ncs gpiote interrupt issue
Using the SDK 17 library, i had the following code running fine:
	//Setup the external interupt and timer interupt
	//Pin Interupt setup
    nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
    in_config.sense = NRF_GPIOTE_POLARITY_HITOLO;
    in_config.pull = NRF_GPIO_PIN_PULLUP;
    //in_config.hi_accuracy = true;
    err_code = nrf_drv_gpiote_in_init(IO_NET_RX, &in_config, NET_INTERRUPT);
    nrfx_gpiote_in_event_enable(IO_NET_RX, true);
    static void NET_INTERRUPT(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
        nrf_drv_timer_clear(&NET_TIMER);
    	nrf_drv_timer_disable(&NET_TIMER);
    	nrf_drv_gpiote_in_event_disable(IO_NET_RX);
Now i am porting it to ncs 1.9.0, i have changed the code to:
	// ** IN NCS THIS SEEMS TO ALREADY BE INITIALISED
	if (!nrfx_gpiote_is_init()){
    	err_code = nrfx_gpiote_init(2);
		if (err_code != NRFX_SUCCESS) {
			printk("Failed to init gpiote (err %d)\n", err_code);
			return;
    nrfx_gpiote_in_config_t in_config = NRFX_GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
    err_code = nrfx_gpiote_in_init(IO_NET_RX, &in_config, NET_INTERRUPT);
		printk("Failed to init gpiote in (err %d)\n", err_code);
		return;
Upon running, i get the following zephr error:
(sorry, copy/paste doesnt seem to work from the nrf terminal)
Any pointers to what has not been setup correctly?
many thanks
    Here's a simple example on how to use it, based on hello_world:
     * Copyright (c) 2012-2014 Wind River Systems, Inc.
    #include <zephyr.h>
    #include <sys/printk.h>
    #include <hal/nrf_gpio.h>
    #include <nrfx_gpiote.h>
    #define IO_NET_RX 13
    #define LED_0 17
    static void NET_INTERRUPT(nrfx_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
    	nrf_gpio_pin_toggle(LED_0);
    void main(void)
    	printk("Hello World! %s\n", CONFIG_BOARD);
    	nrf_gpio_cfg_output(LED_0);
    	uint32_t err_code;
    			return;
    		return;
    Here's my prj.conf:
    CONFIG_GPIO=y
    CONFIG_NRFX_GPIOTE=y
    # Comment in this if you get mpu/stack faults on the uart
    # CONFIG_MAIN_STACK_SIZE=4096
    Could you check if this works on your end?
    Håkon
  • Hi Håkon,
    Thanks for your reply
    After testing further, i found its actually a timer which is causing the problem, i also have the following code:
    static void NET_TIMER_INTERRUPT(nrf_timer_event_t event_type, void* p_context)
    	nrf_gpio_pin_toggle(IO_NET_DGB);
    const nrfx_timer_t NET_TIMER = NRFX_TIMER_INSTANCE(2);
    #define NET_SILENCE_POWER_DETECT_US	(8000ul)
    static uint32_t NET_SILENCE_POWER_DETECT;
    void init(void)
    	//Timer setup
    	nrfx_timer_config_t timer_cfg = NRFX_TIMER_DEFAULT_CONFIG;
        timer_cfg.mode = NRF_TIMER_MODE_TIMER;
        timer_cfg.frequency = NRF_TIMER_FREQ_8MHz;
        timer_cfg.interrupt_priority = 3;
        err_code = nrfx_timer_init(&NET_TIMER, &timer_cfg, NET_TIMER_INTERRUPT);
    		printk("Failed to init timer (err %d)\n", err_code);
    		return;
    	//Reset the timer
    	nrfx_timer_clear(&NET_TIMER);
    	//Syncronise the start of the next packet
    	NET_SILENCE_POWER_DETECT = nrfx_timer_us_to_ticks(&NET_TIMER, NET_SILENCE_POWER_DETECT_US);
    	nrfx_timer_extended_compare(&NET_TIMER, NRF_TIMER_CC_CHANNEL0, (NET_SILENCE_POWER_DETECT/4), NRF_TIMER_SHORT_COMPARE0_STOP_MASK, true);
    	//Enable Timer + External Interupt
    	nrfx_timer_enable(&NET_TIMER);
    This is the code causing the interrupt exception, the gpiote is working fine
    my prj.conf contains
    CONFIG_NRFX_TIMER2=y
    Again, this code seems fine under the SDK 17
    Regards
    Billy
  • Mapping the handler using the following:
    IRQ_CONNECT(DT_IRQN(DT_NODELABEL(timer2)),
    		    DT_IRQ(DT_NODELABEL(timer2), priority),
    		    nrfx_isr, nrfx_timer_2_irq_handler, 0);
    seems to have stopped the exceptions, but i dont seem to get the interrupt
    With the IRQ handler mapped, I get a single interrupt on the NET_TIMER_INTERRUPT, as the timer short is set to this:
    Change it to:
    NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK
    And it will run continuously.
    Did you remember to configure IO_NET_DBG pin as an output?
    Håkon
  • Yes,
    missed that - thanks
