I've been building nRF52840 applications from the command line using the zephyr RTOS for a while, but having taken delivery of the Thingy:91, am unable to get the hello_world sample to build.
https://docs.zephyrproject.org/latest/samples/hello_world/README.html
I'd be surprised if the Thingy:91 was not supported by the zephyrr RTOS, which boards are listed as follows:
https://docs.zephyrproject.org/latest/boards/index.html#boards
Which supported board target do I use as the west build target to build the hello_world sample?
The following build target (nrf9160dk_nrf52840) is clearly wrong (or is it? It throws an error when executing this command):
west build -p auto -b nrf9160dk_nrf52840 samples/hello_world
Does anyone know the correct build target to use - or if the above west CLI command is poorly constructed, know the correct one to use?
The build output from the above command is attached on the CommandLineBuild.txt file below.
Thanks!
(base) developer@Developers-Mini zephyr % west build -p auto -b nrf9160dk_nrf52840 samples/hello_world -- west build: generating a build system Including boilerplate (Zephyr base (cached)): /Users/developer/zephyrproject/zephyr/cmake/app/boilerplate.cmake -- Application: /Users/developer/zephyrproject/zephyr/samples/hello_world -- Zephyr version: 3.0.0-rc3 (/Users/developer/zephyrproject/zephyr) -- Found west (found suitable version "0.12.0", minimum required is "0.7.1") -- Board: nrf9160dk_nrf52840, Revision: 0.7.0 -- Cache files will be written to: /Users/developer/Library/Caches/zephyr -- Found dtc: /opt/homebrew/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6") -- Found toolchain: gnuarmemb (/Users/developer/source/zephyr/gnuarmemb/gcc-arm-none-eabi-10.3-2021.10) -- Found BOARD.dts: /Users/developer/zephyrproject/zephyr/boards/arm/nrf9160dk_nrf52840/nrf9160dk_nrf52840.dts -- Generated zephyr.dts: /Users/developer/zephyrproject/zephyr/build/zephyr/zephyr.dts -- Generated devicetree_unfixed.h: /Users/developer/zephyrproject/zephyr/build/zephyr/include/generated/devicetree_unfixed.h -- Generated device_extern.h: /Users/developer/zephyrproject/zephyr/build/zephyr/include/generated/device_extern.h -- Including generated dts.cmake file: /Users/developer/zephyrproject/zephyr/build/zephyr/dts.cmake Parsing /Users/developer/zephyrproject/zephyr/Kconfig Loaded configuration '/Users/developer/zephyrproject/zephyr/boards/arm/nrf9160dk_nrf52840/nrf9160dk_nrf52840_defconfig' Merged configuration '/Users/developer/zephyrproject/zephyr/samples/hello_world/prj.conf' warning: HAS_NORDIC_DRIVERS (defined at modules/hal_nordic/Kconfig:7) has direct dependencies 0 with value n, but is currently being y-selected by the following symbols: - SOC_SERIES_NRF52X (defined at soc/arm/nordic_nrf/nrf52/Kconfig.series:6), with value y, direct dependencies <choice> (value: y), and select condition <choice> (value: y) warning: HAS_NRFX (defined at modules/hal_nordic/nrfx/Kconfig:4) has direct dependencies 0 with value n, but is currently being y-selected by the following symbols: - SOC_SERIES_NRF52X (defined at soc/arm/nordic_nrf/nrf52/Kconfig.series:6), with value y, direct dependencies <choice> (value: y), and select condition <choice> (value: y) warning: NRFX_CLOCK (defined at modules/hal_nordic/nrfx/Kconfig:14) has direct dependencies HAS_HW_NRF_CLOCK && HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols: - CLOCK_CONTROL_NRF (defined at drivers/clock_control/Kconfig.nrf:13), with value y, direct dependencies SOC_COMPATIBLE_NRF && CLOCK_CONTROL (value: y), and select condition !CLOCK_CONTROL_NRF_FORCE_ALT && SOC_COMPATIBLE_NRF && CLOCK_CONTROL (value: y) warning: NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED (defined at modules/hal_nordic/nrfx/Kconfig:18) has direct dependencies NRFX_CLOCK && HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols: - CLOCK_CONTROL_NRF_K32SRC_XTAL (defined at drivers/clock_control/Kconfig.nrf:36), with value y, direct dependencies <choice CLOCK_CONTROL_NRF_SOURCE> (value: y), and select condition !SOC_SERIES_BSIM_NRFXX && !CLOCK_CONTROL_NRF_FORCE_ALT && <choice CLOCK_CONTROL_NRF_SOURCE> (value: y) warning: NRFX_GPIOTE (defined at modules/hal_nordic/nrfx/Kconfig:65) has direct dependencies HAS_HW_NRF_GPIOTE && HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols: - GPIO_NRFX (defined at drivers/gpio/Kconfig.nrfx:4), with value y, direct dependencies SOC_FAMILY_NRF && GPIO (value: y), and select condition SOC_FAMILY_NRF && GPIO (value: y) warning: NRFX_PPI (defined at modules/hal_nordic/nrfx/Kconfig:109, drivers/serial/Kconfig.nrfx:381) has direct dependencies (HAS_HW_NRF_PPI && HAS_NRFX && 0) || (HAS_HW_NRF_PPI && (UART_0_NRF_HW_ASYNC || UART_1_NRF_HW_ASYNC || UART_2_NRF_HW_ASYNC || UART_3_NRF_HW_ASYNC) && UART_NRFX && SERIAL) with value n, but is currently being y-selected by the following symbols: - UART_ENHANCED_POLL_OUT (defined at drivers/serial/Kconfig.nrfx:398), with value y, direct dependencies (UART_0_ENHANCED_POLL_OUT || UART_1_ENHANCED_POLL_OUT || UART_2_ENHANCED_POLL_OUT || UART_3_ENHANCED_POLL_OUT) && UART_NRFX && SERIAL (value: y), and select condition HAS_HW_NRF_PPI && (UART_0_ENHANCED_POLL_OUT || UART_1_ENHANCED_POLL_OUT || UART_2_ENHANCED_POLL_OUT || UART_3_ENHANCED_POLL_OUT) && UART_NRFX && SERIAL (value: y) error: Aborting due to Kconfig warnings CMake Error at /Users/developer/zephyrproject/zephyr/cmake/kconfig.cmake:272 (message): command failed with return code: 1 Call Stack (most recent call first): /Users/developer/zephyrproject/zephyr/cmake/app/boilerplate.cmake:543 (include) /Users/developer/zephyrproject/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include) /Users/developer/zephyrproject/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:40 (include_boilerplate) CMakeLists.txt:5 (find_package) -- Configuring incomplete, errors occurred! FATAL ERROR: command exited with status 1: /opt/homebrew/bin/cmake -DWEST_PYTHON=/opt/anaconda3/bin/python -B/Users/developer/zephyrproject/zephyr/build -S/Users/developer/zephyrproject/zephyr/samples/hello_world -GNinja -DBOARD=nrf9160dk_nrf52840
