Step 5 of the Matter instructions at developer.nordicsemi.com/.../python_chip_controller_building.html
Shows getting the discriminator data. What is shown looks like the output of some command that was entered via the shell command.
I do have access to the Zephry shell on the matter light switch demo client and I do see output to the shell showing Matter is running with some of the "I:" and "D:" output lines but I don't see how to get it to spit out the diagnostic data that is shown in step 5.
Am I missing something? How to get that output?
Step 5: Commission the Matter accessory device over Bluetooth LE
The controller uses a 12-bit value called discriminator to discern between multiple commissionable device advertisements, as well as a 27-bit setup PIN code to authenticate the device. You can find these values in the logging terminal of the device (for example, UART). For example:
I: 254 [DL]Device Configuration: I: 257 [DL] Serial Number: TEST_SN I: 260 [DL] Vendor Id: 9050 (0x235A) I: 263 [DL] Product Id: 20043 (0x4E4B) I: 267 [DL] Hardware Version: 1 I: 270 [DL] Setup Pin Code: 20202021 I: 273 [DL] Setup Discriminator: 3840 (0xF00) I: 278 [DL] Manufacturing Date: (not set) I: 281 [DL] Device Type: 65535 (0xFFFF)
