FIRST_CONN_PARAMS_UPDATE_DELAY error
I crated a custom peripheral for my application, I took the code from the Blinky example and i changed the service.
I set the FIRST_CONN_PARAMS_UPDATE_DELAY parameter like this :
#define FIRST_CONN_PARAMS_UPDATE_DELAY	APP_TIMER_TICKS(20000)					/**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (20 seconds). */
And the MIN_CONN_INTERVAL and MIN_CONN_INTERVAL like this :
#define MIN_CONN_INTERVAL				MSEC_TO_UNITS(200, UNIT_1_25_MS)			/**< Minimum acceptable connection interval (100 = 100 ms). */
#define MAX_CONN_INTERVAL				MSEC_TO_UNITS(300, UNIT_1_25_MS)		/**< Maximum acceptable connection interval (300 = 300 ms). */
After 20s i Expect the Conn interval to be around 300ms afer 20s in order to save power, unfortunately after 20s the code crash and i have no idea where, i put logs to where i belive is the crash but i don't see anything.
				NRF_LOG_INFO("BLE_GAP_EVT_PHY_UPDATE_REQUEST");
				ble_gap_phys_t const phys =
					.rx_phys = BLE_GAP_PHY_AUTO,
					.tx_phys = BLE_GAP_PHY_AUTO,
			} break;
    ret_code_t err_code;
				NRF_LOG_INFO("ble conn params failed");
        err_code = sd_ble_gap_disconnect(p_evt->conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE);
        //APP_ERROR_CHECK(err_code);
			NRF_LOG_INFO("BLE_CONN_PARAMS_EVT_SUCCESS");
I tried with those parameters :
#define MIN_CONN_INTERVAL				MSEC_TO_UNITS(200, UNIT_1_25_MS)			/**< Minimum acceptable connection interval (8 = 100 ms). */
#define MAX_CONN_INTERVAL				MSEC_TO_UNITS(300, UNIT_1_25_MS)		/**< Maximum acceptable connection interval (150 = 200 ms). */
And it works fine but i don't belive there is an PHY update.
On the other hand the bliky example works fine.
What did i do wrong ? For the central i used NRF connect on my phone and with the PC connected to a dev bloard.
Thank you
  • Hello, while cleaning the project and leaving just the BLE part everything if working fine... i'll reassemble everything step by step to see what I did wrong. I'll keep you posted, thank you again for all your help
    I found the issue :
    When i change the clock to use the external cristal i cqn't change the connection interval parameters :
    here is my configuration
    // <e> NRFX_CLOCK_ENABLED - nrfx_clock - CLOCK peripheral driver
    #ifndef NRFX_CLOCK_ENABLED
    #define NRFX_CLOCK_ENABLED 1
    // <o> NRFX_CLOCK_CONFIG_LF_SRC  - LF Clock Source
    // <0=> RC
    // <1=> XTAL
    // <2=> Synth
    // <131073=> External Low Swing
    // <196609=> External Full Swing
    #ifndef NRFX_CLOCK_CONFIG_LF_SRC
    #define NRFX_CLOCK_CONFIG_LF_SRC 0
    // <o> NRFX_CLOCK_CONFIG_IRQ_PRIORITY  - Interrupt priority
    // <0=> 0 (highest)
    // <1=> 1
    // <2=> 2
    // <3=> 3
    // <4=> 4
    // <5=> 5
    // <6=> 6
    // <7=> 7
    #ifndef NRFX_CLOCK_CONFIG_IRQ_PRIORITY
    #define NRFX_CLOCK_CONFIG_IRQ_PRIORITY 6
    // <e> NRF_CLOCK_ENABLED - nrf_drv_clock - CLOCK peripheral driver - legacy layer
    #ifndef NRF_CLOCK_ENABLED
    #define NRF_CLOCK_ENABLED 1
    // <o> CLOCK_CONFIG_LF_SRC  - LF Clock Source
    // <0=> RC
    // <1=> XTAL
    // <2=> Synth
    #ifndef CLOCK_CONFIG_LF_SRC
    #define CLOCK_CONFIG_LF_SRC 0
    // <q> CLOCK_CONFIG_LF_CAL_ENABLED  - Calibration enable for LF Clock Source
    #ifndef CLOCK_CONFIG_LF_CAL_ENABLED
    #define CLOCK_CONFIG_LF_CAL_ENABLED 0
    // <o> CLOCK_CONFIG_IRQ_PRIORITY  - Interrupt priority
    // <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
    // <0=> 0 (highest)
    // <1=> 1
    // <2=> 2
    // <3=> 3
    // <4=> 4
    // <5=> 5
    // <6=> 6
    // <7=> 7
    #ifndef CLOCK_CONFIG_IRQ_PRIORITY
    #define CLOCK_CONFIG_IRQ_PRIORITY 6
    // </e>
    // <h> Clock - SoftDevice clock configuration
    // <o> NRF_SDH_CLOCK_LF_SRC  - SoftDevice clock source.
    // <0=> NRF_CLOCK_LF_SRC_RC
    // <1=> NRF_CLOCK_LF_SRC_XTAL
    // <2=> NRF_CLOCK_LF_SRC_SYNTH
    #ifndef NRF_SDH_CLOCK_LF_SRC
    #define NRF_SDH_CLOCK_LF_SRC 0
    // <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval.
    #ifndef NRF_SDH_CLOCK_LF_RC_CTIV
    #define NRF_SDH_CLOCK_LF_RC_CTIV 32
    // <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature.
    // <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated
    // <i>  if the temperature has not changed.
    #ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
    // <o> NRF_SDH_CLOCK_LF_ACCURACY  - External clock accuracy used in the LL to compute timing.
    // <0=> NRF_CLOCK_LF_ACCURACY_250_PPM
    // <1=> NRF_CLOCK_LF_ACCURACY_500_PPM
    // <2=> NRF_CLOCK_LF_ACCURACY_150_PPM
    // <3=> NRF_CLOCK_LF_ACCURACY_100_PPM
    // <4=> NRF_CLOCK_LF_ACCURACY_75_PPM
    // <5=> NRF_CLOCK_LF_ACCURACY_50_PPM
    // <6=> NRF_CLOCK_LF_ACCURACY_30_PPM
    // <7=> NRF_CLOCK_LF_ACCURACY_20_PPM
    // <8=> NRF_CLOCK_LF_ACCURACY_10_PPM
    // <9=> NRF_CLOCK_LF_ACCURACY_5_PPM
    // <10=> NRF_CLOCK_LF_ACCURACY_2_PPM
    // <11=> NRF_CLOCK_LF_ACCURACY_1_PPM
    #ifndef NRF_SDH_CLOCK_LF_ACCURACY
    #define NRF_SDH_CLOCK_LF_ACCURACY 1
    // </h>
    Maybe this messes up the softdevice and it reaches some kind of timeout
    I can't see how this could be related to the original issue. Did you get the same hardfault in send_update_request() when you selected the crystal oscillator?
    And please note that NRF_SDH_CLOCK_LF_RC_CTIV should be equal or less than 16 when using the RC oscillator. Otherwise, the +/-500 ppm clock stability is not guaranteed.
  • Hello, i changed the NRF_SDH_CLOCK_LF_RC_CTIV 16 and on my custom hardware i still hardfault on send_update_request() but if I select the XTAL on the demo board it works fine. unfortunately i only have a external quartz on my hardware
  • conn_interval_clean.rar
    I sent you the modified BLE project with the error
