NRF52833DK Persistent Hard Faults
I am developing an NRF52833 application that reads from the I2C sensor MLX90641. Below is the code I am using to test. MLX90641_I2C_Driver.c was originally written for Mbed and is meant to be adapted to the target platform. It isn't important to understand MLX90641_API.c, the important part is in main and MLX90641_I2C_Driver.c, where you can see the arguments passed as they are outputted to printk. This is all running on NRF52833DK with NCS v1.8.
main.c:
#include <zephyr.h>
#include <sys/printk.h>
#include "MLX90641_API.h"
#include "MLX90641_I2C_Driver.h"
#define TA_SHIFT 8 //Default shift for MLX90641 in open air
static float mlx90641To[768];
paramsMLX90641 mlx90641;
void main(void)
	printk("Running sensor_testing on %s\n", CONFIG_BOARD);
	MLX90641_I2CInit();
	int status;
    uint16_t eeMLX90641[832];
    status = MLX90641_DumpEE(MLX90641_ADDR, eeMLX90641);
    if (status != 0) {
        printk("Failed to load system parameters\n");
    status = MLX90641_ExtractParameters(eeMLX90641, &mlx90641);
    if (status != 0) {
        printk("Parameter extraction failed\n");
	while(1) {
		for (uint8_t x = 0 ; x < 2 ; x++) { //Read both subpages
			uint16_t mlx90641Frame[834];
			int status = MLX90641_GetFrameData(MLX90641_ADDR, mlx90641Frame);
			if (status < 0) {
				printk("GetFrame Error: %d\n", status);
			float vdd = MLX90641_GetVdd(mlx90641Frame, &mlx90641);
			float Ta = MLX90641_GetTa(mlx90641Frame, &mlx90641);
			float tr = Ta - TA_SHIFT; //Reflected temperature based on the sensor ambient temperature
			float emissivity = 0.95;
			MLX90641_CalculateTo(mlx90641Frame, &mlx90641, emissivity, tr, mlx90641To);
		for (int x = 0 ; x < 10 ; x++) {
			printk("Pixel %d: %fC\n", x, mlx90641To[x]);
		k_sleep(K_SECONDS(1));
MLX90641_API.c: (not important to understand)
#include <math.h>
void ExtractVDDParameters(uint16_t *eeData, paramsMLX90641 *mlx90641);
void ExtractPTATParameters(uint16_t *eeData, paramsMLX90641 *mlx90641);
void ExtractGainParameters(uint16_t *eeData, paramsMLX90641 *mlx90641);
void ExtractTgcParameters(uint16_t *eeData, paramsMLX90641 *mlx90641);
void ExtractEmissivityParameters(uint16_t *eeData, paramsMLX90641 *mlx90641);
void ExtractResolutionParameters(uint16_t *eeData, paramsMLX90641 *mlx90641);
void ExtractKsTaParameters(uint16_t *eeData, paramsMLX90641 *mlx90641);
void ExtractKsToParameters(uint16_t *eeData, paramsMLX90641 *mlx90641);
void ExtractAlphaParameters(uint16_t *eeData, paramsMLX90641 *mlx90641);
void ExtractOffsetParameters(uint16_t *eeData, paramsMLX90641 *mlx90641);
void ExtractKtaPixelParameters(uint16_t *eeData, paramsMLX90641 *mlx90641);
void ExtractKvPixelParameters(uint16_t *eeData, paramsMLX90641 *mlx90641);
void ExtractCPParameters(uint16_t *eeData, paramsMLX90641 *mlx90641);
int ExtractDeviatingPixels(uint16_t *eeData, paramsMLX90641 *mlx90641);
int CheckEEPROMValid(uint16_t *eeData);
int HammingDecode(uint16_t *eeData);
int ValidateFrameData(uint16_t *frameData);
int ValidateAuxData(uint16_t *auxData);
int MLX90641_DumpEE(uint8_t slaveAddr, uint16_t *eeData)
     int error = 1;
     error = MLX90641_I2CRead(slaveAddr, 0x2400, 832, eeData);
     if (error == 0)
        error = HammingDecode(eeData);
     return error;
    int error = 0;
    int16_t parity[5];
    int8_t D[16];
    int16_t check;
    uint16_t data;
    uint16_t mask;
    for (int addr=16; addr<832; addr++)
        parity[0] = -1;
        parity[1] = -1;
        parity[2] = -1;
        parity[3] = -1;
        parity[4] = -1;
        data = eeData[addr];
        mask = 1;
        for( int i = 0; i < 16; i++)
          D[i] = (data & mask) >> i;
          mask = mask << 1;
        parity[0] = D[0]^D[1]^D[3]^D[4]^D[6]^D[8]^D[10]^D[11];
        parity[1] = D[0]^D[2]^D[3]^D[5]^D[6]^D[9]^D[10]^D[12];
        parity[2] = D[1]^D[2]^D[3]^D[7]^D[8]^D[9]^D[10]^D[13];
        parity[3] = D[4]^D[5]^D[6]^D[7]^D[8]^D[9]^D[10]^D[14];
        parity[4] = D[0]^D[1]^D[2]^D[3]^D[4]^D[5]^D[6]^D[7]^D[8]^D[9]^D[10]^D[11]^D[12]^D[13]^D[14]^D[15];
        if ((parity[0]!=0) || (parity[1]!=0) || (parity[2]!=0) || (parity[3]!=0) || (parity[4]!=0))
            check = (parity[0]<<0) + (parity[1]<<1) + (parity[2]<<2) + (parity[3]<<3) + (parity[4]<<4);
            if ((check > 15)&&(check < 32))
                switch (check)
                    case 16:
                        D[15] = 1 - D[15];
                    case 24:
                        D[14] = 1 - D[14];
                    case 20:
                        D[13] = 1 - D[13];
                    case 18:
                        D[12] = 1 - D[12];
                    case 17:
                        D[11] = 1 - D[11];
                    case 31:
                        D[10] = 1 - D[10];
                    case 30:
                        D[9] = 1 - D[9];
                    case 29:
                        D[8] = 1 - D[8];
                    case 28:
                        D[7] = 1 - D[7];
                    case 27:
                        D[6] = 1 - D[6];
                    case 26:
                        D[5] = 1 - D[5];
                    case 25:
                        D[4] = 1 - D[4];
                    case 23:
                        D[3] = 1 - D[3];
                    case 22:
                        D[2] = 1 - D[2];
                    case 21:
                        D[1] = 1 - D[1];
                    case 19:
                        D[0] = 1 - D[0];
                if(error == 0)
                    error = -9;
                data = 0;
                mask = 1;
                    data = data + D[i]*mask;
                    mask = mask << 1;
                error = -10;
        eeData[addr] = data & 0x07FF;
    return error;
int MLX90641_SynchFrame(uint8_t slaveAddr)
    uint16_t dataReady = 0;
    uint16_t statusRegister;
    int error = 1;
    error = MLX90641_I2CWrite(slaveAddr, 0x8000, 0x0030);
    if(error == -1)
        return error;
    while(dataReady == 0)
        error = MLX90641_I2CRead(slaveAddr, 0x8000, 1, &statusRegister);
        if(error != 0)
            return error;
        dataReady = statusRegister & 0x0008;
   return 0;
int MLX90641_TriggerMeasurement(uint8_t slaveAddr)
    int error = 1;
    uint16_t ctrlReg;
    error = MLX90641_I2CRead(slaveAddr, 0x800D, 1, &ctrlReg);
    if ( error != 0)
        return error;
    ctrlReg |= 0x8000;
    error = MLX90641_I2CWrite(slaveAddr, 0x800D, ctrlReg);
    if ( error != 0)
        return error;
    error = MLX90641_I2CGeneralReset();
    if ( error != 0)
        return error;
    if ( error != 0)
        return error;
    if ((ctrlReg & 0x8000) != 0)
        return -11;
    return 0;
int MLX90641_GetFrameData(uint8_t slaveAddr, uint16_t *frameData)
    uint16_t dataReady = 1;
    uint16_t controlRegister1;
    uint16_t data[48];
    int error = 1;
    uint8_t cnt = 0;
    uint8_t subPage = 0;
    dataReady = 0;
        if(error != 0)
            return error;
    subPage = statusRegister & 0x0001;
    if(error == -1)
        return error;
    if(subPage == 0)
        error = MLX90641_I2CRead(slaveAddr, 0x0400, 32, frameData);
        if(error != 0)
            return error;
        error = MLX90641_I2CRead(slaveAddr, 0x0440, 32, frameData+32);
        if(error != 0)
            return error;
        error = MLX90641_I2CRead(slaveAddr, 0x0480, 32, frameData+64);
        if(error != 0)
            return error;
        error = MLX90641_I2CRead(slaveAddr, 0x04C0, 32, frameData+96);
        if(error != 0)
            return error;
        error = MLX90641_I2CRead(slaveAddr, 0x0500, 32, frameData+128);
        if(error != 0)
            return error;
        error = MLX90641_I2CRead(slaveAddr, 0x0540, 32, frameData+160);
        if(error != 0)
            return error;
        error = MLX90641_I2CRead(slaveAddr, 0x0420, 32, frameData);
        if(error != 0)
            return error;
        error = MLX90641_I2CRead(slaveAddr, 0x0460, 32, frameData+32);
        if(error != 0)
            return error;
        error = MLX90641_I2CRead(slaveAddr, 0x04A0, 32, frameData+64);
        if(error != 0)
            return error;
        error = MLX90641_I2CRead(slaveAddr, 0x04E0, 32, frameData+96);
        if(error != 0)
            return error;
        error = MLX90641_I2CRead(slaveAddr, 0x0520, 32, frameData+128);
        if(error != 0)
            return error;
        error = MLX90641_I2CRead(slaveAddr, 0x0560, 32, frameData+160);
        if(error != 0)
            return error;
    error = MLX90641_I2CRead(slaveAddr, 0x0580, 48, data);
    if(error != 0)
        return error;
    error = MLX90641_I2CRead(slaveAddr, 0x800D, 1, &controlRegister1);
    frameData[240] = controlRegister1;
    frameData[241] = subPage;
    if(error != 0)
        return error;
    error = ValidateAuxData(data);
    if(error == 0)
        for(cnt=0; cnt<48; cnt++)
            frameData[cnt+192] = data[cnt];
    error = ValidateFrameData(frameData);
    if (error != 0)
        return error;
    return frameData[241];
    uint8_t line = 0;
    for(int i=0; i<192; i+=16)
        if(frameData[i] == 0x7FFF) return -8;
        line = line + 1;
    return 0;
    if(auxData[0] == 0x7FFF) return -8;
    for(int i=8; i<19; i++)
        if(auxData[i] == 0x7FFF) return -8;
    for(int i=20; i<23; i++)
    for(int i=24; i<33; i++)
    for(int i=40; i<48; i++)
    return 0;
int MLX90641_ExtractParameters(uint16_t *eeData, paramsMLX90641 *mlx90641)
    int error = CheckEEPROMValid(eeData);
    if(error == 0)
        ExtractVDDParameters(eeData, mlx90641);
        ExtractPTATParameters(eeData, mlx90641);
        ExtractGainParameters(eeData, mlx90641);
        ExtractTgcParameters(eeData, mlx90641);
        ExtractEmissivityParameters(eeData, mlx90641);
        ExtractResolutionParameters(eeData, mlx90641);
        ExtractKsTaParameters(eeData, mlx90641);
        ExtractKsToParameters(eeData, mlx90641);
        ExtractCPParameters(eeData, mlx90641);
        ExtractAlphaParameters(eeData, mlx90641);
        ExtractOffsetParameters(eeData, mlx90641);
        ExtractKtaPixelParameters(eeData, mlx90641);
        ExtractKvPixelParameters(eeData, mlx90641);
        error = ExtractDeviatingPixels(eeData, mlx90641);
    return error;
int MLX90641_SetResolution(uint8_t slaveAddr, uint8_t resolution)
    int value;
    int error;
    value = (resolution & 0x03) << 10;
    if(error == 0)
        value = (controlRegister1 & 0xF3FF) | value;
        error = MLX90641_I2CWrite(slaveAddr, 0x800D, value);
    return error;
int MLX90641_GetCurResolution(uint8_t slaveAddr)
    int resolutionRAM;
    int error;
    if(error != 0)
        return error;
    resolutionRAM = (controlRegister1 & 0x0C00) >> 10;
    return resolutionRAM;
int MLX90641_SetRefreshRate(uint8_t slaveAddr, uint8_t refreshRate)
    int value;
    int error;
    value = (refreshRate & 0x07)<<7;
    if(error == 0)
        value = (controlRegister1 & 0xFC7F) | value;
    return error;
int MLX90641_GetRefreshRate(uint8_t slaveAddr)
    int refreshRate;
    int error;
    if(error != 0)
        return error;
    refreshRate = (controlRegister1 & 0x0380) >> 7;
    return refreshRate;
void MLX90641_CalculateTo(uint16_t *frameData, const paramsMLX90641 *params, float emissivity, float tr, float *result)
    float vdd;
    float ta;
    float ta4;
    float tr4;
    float taTr;
    float gain;
    float irDataCP;
    float irData;
    float alphaCompensated;
    float Sx;
    float To;
    float alphaCorrR[8];
    int8_t range;
    uint16_t subPage;
    float ktaScale;
    float kvScale;
    float alphaScale;
    float kta;
    float kv;
    subPage = frameData[241];
    vdd = MLX90641_GetVdd(frameData, params);
    ta = MLX90641_GetTa(frameData, params);
    ta4 = (ta + 273.15);
    ta4 = ta4 * ta4;
    ta4 = ta4 * ta4;
    tr4 = (tr + 273.15);
    tr4 = tr4 * tr4;
    tr4 = tr4 * tr4;
    taTr = tr4 - (tr4-ta4)/emissivity;
    ktaScale = pow(2,(double)params->ktaScale);
    kvScale = pow(2,(double)params->kvScale);
    alphaScale = pow(2,(double)params->alphaScale);
    alphaCorrR[1] = 1 / (1 + params->ksTo[1] * 20);
    alphaCorrR[0] = alphaCorrR[1] / (1 + params->ksTo[0] * 20);
    alphaCorrR[2] = 1 ;
    alphaCorrR[3] = (1 + params->ksTo[2] * params->ct[3]);
    alphaCorrR[4] = alphaCorrR[3] * (1 + params->ksTo[3] * (params->ct[4] - params->ct[3]));
    alphaCorrR[5] = alphaCorrR[4] * (1 + params->ksTo[4] * (params->ct[5] - params->ct[4]));
    alphaCorrR[6] = alphaCorrR[5] * (1 + params->ksTo[5] * (params->ct[6] - params->ct[5]));
    alphaCorrR[7] = alphaCorrR[6] * (1 + params->ksTo[6] * (params->ct[7] - params->ct[6]));
//------------------------- Gain calculation -----------------------------------
    gain = frameData[202];
    if(gain > 32767)
        gain = gain - 65536;
    gain = params->gainEE / gain;
//------------------------- To calculation -------------------------------------
    irDataCP = frameData[200];
    if(irDataCP > 32767)
        irDataCP = irDataCP - 65536;
    irDataCP = irDataCP * gain;
    irDataCP = irDataCP - params->cpOffset * (1 + params->cpKta * (ta - 25)) * (1 + params->cpKv * (vdd - 3.3));
    for( int pixelNumber = 0; pixelNumber < 192; pixelNumber++)
        irData = frameData[pixelNumber];
        if(irData > 32767)
            irData = irData - 65536;
        irData = irData * gain;
        kta = (float)params->kta[pixelNumber]/ktaScale;
        kv = (float)params->kv[pixelNumber]/kvScale;
        irData = irData - params->offset[subPage][pixelNumber]*(1 + kta*(ta - 25))*(1 + kv*(vdd - 3.3));
        irData = irData - params->tgc * irDataCP;
        irData = irData / emissivity;
        alphaCompensated = SCALEALPHA*alphaScale/params->alpha[pixelNumber];
        alphaCompensated = alphaCompensated*(1 + params->KsTa * (ta - 25));
        Sx = alphaCompensated * alphaCompensated * alphaCompensated * (irData + alphaCompensated * taTr);
        Sx = sqrt(sqrt(Sx)) * params->ksTo[2];
        To = sqrt(sqrt(irData/(alphaCompensated * (1 - params->ksTo[2] * 273.15) + Sx) + taTr)) - 273.15;
        if(To < params->ct[1])
            range = 0;
        else if(To < params->ct[2])
            range = 1;
        else if(To < params->ct[3])
            range = 2;
        else if(To < params->ct[4])
            range = 3;
        else if(To < params->ct[5])
            range = 4;
        else if(To < params->ct[6])
            range = 5;
        else if(To < params->ct[7])
            range = 6;
            range = 7;
        To = sqrt(sqrt(irData / (alphaCompensated * alphaCorrR[range] * (1 + params->ksTo[range] * (To - params->ct[range]))) + taTr)) - 273.15;
        result[pixelNumber] = To;
void MLX90641_GetImage(uint16_t *frameData, const paramsMLX90641 *params, float *result)
    float vdd;
    float ta;
    float gain;
    float irDataCP;
    float irData;
    float image;
    uint16_t subPage;
    float ktaScale;
    float kvScale;
    float kta;
    float kv;
    if(gain > 32767)
//------------------------- Image calculation -------------------------------------
        if(irData > 32767)
        alphaCompensated = (params->alpha[pixelNumber] - params->tgc * params->cpAlpha);
        image = irData*alphaCompensated;
        result[pixelNumber] = image;
float MLX90641_GetVdd(uint16_t *frameData, const paramsMLX90641 *params)
    float vdd;
    float resolutionCorrection;
    int resolutionRAM;
    vdd = frameData[234];
    if(vdd > 32767)
        vdd = vdd - 65536;
    resolutionRAM = (frameData[240] & 0x0C00) >> 10;
    resolutionCorrection = pow(2, (double)params->resolutionEE) / pow(2, (double)resolutionRAM);
    vdd = (resolutionCorrection * vdd - params->vdd25) / params->kVdd + 3.3;
    return vdd;
float MLX90641_GetTa(uint16_t *frameData, const paramsMLX90641 *params)
    float ptat;
    float ptatArt;
    float vdd;
    float ta;
    ptat = frameData[224];
    if(ptat > 32767)
        ptat = ptat - 65536;
    ptatArt = frameData[192];
    if(ptatArt > 32767)
        ptatArt = ptatArt - 65536;
    ptatArt = (ptat / (ptat * params->alphaPTAT + ptatArt)) * pow(2, (double)18);
    ta = (ptatArt / (1 + params->KvPTAT * (vdd - 3.3)) - params->vPTAT25);
    ta = ta / params->KtPTAT + 25;
    return ta;
int MLX90641_GetSubPageNumber(uint16_t *frameData)
void MLX90641_BadPixelsCorrection(uint16_t pixel, float *to)
    float ap[2];
    uint8_t line;
    uint8_t column;
    if(pixel<192)
        line = pixel>>4;
        column = pixel - (line<<4);
        if(column == 0)
            to[pixel] = to[pixel+1];
        else if(column == 1 || column == 14)
            to[pixel] = (to[pixel-1]+to[pixel+1])/2.0;
        else if(column == 15)
            to[pixel] = to[pixel-1];
            ap[0] = to[pixel+1] - to[pixel+2];
            ap[1] = to[pixel-1] - to[pixel-2];
            if(fabs(ap[0]) > fabs(ap[1]))
                to[pixel] = to[pixel-1] + ap[1];
                to[pixel] = to[pixel+1] + ap[0];
    int16_t kVdd;
    int16_t vdd25;
    kVdd = eeData[39];
    if(kVdd > 1023)
        kVdd = kVdd - 2048;
    kVdd = 32 * kVdd;
    vdd25 = eeData[38];
    if(vdd25 > 1023)
        vdd25 = vdd25 - 2048;
    vdd25 = 32 * vdd25;
    mlx90641->kVdd = kVdd;
    mlx90641->vdd25 = vdd25;
    float KvPTAT;
    float KtPTAT;
    int16_t vPTAT25;
    float alphaPTAT;
    KvPTAT = eeData[43];
    if(KvPTAT > 1023)
        KvPTAT = KvPTAT - 2048;
    KvPTAT = KvPTAT/4096;
    KtPTAT = eeData[42];
    if(KtPTAT > 1023)
        KtPTAT = KtPTAT - 2048;
    KtPTAT = KtPTAT/8;
    vPTAT25 = 32 * eeData[40] + eeData[41];
    alphaPTAT = eeData[44] / 128.0f;
    mlx90641->KvPTAT = KvPTAT;
    mlx90641->KtPTAT = KtPTAT;
    mlx90641->vPTAT25 = vPTAT25;
    mlx90641->alphaPTAT = alphaPTAT;
    int16_t gainEE;
    gainEE = 32 * eeData[36] + eeData[37];
    mlx90641->gainEE = gainEE;
    float tgc;
    tgc = eeData[51] & 0x01FF;
    if(tgc > 255)
        tgc = tgc - 512;
    tgc = tgc / 64.0f;
    mlx90641->tgc = tgc;
    float emissivity;
    emissivity = eeData[35];
    if(emissivity > 1023)
        emissivity = emissivity - 2048;
    emissivity = emissivity/512;
    mlx90641->emissivityEE = emissivity;
    uint8_t resolutionEE;
    resolutionEE = (eeData[51] & 0x0600) >> 9;
    mlx90641->resolutionEE = resolutionEE;
    float KsTa;
    KsTa = eeData[34];
    if(KsTa > 1023)
        KsTa = KsTa - 2048;
    KsTa = KsTa / 32768.0f;
    mlx90641->KsTa = KsTa;
    int KsToScale;
    mlx90641->ct[0] = -40;
    mlx90641->ct[1] = -20;
    mlx90641->ct[2] = 0;
    mlx90641->ct[3] = 80;
    mlx90641->ct[4] = 120;
    mlx90641->ct[5] = eeData[58];
    mlx90641->ct[6] = eeData[60];
    mlx90641->ct[7] = eeData[62];
    KsToScale = eeData[52];
    KsToScale = 1 << KsToScale;
    mlx90641->ksTo[0] = eeData[53];
    mlx90641->ksTo[1] = eeData[54];
    mlx90641->ksTo[2] = eeData[55];
    mlx90641->ksTo[3] = eeData[56];
    mlx90641->ksTo[4] = eeData[57];
    mlx90641->ksTo[5] = eeData[59];
    mlx90641->ksTo[6] = eeData[61];
    mlx90641->ksTo[7] = eeData[63];
    for(int i = 0; i < 8; i++)
        if(mlx90641->ksTo[i] > 1023)
            mlx90641->ksTo[i] = mlx90641->ksTo[i] - 2048;
        mlx90641->ksTo[i] = mlx90641->ksTo[i] / KsToScale;
    float rowMaxAlphaNorm[6];
    uint16_t scaleRowAlpha[6];
    uint8_t alphaScale;
    float alphaTemp[192];
    float temp;
    int p = 0;
    scaleRowAlpha[0] = (eeData[25] >> 5) + 20;
    scaleRowAlpha[1] = (eeData[25] & 0x001F) + 20;
    scaleRowAlpha[2] = (eeData[26] >> 5) + 20;
    scaleRowAlpha[3] = (eeData[26] & 0x001F) + 20;
    scaleRowAlpha[4] = (eeData[27] >> 5) + 20;
    scaleRowAlpha[5] = (eeData[27] & 0x001F) + 20;
    for(int i = 0; i < 6; i++)
        rowMaxAlphaNorm[i] = eeData[28 + i] / pow(2,(double)scaleRowAlpha[i]);
        rowMaxAlphaNorm[i] = rowMaxAlphaNorm[i] / 2047.0f;
        for(int j = 0; j < 32; j ++)
            p = 32 * i +j;
            alphaTemp[p] = eeData[256 + p] * rowMaxAlphaNorm[i];
            alphaTemp[p] = alphaTemp[p] - mlx90641->tgc * mlx90641->cpAlpha;
            alphaTemp[p] = SCALEALPHA/alphaTemp[p];
    temp = alphaTemp[0];
    for(int i = 1; i < 192; i++)
        if (alphaTemp[i] > temp)
            temp = alphaTemp[i];
    alphaScale = 0;
    while(temp < 32768)
        temp = temp*2;
        alphaScale = alphaScale + 1;
    for(int i = 0; i < 192; i++)
        temp = alphaTemp[i] * pow(2,(double)alphaScale);
        mlx90641->alpha[i] = (temp + 0.5);
    mlx90641->alphaScale = alphaScale;
    int scaleOffset;
    int16_t offsetRef;
    int16_t tempOffset;
    scaleOffset = eeData[16] >> 5;
    scaleOffset = 1 << scaleOffset;
    offsetRef = 32 * eeData[17] + eeData[18];
    if (offsetRef > 32767)
        offsetRef = offsetRef - 65536;
        tempOffset = eeData[64 + i];
        if(tempOffset > 1023)
           tempOffset = eeData[64 + i] - 2048;
        mlx90641->offset[0][i] = tempOffset * scaleOffset + offsetRef;
        tempOffset = eeData[640 + i];
           tempOffset = eeData[640 + i] - 2048;
        mlx90641->offset[1][i] = tempOffset * scaleOffset + offsetRef;
    uint8_t ktaScale1;
    uint8_t ktaScale2;
    int16_t ktaAvg;
    int16_t tempKta;
    float ktaTemp[192];
    float temp;
    ktaAvg = eeData[21];
    if (ktaAvg > 1023)
        ktaAvg = ktaAvg - 2048;
    ktaScale1 = eeData[22] >> 5;
    ktaScale2 = eeData[22] & 0x001F;
        tempKta = (eeData[448 + i] >> 5);
        if (tempKta > 31)
            tempKta = tempKta - 64;
        ktaTemp[i] = tempKta * pow(2,(double)ktaScale2);
        ktaTemp[i] = ktaTemp[i] + ktaAvg;
        ktaTemp[i] = ktaTemp[i] / pow(2,(double)ktaScale1);
    temp = fabs(ktaTemp[0]);
        if (fabs(ktaTemp[i]) > temp)
            temp = fabs(ktaTemp[i]);
    ktaScale1 = 0;
    while(temp < 64)
        temp = temp*2;
        ktaScale1 = ktaScale1 + 1;
        temp = ktaTemp[i] * pow(2,(double)ktaScale1);
        if (temp < 0)
            mlx90641->kta[i] = (temp - 0.5);
            mlx90641->kta[i] = (temp + 0.5);
    mlx90641->ktaScale = ktaScale1;
    uint8_t kvScale1;
    uint8_t kvScale2;
    int16_t kvAvg;
    int16_t tempKv;
    float kvTemp[192];
    float temp;
    kvAvg = eeData[23];
    if (kvAvg > 1023)
        kvAvg = kvAvg - 2048;
    kvScale1 = eeData[24] >> 5;
    kvScale2 = eeData[24] & 0x001F;
        tempKv = (eeData[448 + i] & 0x001F);
        if (tempKv > 15)
            tempKv = tempKv - 32;
        kvTemp[i] = tempKv * pow(2,(double)kvScale2);
        kvTemp[i] = kvTemp[i] + kvAvg;
        kvTemp[i] = kvTemp[i] / pow(2,(double)kvScale1);
    temp = fabs(kvTemp[0]);
        if (fabs(kvTemp[i]) > temp)
            temp = fabs(kvTemp[i]);
    kvScale1 = 0;
    while(temp < 64)
        temp = temp*2;
        kvScale1 = kvScale1 + 1;
        temp = kvTemp[i] * pow(2,(double)kvScale1);
        if (temp < 0)
            mlx90641->kv[i] = (temp - 0.5);
            mlx90641->kv[i] = (temp + 0.5);
    mlx90641->kvScale = kvScale1;
    float alphaCP;
    int16_t offsetCP;
    float cpKv;
    float cpKta;
    uint8_t alphaScale;
    uint8_t ktaScale1;
    uint8_t kvScale;
    alphaScale = eeData[46];
    offsetCP = 32 * eeData[47] + eeData[48];
    if (offsetCP > 32767)
        offsetCP = offsetCP - 65536;
    alphaCP = eeData[45];
    if (alphaCP > 1023)
        alphaCP = alphaCP - 2048;
    alphaCP = alphaCP /  pow(2,(double)alphaScale);
    cpKta = eeData[49] & 0x003F;
    if (cpKta > 31)
        cpKta = cpKta - 64;
    ktaScale1 = eeData[49] >> 6;
    mlx90641->cpKta = cpKta / pow(2,(double)ktaScale1);
    cpKv = eeData[50] & 0x003F;
    if (cpKv > 31)
        cpKv = cpKv - 64;
    kvScale = eeData[50] >> 6;
    mlx90641->cpKv = cpKv / pow(2,(double)kvScale);
    mlx90641->cpAlpha = alphaCP;
    mlx90641->cpOffset = offsetCP;
float MLX90641_GetEmissivity(const paramsMLX90641 *mlx90641)
    return  mlx90641->emissivityEE;
    uint16_t pixCnt = 0;
    uint16_t brokenPixCnt = 0;
    int warn = 0;
    mlx90641->brokenPixel = 0xFFFF;
    pixCnt = 0;
    while (pixCnt < 192 && brokenPixCnt < 2)
        if((eeData[pixCnt+64] == 0) && (eeData[pixCnt+256] == 0) && (eeData[pixCnt+448] == 0) && (eeData[pixCnt+640] == 0))
            mlx90641->brokenPixel = pixCnt;
            brokenPixCnt = brokenPixCnt + 1;
        pixCnt = pixCnt + 1;
    if(brokenPixCnt > 1)
        warn = -3;
    return warn;
     int deviceSelect;
     deviceSelect = eeData[10] & 0x0040;
     if(deviceSelect != 0)
         return 0;
     return -7;
MLX90641_I2C_Driver.c: (where the crash happens)
#include <zephyr.h>
#include <errno.h>
#include <device.h>
#include <drivers/i2c.h>
const struct device *i2c_dev;
void MLX90641_I2CInit()
    //i2c.stop();
    i2c_dev = DEVICE_DT_GET(DT_NODELABEL(i2c0));
int MLX90641_I2CGeneralReset(void)
    int ack;
    char cmd[2] = {0,0};
    cmd[0] = 0x00;
    cmd[1] = 0x06;
    //i2c.stop();
    //wait_us(5);
    k_sleep(K_USEC(5));
    //ack = i2c.write(cmd[0], &cmd[1], 1, 0);
    ack = i2c_write(i2c_dev, &cmd[1], 1, cmd[0]);
    if (ack != 0x00)
        return -1;
    //i2c.stop();
    //wait_us(50);
    k_sleep(K_USEC(50));
    return 0;
int MLX90641_I2CRead(uint8_t slaveAddr, uint16_t startAddress, uint16_t nMemAddressRead, uint16_t *data)
    printk("slaveAddr: %d startAddress: %d nMemAddressRead: %d *data: %p\n", slaveAddr, startAddress, nMemAddressRead, data);
    //uint8_t sa;
    int ack = 0;
    int cnt = 0;
    int i = 0;
    char i2cData[1664] = {0};
    uint16_t *p;
    p = data;
    //sa = (slaveAddr << 1);
    cmd[0] = startAddress >> 8;
    cmd[1] = startAddress & 0x00FF;
    //printk("sa: %d\n", sa);
    //i2c.stop();
    //wait_us(5);
    k_sleep(K_USEC(5));
    //ack = i2c.write(sa, cmd, 2, 1);
    i2c_write(i2c_dev, cmd, 2, slaveAddr);
    if (ack != 0x00)
        return -1;
    //sa = sa | 0x01;
    //ack = i2c.read(sa, i2cData, 2*nMemAddressRead, 0);
    i2c_read(i2c_dev, i2cData, 2*nMemAddressRead, slaveAddr);
    if (ack != 0x00)
        return -1;
    //i2c.stop();
    for(cnt=0; cnt < nMemAddressRead; cnt++)
        i = cnt << 1;
        *p++ = (uint16_t)i2cData[i]*256 + (uint16_t)i2cData[i+1];   // THIS CAUSES THE CRASH
        printk("cnt: %d i: %d *p: %p\n", cnt, i, p);
        //thread_analyzer_print();
    return 0;
void MLX90641_I2CFreqSet(int freq)  // seems like this function isn't used
    //i2c.frequency(1000*freq);
int MLX90641_I2CWrite(uint8_t slaveAddr, uint16_t writeAddress, uint16_t data)
    //uint8_t sa;
    int ack = 0;
    char cmd[4] = {0,0,0,0};
    static uint16_t dataCheck;
    cmd[0] = writeAddress >> 8;
    cmd[1] = writeAddress & 0x00FF;
    cmd[2] = data >> 8;
    cmd[3] = data & 0x00FF;
    //i2c.stop();
    //wait_us(5);
    k_sleep(K_USEC(5));
    //ack = i2c.write(sa, cmd, 4, 0);
    ack = i2c_write(i2c_dev, cmd, 4, slaveAddr);
    if (ack != 0x00)
        return -1;
    //i2c.stop();
    MLX90641_I2CRead(slaveAddr,writeAddress,1, &dataCheck);
    if ( dataCheck != data)
        return -2;
    return 0;
prj.conf:
CONFIG_I2C=y
CONFIG_TINYCBOR=y
CONFIG_CBOR_FLOATING_POINT=y
CONFIG_LOG=y
CONFIG_LOG2_MODE_IMMEDIATE=y
#CONFIG_MAIN_STACK_SIZE=2048
#CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048
#CONFIG_IDLE_STACK_SIZE=1024
#CONFIG_THREAD_ANALYZER=y
#CONFIG_THREAD_ANALYZER_USE_PRINTK=y
The I2C itself seems to work fine writing and reading, but then when the read data is copied from a char array in the I2C function (1664 length) into a uint16_t array in main() (832 length) I always get the same crash, when the pointer to the uint16_t reaches address 0x20001b60. Using printk and addr2line I traced the problem to line 86 in MLX90641_I2C_Driver.c, where the data is copied inside a for loop.
When I try setting CONFIG_MAIN_STACK_SIZE=2048, I instead get a "Bus Fault" before the program even prints anything. The crash address is traced to the zephyr uart_console.c line 94.
I then removed the stack size config and tried using the Thread Analyzer, which causes a bus fault traced to the zephyr kernel thread.c line 946 and thread_analyzer.c line 84. The thread analyzer output shows the thread stacks aren't anywhere close to overflowing.
I am pretty stumped here and would greatly appreciate any help. Thanks!
  • 1) the function MLX90641_I2CRead() is called from main thread context? correct?
    2) Any difference if you set CONFIG_LOG2_MODE_IMMEDIATE=n ?
    3) Have you tried setting stack and heap to some very high numbers? e.g.
    # Stacks and heaps
    CONFIG_MAIN_STACK_SIZE=16384
    CONFIG_HEAP_MEM_POOL_SIZE=16384
  • CONFIG_MAIN_STACK_SIZE=16384
    This did the job, 8192 is enough and anything below that crashes. So weird because I tried increasing to 2048 and 4096 initially and both caused the program to crash earlier than with 1024 so I never tried increasing it more.
    One last question, if main stack size was the culprit, why did the thread analyzer say that main stack was only at 28% usage when the crashes were happening?
    Great!
    I assume that there was a sudden peak in the stack usage, this caused the crash, and that the thread analyzer did not have time to register or report this increase before the crash.
