time.h
unable to use time.h file
i have used:
#include time.h in main.c
added time.h file from C:\Keil_v5\ARM\ARMCC\include\time.h
when i use
time_t T = time(NULL);
srand(T);
but it throw error
.\_build\nrf52832_xxaa.axf: Error: L6218E: Undefined symbol time (referred from main.o).
    Most likely you get this error because the project is configured to use Microlib, see this thread. Note that there is no time available in the chip by default, the default implementation of time() uses semihosting, which means that the function may not work as expected when run standalone on the chip.
    If you are only looking at using time to seed the srand() function, you can use the RNG peripheral to generate a random number instead. If you need time/calendar in your application, please have a look at the nrf5-calendar example instead.
    Jørgen
  • Jorgen i have to generate a random timer.
    pls assist me with some code tht i can use to put a unifrom random delay value before  the time i hve use din line 353
     * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_app_template_main main.c
     * @ingroup ble_sdk_app_template
     * @brief Template project main file.
     * This file contains a template for creating a new application. It has the code necessary to wakeup
     * from button, advertise, get a connection restart advertising on disconnect and if no new
     * connection created go back to system-off mode.
     * It can easily be used as a starting point for creating a new application, the comments identified
     * with 'YOUR_JOB' indicates where and how you can customize.
    #include <stdbool.h>
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "app_timer.h"
    #include "fds.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "bsp_btn_ble.h"
    #include "sensorsim.h"
    #include "ble_conn_state.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    #include "bsp.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_drv_twi.h"
    #include "sht4x.h"
    #include "lis3dh.h"
    #include "nrf_gpio.h"
    #include "ble_bas.h"
    #include "battery_voltage.h"
    //const uint8_t device_name_arr[2]        = {'N', 2};
    //#define DEVICE_NAME                     device_name_arr//"Nordic_Template"      /**< Name of device. Will be included in the advertising data. */
    //#define MANUFACTURER_NAME               "NordicSemiconductor"                   /**< Manufacturer. Will be passed to Device Information Service. */
    #define APP_ADV_INTERVAL                 32 //80 = 50ms //300 karna hae                  /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
    //#define APP_ADV_DURATION                40 //200 = 2s//1800 50, 300 ,20 karna hae                 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define ADV_INTERVAL                    APP_TIMER_TICKS(1000*30)                /**< Interval after which device will send notification (in milli seconds). */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.1 seconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.2 second). */
    #define SLAVE_LATENCY                   0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define SEC_PARAM_BOND                  1                                       /**< Perform bonding. */
    #define SEC_PARAM_MITM                  0                                       /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC                  0                                       /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS              0                                       /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
    #define SEC_PARAM_OOB                   0                                       /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE          7                                       /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE          16                                      /**< Maximum encryption key size. */
    #define APP_BEACON_INFO_LENGTH						 0x1B   //packet size= 27 Bytes
    #define SENSOR_TYPE2                       0x02
    #define WORKING_COND                       0x01
    #define SENSOR_TYPE1                       0x01
    #define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define ACC_VDD                         20
    #define TEMP_VDD                        28
    #define ACC_SDO                         19
    static uint32_t button_tick = 0;
    BLE_BAS_DEF(m_bas);
    NRF_BLE_QWR_DEF(m_qwr);
    static ble_gap_adv_params_t m_adv_params;
    static uint8_t              m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
    //APP_TIMER_DEF(m_adv_timer_id);                                         /**< timer to send notification. */
    uint8_t  battery_level;
    int v_g_battery;
    #define TOP_INDEX                       152
    uint8_t num_packets= TOP_INDEX;
    #define BT0_LONG_PUSH  BSP_EVENT_KEY_0
    APP_TIMER_DEF(m_repeated_timer_id);
    APP_TIMER_DEF(motion_sensor_timer_id);
    APP_TIMER_DEF(sensor_timer_id);
    APP_TIMER_DEF(m_battery_timer_id);
    uint8_t battery=100;
    uint8_t data_to_advertise[27];
    //SHT40 variable
    float temp;
    float hum;
    int16_t temp1,hum1;
    int flag=0;                    // variable to count two readings
    int g_sleep_flag=1;
    uint8_t flag1=0;
    extern int acc_working_condition;
    uint8_t temp_working_condition=0;
    int16_t tmp_int16[3] = {0};
    static int Motion_index=0;
    static uint8_t              m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];
    static ble_gap_adv_data_t m_adv_data =
        .adv_data =
            .p_data = m_enc_advdata,
            .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
        .scan_rsp_data =
            .p_data = NULL,
            .len    = 0
    #define ADV_DATA_UPDATE_INTERVAL        APP_TIMER_TICKS(20)     //(25)              //5000 karna hae  - 120000       500
    #define ADV_DATA_UPDATE                 APP_TIMER_TICKS(10000)                      //supposed to be 60000*4
    #define Motion_Data_Update              APP_TIMER_TICKS(100)
    #define BATTERY_DATA_UPDATE             APP_TIMER_TICKS(10)
    #define UNIFORM                         APP_TIMER_TICKS(100)
    static const nrf_drv_twi_t i2c1_instance = NRF_DRV_TWI_INSTANCE(0);
    static const nrf_drv_twi_t  m_twi = NRF_DRV_TWI_INSTANCE(1);
    //#define PAYLOAD_SIZE                    1
    #define APP_COMPANY_IDENTIFIER          0x0059                                   /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
    typedef struct
    uint8_t x_msb;
    uint8_t x_lsb;
    uint8_t y_msb;
    uint8_t y_lsb;
    uint8_t z_msb;
    uint8_t z_lsb;
    }motion_data;
    motion_data Motion_data[600];                // structure to hold Lis3dh data 8
    uint8_t*ptr;
    //static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
    /* YOUR_JOB: Declare all services structure your application is using
     *  BLE_XYZ_DEF(m_xyz);
    // YOUR_JOB: Use UUIDs for service(s) used in your application.
    //static ble_uuid_t m_adv_uuids[] =                                               /**< Universally unique service identifiers. */
    //    {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
    static void advertising_init(void);
    static void advertising_start(void);
    void send_notification(void);
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in] line_num   Line number of the failing ASSERT call.
     * @param[in] file_name  File name of the failing ASSERT call.
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
        ret_code_t err_code;
        err_code = bsp_indication_set(BSP_INDICATE_IDLE);  //all LEDs are off
        // Prepare wakeup buttons.
        err_code = sd_app_evt_wait(); //sd_power_system_off();
    static void battery_services_init(void)
        ble_bas_init_t bas_init;
    	  memset(&bas_init, 0, sizeof(bas_init));
    		bas_init.bl_rd_sec        = SEC_OPEN;
        bas_init.bl_cccd_wr_sec   = SEC_OPEN;
        bas_init.bl_report_rd_sec = SEC_OPEN;
    		bas_init.evt_handler          = NULL;
        bas_init.support_notification = true;
        bas_init.p_report_ref         = NULL;
        bas_init.initial_batt_level   = 100;
        err_code = ble_bas_init(&m_bas, &bas_init);
    static void battery_level_update(void)
        // uint8_t  battery_level;
        uint16_t vbatt;
        battery_voltage_get(&vbatt);                                 // Get new battery voltage
    		NRF_LOG_INFO("ADC result: %d\r\n", vbatt);
        battery_level = battery_level_in_percent(vbatt);            //Transform the millivolts value into battery level percent.
        NRF_LOG_INFO("ADC result in percent: %d\r\n", battery_level);
        err_code = ble_bas_battery_level_update(&m_bas, battery_level, m_conn_handle);
    	 	NRF_LOG_INFO("ADC result: %d\r\n", battery_level);
        if(v_g_battery==1)
        if ( (err_code != NRF_SUCCESS) &&
            (err_code != NRF_ERROR_INVALID_STATE) &&
            (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            APP_ERROR_HANDLER(err_code);
    static void battery_level_meas_timeout_handler(void * p_context)
        UNUSED_PARAMETER(p_context);
        NRF_LOG_INFO("Battery Level timeout event");
        // Only send the battery level update if we are connected
      //   if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
    		     battery_level_update();
    	 error_code = app_timer_start(m_repeated_timer_id,
                                       ADV_DATA_UPDATE_INTERVAL,
                                       NULL);
      	APP_ERROR_CHECK(error_code);
    static void repeated_timer_handler(void * p_context)
    		num_packets=num_packets-1;
    	  advertising_init();
        NRF_LOG_INFO("Advertising start");
    	  NRF_LOG_INFO("Number of packets remaining %d",num_packets);
    		advertising_start();    //start advertising and blink LED1
    	  	if(num_packets==0)
    	  	Motion_index=0;
      		num_packets=TOP_INDEX;
      	  //remaining_packet=152;
          app_timer_stop(m_repeated_timer_id);
    		  ret_code_t error_code;
    			sleep_mode_enter();
          error_code = app_timer_start(sensor_timer_id,
                                        ADV_DATA_UPDATE,
                                        NULL);
          acc_working_condition=0;
    			  //after all the data has been sent, enter sleep mode, stop blinking LEDs
    static void motion_sensor_timer_handler(void *p_context)
        float LIS3DH_Acc[3];
    	  nrf_gpio_pin_set(ACC_VDD);
    	  nrf_gpio_pin_set(ACC_SDO);
    	  twi_init();
    	  LIS3DH_Init();                                  //LIS3DH Sensor Init
    	  LIS3DH_GetAccData(LIS3DH_Acc);
         tmp_int16[0] =(int16_t)( LIS3DH_Acc[0]);
    		 tmp_int16[1] =(int16_t)( LIS3DH_Acc[1]);
    		 tmp_int16[2] =(int16_t)( LIS3DH_Acc[2]);
    		 NRF_LOG_INFO(" value of temp x %d ",tmp_int16[0]);
    		 NRF_LOG_INFO(" value of temp y %d ",tmp_int16[1]);
    		 NRF_LOG_INFO(" value of temp z %d ",tmp_int16[2]);
    	  	Motion_data[flag].x_msb= (uint8_t)((tmp_int16[0] & 0xFF00)>>8);
    		  Motion_data[flag].x_lsb= (int8_t)(tmp_int16[0] & 0xFF);
    	  	Motion_data[flag].y_msb= (int8_t)((tmp_int16[1] & 0xFF00)>>8);
    		  Motion_data[flag].y_lsb= (int8_t)(tmp_int16[1] & 0xFF);
    	  	Motion_data[flag].z_msb= (int8_t)((tmp_int16[2] & 0xFF00)>>8);
    	  	Motion_data[flag].z_lsb= (int8_t)(tmp_int16[2] & 0xFF);
    	//	 NRF_LOG_INFO(" value of x msb %d ",Motion_data[flag].x_msb);
    	//	 NRF_LOG_INFO(" value of x lsb %d ",Motion_data[flag].x_lsb);
    	//	 NRF_LOG_INFO(" value of y msb %d ",Motion_data[flag].y_msb);
    	//	 NRF_LOG_INFO(" value of y lsb %d ",Motion_data[flag].y_lsb);
      //   NRF_LOG_INFO(" value of z msb %d ",Motion_data[flag].z_msb);
    	//	 NRF_LOG_INFO(" value of z lsb %d ",Motion_data[flag].z_lsb);
    	   NRF_LOG_INFO(" value of flag %d ",flag);
    	 	 ++flag;
    	   nrf_drv_twi_disable(&m_twi);          // disable twi
    	   nrf_drv_twi_uninit(&m_twi);
    	   if(flag==600)
    	     flag=0;
    		   app_timer_stop(motion_sensor_timer_id);
           error_code = app_timer_start(m_battery_timer_id,
                                        BATTERY_DATA_UPDATE,
                                        NULL);
           nrf_gpio_pin_clear(ACC_VDD);
           nrf_gpio_pin_clear(ACC_SDO);
    static void sensor_timer_handler(void *p_context)
    	     nrf_gpio_pin_set(TEMP_VDD);
         	 sensirion_i2c_init();
    			 while (sht4x_probe() != STATUS_OK)
    						NRF_LOG_INFO("SHT sensor probing failed\n");
    						nrf_delay_ms(200);
            NRF_LOG_INFO("SHT sensor probing successful\n");
            int32_t temperature, humidity;
            /* Measure temperature and relative humidity and store into variables
             * temperature, humidity (each output multiplied by 1000).
            int8_t ret = sht4x_measure_blocking_read(&temperature, &humidity);
            if (ret == STATUS_OK)
    						 NRF_LOG_INFO("measured temperature: %3.2f degreeCelsius,"
    													"measured humidity: %3.2f percentRH\n",temperature / 1000.0f, humidity / 1000.0f);
    													 temp =temperature / 1000.0f;
    													 hum =humidity / 1000.0f;
                               temp_working_condition=1;
    						NRF_LOG_INFO("temp=%f,hum=%f",temp,hum);
    						NRF_LOG_INFO("error reading measurement\n");
    			 		// disable and uninitialize twi
    		    nrf_drv_twi_disable(&i2c1_instance);
    		    nrf_drv_twi_uninit(&i2c1_instance);
    			  temp1=temp*100;
    			  hum1=hum*100;
    	      nrf_gpio_pin_clear(TEMP_VDD);
            error_code = app_timer_start(motion_sensor_timer_id, Motion_Data_Update, NULL);
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void timers_init(void)
        // Initialize timer module.
        // Create timers.
    //		 // Timer to start/stop sending notification
    //		err_code = app_timer_create(&m_adv_timer_id, APP_TIMER_MODE_REPEATED, adv_timeout_handler);
    //    APP_ERROR_CHECK(err_code);
    	   // advertising
    	  err_code = app_timer_create(&m_repeated_timer_id,
                                    repeated_timer_handler);
    	  // temp sensor
    	  err_code = app_timer_create(&sensor_timer_id,
                                    APP_TIMER_MODE_SINGLE_SHOT,
                                    sensor_timer_handler);
    	  // motion sensor
    	  err_code = app_timer_create(&motion_sensor_timer_id,
                                    motion_sensor_timer_handler);
    		err_code = app_timer_create(&m_battery_timer_id,
                                    battery_level_meas_timeout_handler);
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
    		ble_gap_addr_t          m_adv_addr;
    	//SETTING CUSTOM RANDOM STATIC DEVICE ADDRESS (6 bytes)
    		m_adv_addr.addr_type = BLE_GAP_ADDR_TYPE_RANDOM_STATIC; //address type
    		m_adv_addr.addr[0] = 0xfd;
    		m_adv_addr.addr[1] = 0x71;
    		m_adv_addr.addr[2] = 0x5f;
    		m_adv_addr.addr[3] = 0x45;
    		m_adv_addr.addr[4] = 0x2b;
    		m_adv_addr.addr[5] = 0xC6; // 2MSB must be set 11
    		sd_ble_gap_addr_set(&m_adv_addr);
    /**@brief Function for starting timers.
    static void application_timers_start(void)
                                        ADV_DATA_UPDATE,
                                        NULL);
        ret_code_t err_code = NRF_SUCCESS;
                NRF_LOG_INFO("Disconnected.");
    				     v_g_battery=0;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected.");
    				     v_g_battery=1;
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    		uint32_t      err_code;
        ble_advdata_t advdata;
    		static uint8_t payload_index = 0;
    		//num_packets=num_packets-1;    //when the first packet is sent, number of packets remaining reduces to TOP_INDEX-1
    	uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =                    /**< Information advertised by the Beacon. */
    			num_packets,
    			SENSOR_TYPE1,
    			temp_working_condition,
    		 (uint8_t)((temp1 & 0xFF00) >> 8),
    			(uint8_t)(temp1 & 0xFF),
    			battery_level,
    	// Manufacturing data
    		ble_advdata_manuf_data_t 						    manuf_data; //Variable to hold manufacturer specific data
        manuf_data.company_identifier           = 0x0059; //Nordics company ID
    		if(num_packets>=TOP_INDEX-2)    //when the first two packets have been sent, we start advertising accelerometer data
    			manuf_data.data.p_data                  = (uint8_t *) m_beacon_info;
    			ptr=&Motion_data[Motion_index].x_msb;
    			uint8_t m_beacon_info1[APP_BEACON_INFO_LENGTH] =                    /**< accelerometer data advertised by the Beacon. */
    					num_packets,
    					SENSOR_TYPE2,
    					acc_working_condition,
    					*ptr,
    					*(ptr+1),
    					*(ptr+2),
    					*(ptr+3),
    					*(ptr+4),
    					*(ptr+5),
    					*(ptr+6),
    					*(ptr+7),
    					*(ptr+8),
    					*(ptr+9),
    					*(ptr+10),
    					*(ptr+11),
    					*(ptr+12),
    					*(ptr+13),
    					*(ptr+14),
    					*(ptr+15),
    					*(ptr+16),
    					*(ptr+17),
    					*(ptr+18),
    					*(ptr+19),
    					*(ptr+20),
    					*(ptr+21),
    					*(ptr+22),
    					*(ptr+23),
    				Motion_index=Motion_index+4;
    		manuf_data.data.p_data                  = (uint8_t *) m_beacon_info1;
    		manuf_data.data.size                    = APP_BEACON_INFO_LENGTH;
    		memset(&advdata, 0, sizeof(advdata));
        advdata.name_type             = BLE_ADVDATA_NO_NAME;
        advdata.p_manuf_specific_data = &manuf_data;
        memset(&m_adv_params, 0, sizeof(m_adv_params));
    	  m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED; //Beacon needs to be scannable to receive scan response
        m_adv_params.p_peer_addr     = NULL;    // Undirected advertisement.
        m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
    		m_adv_params.interval        = APP_ADV_INTERVAL;
    		//m_adv_params.duration        = APP_ADV_DURATION;
    		m_adv_params.max_adv_evts    = 1;
    		//m_adv_params.channel_mask[4] = 0xC0;   //use only channel-37 for advertising
        err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
    		//Configure the advertising set- the data that you wish to send, and the parameters that you wish to use.
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
    static void log_init(void)
    /**@brief Function for initializing LEDs.
    static void leds_init(void)
        ret_code_t err_code = bsp_init(BSP_INIT_LEDS, NULL);
    static void bsp_event_handler(bsp_event_t event)
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
                break; // BSP_EVENT_SLEEP
            case BT0_LONG_PUSH:                    // BSP_EVENT_KEY_0
    				      NRF_LOG_INFO("Button is pressed.");
                  g_sleep_flag=0;
    static void buttons_leds_init(void)
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    		err_code = bsp_event_to_button_action_assign(BSP_BOARD_BUTTON_0,  BSP_BUTTON_ACTION_RELEASE , BT0_LONG_PUSH); //add release action trigger on the button. call BSP_EVENT_KEY_2 event  BSP_BUTTON_ACTION_RELEASE
            nrf_pwr_mgmt_run();
    		err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);  //start advertising
    static void setting_pin()
       NRF_LOG_INFO("Setting pin 28,19 and 20 as output");
    	 nrf_gpio_cfg_output(TEMP_VDD);
    	 nrf_gpio_cfg_output(ACC_VDD);
    	 nrf_gpio_cfg_output(ACC_SDO);
    void sleepmode()
    						bsp_wakeup_button_disable(BSP_BOARD_BUTTON_1);
    						bsp_wakeup_button_disable(BSP_BOARD_BUTTON_2);
    						bsp_wakeup_button_disable(BSP_BOARD_BUTTON_3);
    						bsp_wakeup_button_enable(BSP_BOARD_BUTTON_0);
    						bsp_indication_set(BSP_INDICATE_USER_STATE_0);
    						nrf_delay_ms(50);
    						bsp_indication_set(BSP_INDICATE_USER_STATE_OFF);
    						NRF_LOG_INFO("Going to sleep.\r\n");
    						nrf_delay_ms(100);
    						// Enter system OFF. After wakeup the chip will be reset, and code execution will run from the top
    						NRF_POWER->SYSTEMOFF = 1;
    /**@brief Function for application main entry.
        bool erase_bonds;
        // Initialize.
        log_init();
        timers_init();
    		//leds_init();
        buttons_leds_init();
    		battery_voltage_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
       // gatt_init();
    		setting_pin();
        battery_services_init();
        //peer_manager_init();
        // Start execution.
        NRF_LOG_INFO("Template example started.");
          	while(bsp_button_is_pressed(BSP_BOARD_BUTTON_0) == true)
    				if (button_tick >= 65534*100)
    					button_tick = 0;
    					NRF_LOG_INFO("BeforeFivesec");
    					g_sleep_flag = 0;
    			  button_tick++;
    		while(g_sleep_flag)
    		 // sd_power_system_off();
    			  sleepmode();
    		application_timers_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
  • I already explained you why time() is not working.
    You can get a random number from the RNG peripheral and pass this to srand() instead of the output from time().
  • i am asking how to use this srand() because srand() requires time.h file usage
  • srand() does not require use of time.h. srand() takes a seed argument, which can be any unsigned int number. time(0) is popularly used as seed to the function, as it in many cases generates a "random enough" number to give a random sequence of numbers from the pseudo-random function rand(). See the description of the srand() function on cplusplus.com.
    I'm trying to tell you that you can use a random number from the RNG peripheral to pass as the seed to srand(), instead of the output from time(0).
