I want to add a random delay in range 2000 to 3000 ms before my device perfrom any activity.
pls tell how can do this at earliest
usins some timer or something else
Please stop updating the thread if you do not get an answer within minutes.
When you input a thread on this forum, we assume that you read through the responses, evaluate what you should do, and provide a bit more effort to try to solve your own scenario. A response like this two minutes after I have given you advice:
Ridhi said:can u pls change that i my shred code ,i am realyy finding it bit difficult
Indicates no question, nor any effort from your side to explain what you want to do, nor what you want to achieve.
It is very clear that you are new to C programming, and I would strongly recommend that you read up on this matter and get a bit more experience within the field of embedded programming.
Håkon
Hakon i had put this query only after i had tried a few things:
1). actually earlier i had put rando delay like:
nrf_delay_ms((rand()% 3000) + 2000);
i then tested this and was able to get the required delay. I had an issue that random delay using nrf delay resulted in very high current of 6mA.
2). Then i studied and found tht timer method is another feasible way..
I tried :
err_code = app_timer_start(instance, APP_TIMER_TICKS((rand() % 1000) + 2000), NULL);
but this also did not help.
3). i refrred ways that:
RNG peripheral,
crypto random method
and soft device method
i am some how unable to integrate the hndler thing of soft device.thats why i am asking help from you.
Ridhi said:rand()
This is a stdlib function (unless you manually defined this function), which is implemented based on what your linked in standard libc (Keil's libc in your case) actually implements. In embedded applications, such functions are seldom targeting the actual hardware RNG unless you provide hooks into it.
This is why you have to use the RNG, or the API that the softdevice exposes, which is the sd_rand_* API.
As mentioned earlier, it is very crucial that you query this API after the BLE stack is initialized:
Håkon Alseth said:For the sd_rand_* API to provide you with random bytes, you need to call this after the softdevice has been initialized (ie. after ble_stack_init()).
I would recommend that you enter debug mode and see if the sd_rand_* API calls succeeds and if the input variable is populated with random numbers, then implement the rest step-by-step.
Ridhi said:I had an issue that random delay using nrf delay resulted in very high current of 6mA.
This is because nrf_delay uses the CPU for waiting, by essentially counting down from a very large number until it reaches 0.
Ridhi said:err_code = app_timer_start(instance, APP_TIMER_TICKS((rand() % 1000) + 2000), NULL);
When implemented with a function that returns a random number, this starts the timer and you will get an interrupt after between 2-3 seconds. You must add logic inside the timer_handler that you set for the specific "instance", as well as the waiting logic in your main-loop, something like this:
start_my_apptimer();
while(my_timer_flag == false) {
// reset the flag set in the timer_handler
my_timer_flag = false;
idle_state_handle();
/* continue execution */
Håkon
Hello, i have rectified the random delay. actually i had placed the timer at wrong place.
it works both with i am sharing the codes:
1). rand()
* Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_app_template_main main.c
* @ingroup ble_sdk_app_template
* @brief Template project main file.
* This file contains a template for creating a new application. It has the code necessary to wakeup
* from button, advertise, get a connection restart advertising on disconnect and if no new
* connection created go back to system-off mode.
* It can easily be used as a starting point for creating a new application, the comments identified
* with 'YOUR_JOB' indicates where and how you can customize.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include <stdlib.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "fds.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "bsp_btn_ble.h"
#include "sensorsim.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "bsp.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_twi.h"
#include "sht4x.h"
#include "lis3dh.h"
#include "nrf_gpio.h"
#include "ble_bas.h"
#include "battery_voltage.h"
//#include "nrf_drv_rng.h"
//const uint8_t device_name_arr[2] = {'N', 2};
//#define DEVICE_NAME device_name_arr//"Nordic_Template" /**< Name of device. Will be included in the advertising data. */
//#define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL 32 //80 = 50ms //300 karna hae /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
//#define APP_ADV_DURATION 40 //200 = 2s//1800 50, 300 ,20 karna hae /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define ADV_INTERVAL APP_TIMER_TICKS(1000*30) /**< Interval after which device will send notification (in milli seconds). */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.1 seconds). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.2 second). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define APP_BEACON_INFO_LENGTH 0x1B //packet size= 27 Bytes
#define SENSOR_TYPE2 0x02
#define WORKING_COND 0x01
#define SENSOR_TYPE1 0x01
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define ACC_VDD 20
#define TEMP_VDD 28
#define ACC_SDO 19
static uint32_t button_tick = 0;
BLE_BAS_DEF(m_bas);
NRF_BLE_QWR_DEF(m_qwr);
static ble_gap_adv_params_t m_adv_params;
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
//APP_TIMER_DEF(m_adv_timer_id); /**< timer to send notification. */
uint8_t battery_level;
int v_g_battery;
#define TOP_INDEX 152
uint8_t num_packets= TOP_INDEX;
#define BT0_LONG_PUSH BSP_EVENT_KEY_0
APP_TIMER_DEF(m_repeated_timer_id);
APP_TIMER_DEF(motion_sensor_timer_id);
APP_TIMER_DEF(sensor_timer_id);
APP_TIMER_DEF(m_battery_timer_id);
APP_TIMER_DEF(m_my_timer_instance);
uint8_t battery=100;
uint8_t data_to_advertise[27];
//SHT40 variable
float temp;
float hum;
int16_t temp1,hum1;
int flag=0; // variable to count two readings
int g_sleep_flag=1;
uint8_t flag1=0;
extern int acc_working_condition;
uint8_t temp_working_condition=0;
int16_t tmp_int16[3] = {0};
static int Motion_index=0;
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];
static ble_gap_adv_data_t m_adv_data =
.adv_data =
.p_data = m_enc_advdata,
.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX
.scan_rsp_data =
.p_data = NULL,
.len = 0
#define ADV_DATA_UPDATE_INTERVAL APP_TIMER_TICKS(20) //(25) //5000 karna hae - 120000 500
#define ADV_DATA_UPDATE APP_TIMER_TICKS(10000) //supposed to be 60000*4
#define Motion_Data_Update APP_TIMER_TICKS(100)
#define BATTERY_DATA_UPDATE APP_TIMER_TICKS(10)
#define UNIFORM APP_TIMER_TICKS(100)
static const nrf_drv_twi_t i2c1_instance = NRF_DRV_TWI_INSTANCE(0);
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(1);
//#define PAYLOAD_SIZE 1
#define APP_COMPANY_IDENTIFIER 0x0059 /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
typedef struct
uint8_t x_msb;
uint8_t x_lsb;
uint8_t y_msb;
uint8_t y_lsb;
uint8_t z_msb;
uint8_t z_lsb;
}motion_data;
motion_data Motion_data[600]; // structure to hold Lis3dh data 8
uint8_t*ptr;
//static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
/* YOUR_JOB: Declare all services structure your application is using
* BLE_XYZ_DEF(m_xyz);
// YOUR_JOB: Use UUIDs for service(s) used in your application.
//static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */
// {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
uint16_t rand_value;
uint8_t bytes_available = 0;
static void advertising_init(void);
static void advertising_start(void);
void send_notification(void);
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
ret_code_t err_code;
err_code = bsp_indication_set(BSP_INDICATE_IDLE); //all LEDs are off
// Prepare wakeup buttons.
err_code = sd_app_evt_wait(); //sd_power_system_off();
int x;
static void timeout_handler(void * p_context)
ret_code_t error_code;
error_code = app_timer_start(m_repeated_timer_id,
ADV_DATA_UPDATE_INTERVAL,
NULL);
APP_ERROR_CHECK(error_code);
//x= rand()%10000;
//NRF_LOG_INFO("ADC result: %d\r\n", x);
// NRF_LOG_INFO("random num: %d\r\n", x);
// ret_code_t err_code;
// err_code = sd_rand_application_bytes_available_get(&bytes_available);
//if (bytes_available >= sizeof(rand_value))
// err_code = sd_rand_application_vector_get((uint8_t *)&rand_value, sizeof(rand_value));
// APP_ERROR_CHECK(err_code);
//} else {
// /* implement your error handling if no rand bytes available */
static void battery_services_init(void)
ble_bas_init_t bas_init;
memset(&bas_init, 0, sizeof(bas_init));
bas_init.bl_rd_sec = SEC_OPEN;
bas_init.bl_cccd_wr_sec = SEC_OPEN;
bas_init.bl_report_rd_sec = SEC_OPEN;
bas_init.evt_handler = NULL;
bas_init.support_notification = true;
bas_init.p_report_ref = NULL;
bas_init.initial_batt_level = 100;
err_code = ble_bas_init(&m_bas, &bas_init);
static void battery_level_update(void)
// uint8_t battery_level;
uint16_t vbatt;
battery_voltage_get(&vbatt); // Get new battery voltage
NRF_LOG_INFO("ADC result: %d\r\n", vbatt);
battery_level = battery_level_in_percent(vbatt); //Transform the millivolts value into battery level percent.
NRF_LOG_INFO("ADC result in percent: %d\r\n", battery_level);
err_code = ble_bas_battery_level_update(&m_bas, battery_level, m_conn_handle);
NRF_LOG_INFO("ADC result: %d\r\n", battery_level);
if(v_g_battery==1)
if ( (err_code != NRF_SUCCESS) &&
(err_code != NRF_ERROR_INVALID_STATE) &&
(err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
APP_ERROR_HANDLER(err_code);
static void battery_level_meas_timeout_handler(void * p_context)
UNUSED_PARAMETER(p_context);
NRF_LOG_INFO("Battery Level timeout event");
// Only send the battery level update if we are connected
// if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
battery_level_update();
//uint16_t rand_value;
//uint8_t bytes_available = 0;
//(void)sd_rand_application_bytes_available_get(&bytes_available);
//} else {
//err_code = app_timer_start(m_my_timer_instance, APP_TIMER_TICKS((rand_value % 1000) + 2000), NULL);
// nrf_delay_ms(2000); //constnt delay
//nrf_delay_ms(rand()% 100); //100ms delay
//nrf_delay_ms(rand()% 60000); // 1 min delay
// time_t T = time(NULL);
// srand(T); //different sequence
// nrf_delay_ms((rand()% 3000) + 2000); //uniform random delay
x= rand();
NRF_LOG_INFO("Random %d", x);
err_code = app_timer_start(m_my_timer_instance, APP_TIMER_TICKS(x), NULL);
static void repeated_timer_handler(void * p_context)
num_packets=num_packets-1;
advertising_init();
NRF_LOG_INFO("Advertising start");
NRF_LOG_INFO("Number of packets remaining %d",num_packets);
advertising_start(); //start advertising and blink LED1
if(num_packets==0)
Motion_index=0;
num_packets=TOP_INDEX;
//remaining_packet=152;
app_timer_stop(m_repeated_timer_id);
sleep_mode_enter();
error_code = app_timer_start(sensor_timer_id,
ADV_DATA_UPDATE,
NULL);
acc_working_condition=0;
//after all the data has been sent, enter sleep mode, stop blinking LEDs
static void motion_sensor_timer_handler(void *p_context)
float LIS3DH_Acc[3];
nrf_gpio_pin_set(ACC_VDD);
nrf_gpio_pin_set(ACC_SDO);
twi_init();
LIS3DH_Init(); //LIS3DH Sensor Init
LIS3DH_GetAccData(LIS3DH_Acc);
tmp_int16[0] =(int16_t)( LIS3DH_Acc[0]);
tmp_int16[1] =(int16_t)( LIS3DH_Acc[1]);
tmp_int16[2] =(int16_t)( LIS3DH_Acc[2]);
NRF_LOG_INFO(" value of temp x %d ",tmp_int16[0]);
NRF_LOG_INFO(" value of temp y %d ",tmp_int16[1]);
NRF_LOG_INFO(" value of temp z %d ",tmp_int16[2]);
Motion_data[flag].x_msb= (uint8_t)((tmp_int16[0] & 0xFF00)>>8);
Motion_data[flag].x_lsb= (int8_t)(tmp_int16[0] & 0xFF);
Motion_data[flag].y_msb= (int8_t)((tmp_int16[1] & 0xFF00)>>8);
Motion_data[flag].y_lsb= (int8_t)(tmp_int16[1] & 0xFF);
Motion_data[flag].z_msb= (int8_t)((tmp_int16[2] & 0xFF00)>>8);
Motion_data[flag].z_lsb= (int8_t)(tmp_int16[2] & 0xFF);
// NRF_LOG_INFO(" value of x msb %d ",Motion_data[flag].x_msb);
// NRF_LOG_INFO(" value of x lsb %d ",Motion_data[flag].x_lsb);
// NRF_LOG_INFO(" value of y msb %d ",Motion_data[flag].y_msb);
// NRF_LOG_INFO(" value of y lsb %d ",Motion_data[flag].y_lsb);
// NRF_LOG_INFO(" value of z msb %d ",Motion_data[flag].z_msb);
// NRF_LOG_INFO(" value of z lsb %d ",Motion_data[flag].z_lsb);
NRF_LOG_INFO(" value of flag %d ",flag);
++flag;
nrf_drv_twi_disable(&m_twi); // disable twi
nrf_drv_twi_uninit(&m_twi);
if(flag==600)
flag=0;
app_timer_stop(motion_sensor_timer_id);
error_code = app_timer_start(m_battery_timer_id,
BATTERY_DATA_UPDATE,
NULL);
nrf_gpio_pin_clear(ACC_VDD);
nrf_gpio_pin_clear(ACC_SDO);
static void sensor_timer_handler(void *p_context)
nrf_gpio_pin_set(TEMP_VDD);
sensirion_i2c_init();
while (sht4x_probe() != STATUS_OK)
NRF_LOG_INFO("SHT sensor probing failed\n");
nrf_delay_ms(200);
NRF_LOG_INFO("SHT sensor probing successful\n");
int32_t temperature, humidity;
/* Measure temperature and relative humidity and store into variables
* temperature, humidity (each output multiplied by 1000).
int8_t ret = sht4x_measure_blocking_read(&temperature, &humidity);
if (ret == STATUS_OK)
NRF_LOG_INFO("measured temperature: %3.2f degreeCelsius,"
"measured humidity: %3.2f percentRH\n",temperature / 1000.0f, humidity / 1000.0f);
temp =temperature / 1000.0f;
hum =humidity / 1000.0f;
temp_working_condition=1;
NRF_LOG_INFO("temp=%f,hum=%f",temp,hum);
NRF_LOG_INFO("error reading measurement\n");
// disable and uninitialize twi
nrf_drv_twi_disable(&i2c1_instance);
nrf_drv_twi_uninit(&i2c1_instance);
temp1=temp*100;
hum1=hum*100;
nrf_gpio_pin_clear(TEMP_VDD);
error_code = app_timer_start(motion_sensor_timer_id, Motion_Data_Update, NULL);
/**@brief Function for the Timer initialization.
* @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
// Initialize timer module.
// Create timers.
// // Timer to start/stop sending notification
// err_code = app_timer_create(&m_adv_timer_id, APP_TIMER_MODE_REPEATED, adv_timeout_handler);
// advertising
err_code = app_timer_create(&m_repeated_timer_id,
repeated_timer_handler);
// temp sensor
err_code = app_timer_create(&sensor_timer_id,
APP_TIMER_MODE_SINGLE_SHOT,
sensor_timer_handler);
// motion sensor
err_code = app_timer_create(&motion_sensor_timer_id,
motion_sensor_timer_handler);
err_code = app_timer_create(&m_battery_timer_id,
battery_level_meas_timeout_handler);
err_code = app_timer_create(&m_my_timer_instance,
timeout_handler);
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
ble_gap_addr_t m_adv_addr;
//SETTING CUSTOM RANDOM STATIC DEVICE ADDRESS (6 bytes)
m_adv_addr.addr_type = BLE_GAP_ADDR_TYPE_RANDOM_STATIC; //address type
m_adv_addr.addr[0] = 0xfd;
m_adv_addr.addr[1] = 0x71;
m_adv_addr.addr[2] = 0x5f;
m_adv_addr.addr[3] = 0x45;
m_adv_addr.addr[4] = 0x2b;
m_adv_addr.addr[5] = 0xC6; // 2MSB must be set 11
sd_ble_gap_addr_set(&m_adv_addr);
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
/**@brief Function for starting timers.
static void application_timers_start(void)
ADV_DATA_UPDATE,
NULL);
ret_code_t err_code = NRF_SUCCESS;
NRF_LOG_INFO("Disconnected.");
v_g_battery=0;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected.");
v_g_battery=1;
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
// No implementation needed.
uint32_t ram_start = 0;
// Enable BLE stack.
uint32_t err_code;
ble_advdata_t advdata;
static uint8_t payload_index = 0;
//num_packets=num_packets-1; //when the first packet is sent, number of packets remaining reduces to TOP_INDEX-1
uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] = /**< Information advertised by the Beacon. */
num_packets,
SENSOR_TYPE1,
temp_working_condition,
(uint8_t)((temp1 & 0xFF00) >> 8),
(uint8_t)(temp1 & 0xFF),
battery_level,
// Manufacturing data
ble_advdata_manuf_data_t manuf_data; //Variable to hold manufacturer specific data
manuf_data.company_identifier = 0x0059; //Nordics company ID
if(num_packets>=TOP_INDEX-2) //when the first two packets have been sent, we start advertising accelerometer data
manuf_data.data.p_data = (uint8_t *) m_beacon_info;
ptr=&Motion_data[Motion_index].x_msb;
uint8_t m_beacon_info1[APP_BEACON_INFO_LENGTH] = /**< accelerometer data advertised by the Beacon. */
num_packets,
SENSOR_TYPE2,
acc_working_condition,
*ptr,
*(ptr+1),
*(ptr+2),
*(ptr+3),
*(ptr+4),
*(ptr+5),
*(ptr+6),
*(ptr+7),
*(ptr+8),
*(ptr+9),
*(ptr+10),
*(ptr+11),
*(ptr+12),
*(ptr+13),
*(ptr+14),
*(ptr+15),
*(ptr+16),
*(ptr+17),
*(ptr+18),
*(ptr+19),
*(ptr+20),
*(ptr+21),
*(ptr+22),
*(ptr+23),
Motion_index=Motion_index+4;
manuf_data.data.p_data = (uint8_t *) m_beacon_info1;
manuf_data.data.size = APP_BEACON_INFO_LENGTH;
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_NO_NAME;
advdata.p_manuf_specific_data = &manuf_data;
memset(&m_adv_params, 0, sizeof(m_adv_params));
m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED; //Beacon needs to be scannable to receive scan response
m_adv_params.p_peer_addr = NULL; // Undirected advertisement.
m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
m_adv_params.interval = APP_ADV_INTERVAL;
//m_adv_params.duration = APP_ADV_DURATION;
m_adv_params.max_adv_evts = 1;
//m_adv_params.channel_mask[4] = 0xC0; //use only channel-37 for advertising
err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
//Configure the advertising set- the data that you wish to send, and the parameters that you wish to use.
err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
static void log_init(void)
/**@brief Function for initializing LEDs.
static void leds_init(void)
ret_code_t err_code = bsp_init(BSP_INIT_LEDS, NULL);
static void bsp_event_handler(bsp_event_t event)
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
break; // BSP_EVENT_SLEEP
case BT0_LONG_PUSH: // BSP_EVENT_KEY_0
NRF_LOG_INFO("Button is pressed.");
g_sleep_flag=0;
static void buttons_leds_init(void)
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
err_code = bsp_event_to_button_action_assign(BSP_BOARD_BUTTON_0, BSP_BUTTON_ACTION_RELEASE , BT0_LONG_PUSH); //add release action trigger on the button. call BSP_EVENT_KEY_2 event BSP_BUTTON_ACTION_RELEASE
nrf_pwr_mgmt_run();
err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG); //start advertising
static void setting_pin()
NRF_LOG_INFO("Setting pin 28,19 and 20 as output");
nrf_gpio_cfg_output(TEMP_VDD);
nrf_gpio_cfg_output(ACC_VDD);
nrf_gpio_cfg_output(ACC_SDO);
void sleepmode()
bsp_wakeup_button_disable(BSP_BOARD_BUTTON_1);
bsp_wakeup_button_disable(BSP_BOARD_BUTTON_2);
bsp_wakeup_button_disable(BSP_BOARD_BUTTON_3);
bsp_wakeup_button_enable(BSP_BOARD_BUTTON_0);
bsp_indication_set(BSP_INDICATE_USER_STATE_0);
nrf_delay_ms(50);
bsp_indication_set(BSP_INDICATE_USER_STATE_OFF);
NRF_LOG_INFO("Going to sleep.\r\n");
nrf_delay_ms(100);
// Enter system OFF. After wakeup the chip will be reset, and code execution will run from the top
NRF_POWER->SYSTEMOFF = 1;
/**@brief Function for application main entry.
bool erase_bonds;
// Initialize.
log_init();
timers_init();
//leds_init();
buttons_leds_init();
battery_voltage_init();
power_management_init();
ble_stack_init();
gap_params_init();
// gatt_init();
setting_pin();
battery_services_init();
//peer_manager_init();
// Start execution.
NRF_LOG_INFO("Template example started.");
while(bsp_button_is_pressed(BSP_BOARD_BUTTON_0) == true)
if (button_tick >= 65534*100)
button_tick = 0;
NRF_LOG_INFO("BeforeFivesec");
g_sleep_flag = 0;
button_tick++;
while(g_sleep_flag)
// sd_power_system_off();
sleepmode();
application_timers_start();
// Enter main loop.
for (;;)
2). sd_rand_* API
/** @file
#include <stdint.h>
#include <string.h>
#include <stdlib.h>
#include "nrf.h"
#include "ble.h"
#include "fds.h"
#include "bsp.h"
#include "sht4x.h"
#include "lis3dh.h"
#define ACC_VDD 20
#define TEMP_VDD 28
#define ACC_SDO 19
BLE_BAS_DEF(m_bas);
int v_g_battery;
//SHT40 variable
float temp;
float hum;
int16_t temp1,hum1;
int g_sleep_flag=1;
uint8_t flag1=0;
.adv_data =
.scan_rsp_data =
.p_data = NULL,
.len = 0
typedef struct
uint8_t x_msb;
uint8_t x_lsb;
uint8_t y_msb;
uint8_t y_lsb;
uint8_t z_msb;
uint8_t z_lsb;
}motion_data;
uint8_t*ptr;
int x;
NULL);
//x= rand()%10000;
//} else {
uint16_t vbatt;
if(v_g_battery==1)
} else {
// x= rand()% 1000;
// NRF_LOG_INFO("Random: %d", x);
// err_code = app_timer_start(m_my_timer_instance, APP_TIMER_TICKS(x), NULL);
advertising_init();
if(num_packets==0)
Motion_index=0;
sleep_mode_enter();
ADV_DATA_UPDATE,
NULL);
twi_init();
++flag;
if(flag==600)
flag=0;
NULL);
nrf_delay_ms(200);
temp1=temp*100;
hum1=hum*100;
// Create timers.
// advertising
// temp sensor
// motion sensor
timeout_handler);
ADV_DATA_UPDATE,
NULL);
v_g_battery=0;
v_g_battery=1;
} break;
uint32_t err_code;
num_packets,
SENSOR_TYPE1,
battery_level,
num_packets,
SENSOR_TYPE2,
*ptr,
*(ptr+1),
*(ptr+2),
*(ptr+3),
*(ptr+4),
*(ptr+5),
*(ptr+6),
*(ptr+7),
*(ptr+8),
*(ptr+9),
*(ptr+10),
*(ptr+11),
*(ptr+12),
*(ptr+13),
*(ptr+14),
*(ptr+15),
*(ptr+16),
*(ptr+17),
*(ptr+18),
*(ptr+19),
*(ptr+20),
*(ptr+21),
*(ptr+22),
*(ptr+23),
switch (event)
sleep_mode_enter();
g_sleep_flag=0;
nrf_pwr_mgmt_run();
void sleepmode()
nrf_delay_ms(50);
nrf_delay_ms(100);
bool erase_bonds;
// Initialize.
log_init();
timers_init();
//leds_init();
ble_stack_init();
gap_params_init();
// gatt_init();
setting_pin();
// Start execution.
button_tick = 0;
g_sleep_flag = 0;
button_tick++;
while(g_sleep_flag)
sleepmode();
// Enter main loop.
for (;;)
i have an issue tht
a).i want to add a guassian delay also how can i do that?
b). i am able to generate random delay with sd_rand_application_vector_get() by the logic u have shared but can u pls share the basic understndg of these funtions in simple manner with a basic logic example. as in nordic infocenter i am unable to understnd there working
Ridhi said:a).i want to add a guassian delay also how can i do that?
as mentioned, you can select your range, via the modulo operation, and add a offset. If you need more than that, you'll have to figure out that on your own.
Ridhi said:b). i am able to generate random delay with sd_rand_application_vector_get() by the logic u have shared but can u pls share the basic understndg of these funtions in simple manner with a basic logic example. as in nordic infocenter i am unable to understnd there working
You can have a look at the RNG peripheral in the PS, its essentially a small wrapper on top of that peripheral.
There's a random number pool inside the softdevice, since it requires random numbers for the bluetooth stack, and it shares this pool with the application, so that it can also query for random numbers.
Håkon
