the central (Tx mode) I get the following exception:
[00:00:45.308,441] <err> sdc_hci_driver: SoftDevice Controller ASSERT: 53, 607 [00:00:45.308,471] <err> os: ***** HARD FAULT ***** [00:00:45.308,471] <err> os: Fault escalation (see below) [00:00:45.308,471] <err> os: ARCH_EXCEPT with reason 3 [00:00:45.308,502] <err> os: r0/a1: 0x00000003 r1/a2: 0x00000007 r2/a3: 0x00000006 [00:00:45.308,532] <err> os: r3/a4: 0x21001868 r12/ip: 0xf7bfded5 r14/lr: 0x0102441f [00:00:45.308,532] <err> os: xpsr: 0x4100001c [00:00:45.308,532] <err> os: r4/v1: 0x00000441 r5/v2: 0x0000025f r6/v3: 0x210077a0 [00:00:45.308,532] <err> os: r7/v4: 0x00000000 r8/v5: 0x00000000 r9/v6: 0x00000000 [00:00:45.308,563] <err> os: r10/v7: 0x00000000 r11/v8: 0x00000000 psp: 0x21006fc0 [00:00:45.308,563] <err> os: EXC_RETURN: 0xffffffb0 [00:00:45.308,563] <err> os: Faulting instruction address (r15/pc): 0x01028ea2 [00:00:45.308,563] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0 [00:00:45.308,563] <err> os: Fault during interrupt handling [00:00:45.308,593] <err> os: Current thread: 0x21001c70 (idle 00) [00:00:45.456,726] <err> os: Halting system
The only difference is that the peripheral is using the radio in Rx mode, while the transmitter is using it in Tx mode. The exception occurs after the first timeslot has ended.
I have verified that the radio is disabled before the timeslot ends. The "timeslot is ending" callbacks for Rx and Tx modes are practically identical, the only thing different is the DPPI channel that gets cleared.
Can someone shed some light on what this assert means?
