FIRST_CONN_PARAMS_UPDATE_DELAY error
I crated a custom peripheral for my application, I took the code from the Blinky example and i changed the service.
I set the FIRST_CONN_PARAMS_UPDATE_DELAY parameter like this :
#define FIRST_CONN_PARAMS_UPDATE_DELAY	APP_TIMER_TICKS(20000)					/**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (20 seconds). */
And the MIN_CONN_INTERVAL and MIN_CONN_INTERVAL like this :
#define MIN_CONN_INTERVAL				MSEC_TO_UNITS(200, UNIT_1_25_MS)			/**< Minimum acceptable connection interval (100 = 100 ms). */
#define MAX_CONN_INTERVAL				MSEC_TO_UNITS(300, UNIT_1_25_MS)		/**< Maximum acceptable connection interval (300 = 300 ms). */
After 20s i Expect the Conn interval to be around 300ms afer 20s in order to save power, unfortunately after 20s the code crash and i have no idea where, i put logs to where i belive is the crash but i don't see anything.
				NRF_LOG_INFO("BLE_GAP_EVT_PHY_UPDATE_REQUEST");
				ble_gap_phys_t const phys =
					.rx_phys = BLE_GAP_PHY_AUTO,
					.tx_phys = BLE_GAP_PHY_AUTO,
			} break;
    ret_code_t err_code;
				NRF_LOG_INFO("ble conn params failed");
        err_code = sd_ble_gap_disconnect(p_evt->conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE);
        //APP_ERROR_CHECK(err_code);
			NRF_LOG_INFO("BLE_CONN_PARAMS_EVT_SUCCESS");
I tried with those parameters :
#define MIN_CONN_INTERVAL				MSEC_TO_UNITS(200, UNIT_1_25_MS)			/**< Minimum acceptable connection interval (8 = 100 ms). */
#define MAX_CONN_INTERVAL				MSEC_TO_UNITS(300, UNIT_1_25_MS)		/**< Maximum acceptable connection interval (150 = 200 ms). */
And it works fine but i don't belive there is an PHY update.
On the other hand the bliky example works fine.
What did i do wrong ? For the central i used NRF connect on my phone and with the PC connected to a dev bloard.
Thank you
  • I really don't understand, i added the breakpoint here :
    it never reaches the breakpoint
    I can see the output below :
    And unfortunately the Watch doesn't work
    I start to think the best solution is to restart everything from scratch...
  • I don't think that breakpoint is reachable as it is placed on the line above the 'return'. And  update_timeout_handler() is invoked 20 seconds after the connection is established.
    Are you able to share your project so I can debug it here?
  • Unfortunately I am not allowed to share the code.
    I tried again with the breakpoint on the return line it acts the same.
    I also tried to change the MIN_CONN_INTERVAL to 7 or 9 it only works with this parameter : MSEC_TO_UNITS(8, UNIT_1_25_MS) everything else fail.
    I can change the MAX_CONN_INTERVAL as i like.
    I'll try to modify the Blinky example step by step to see what I did wrong.
    But it's still entering the hardfault handler after 20 seconds?
    I only need a minimal example that allows me to reproduce the problem. I can make this ticket private if it helps.
  • Ok i clean up the project and i give it to you by the end of the week.
    Thank you for helping :)
