Unable to find bootable image - MCUBoot - again
Hi again,
The previous issue is closed - but I never got any suggestions or answers to my problem.
I still have this problem - if I do a prestine build the mcuboot doesn't work - if I just touch the makefile and build again - then it works.
Below is my last entry in the original issue (https://devzone.nordicsemi.com/f/nordic-q-a/84564/unable-to-find-bootable-image---mcuboot).
Thomas
I'm trying to see what differs between the two builds, and one thing I noticed is in the build/ncs/CMakeCache.txt file.
When it fails, it more or less only differs in the following line:
mcuboot_OVERLAY_CONFIG:INTERNAL=
  /xx/vsln-ncs/vt2-overlays/vt2-mcuboot-overlay.conf
  /xx/ncs/nrf/subsys/partition_manager/partition_manager_enabled.conf
When it works it looks like this:
  ; /xx/vsln-ncs/vt2-overlays/vt2-mcuboot-overlay.conf
  /xx/ncs/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf
And the .config only differs for mcuboot as I showed in a previous entry:
$ diff build/ncs/mcuboot/zephyr/.config fail_build/ncs/mcuboot/zephyr/.config
  265,266c265,266
  < CONFIG_PARTITION_MANAGER_ENABLED=y
  < CONFIG_FLASH_MAP_CUSTOM=y
  > # CONFIG_PARTITION_MANAGER_ENABLED is not set
  > # CONFIG_FLASH_MAP_CUSTOM is not set
So, it seems as if the config somehow is not correctly setup during a prestine build. The vt2-mcuboot-overlay.conf is included twice, and the ext_flash_mcuboot_secondary is only included in the working build.
The ext_flash_mcuboot_secondary.conf is included in the CMakeFile.txt for the mcuboot, in the file ncs/nrf/modules/mcuboot/CMakeLists.txt:
  if (CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY)
    # By passing this value we don't require the user to pass any overlay files
    # to the MCUboot child image for storing the secondary partition in
    # external flash.
    add_overlay_config(
      mcuboot
      ${ZEPHYR_NRF_MODULE_DIR}/subsys/partition_manager/ext_flash_mcuboot_secondary.conf
  endif()
And CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY seems to be configured in the subsys/partition_manager/ext_flash_mcuboot_secondary.conf file, which seems odd since then we have a circular reference ... (the config is set in the file included if the config is set ...) ?
And that is the only content of the file ncs/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf:
=y
I can't see that this config is set anywhere else ...
Could that be that the MCUBOOT_SECONDARY somehow is not included in the first build, but in the second build the buildsystem gets that the MCUBOOT_SECONDARY should be included ... at least that how I interpret the CMakeCache.txt contents ... that could explain why the bootloader doesn't find the image in the first build.
Thomas
    Are you doing pristine builds in VS code? Could you try to use west build? Also, test west build with the example provided by Simon in this thread.
    Amanda
  • Hi Amanda,
    As described in the original ticket (the same thread you pointed to), I use west to build:
      $ rm -rf build
      $ west build --build-dir build/ncs src/ncs
      $ nrfjprog -f NRF52 --sectorerase --verify --program build/ncs/mcuboot/zephyr/zephyr.hex
      $ nrfjprog -f NRF52 --sectorerase --verify --program build/ncs/zephyr/app_signed.hex
      $ nrfjprog -f NRF52 --reset
    And yes, I tried the suggestion with the child_image, but it didn't help.
    Thomas
    With the hello_world_with_mcuboot_v2.zip provided by Simon, I run the command with nRF52DK as:
    west build -b nrf52dk_nrf52832 -p && west flash --recover
    And get:
    *** Booting Zephyr OS build v2.6.99-ncs1  ***
    I: Starting bootloader
    I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Boot source: none
    I: Swap type: none
    I: Bootloader chainload address offset: 0xc000
    I: Jumping to the first image slot
    ▒*** Booting Zephyr OS build v2.6.99-ncs1  ***
    Hello World! nrf52dk_nrf52832
    -Amanda
  • Hi Thomas,
    I also experience this issue with nRF SDK 1.9.1. I don't really know the reason, but it seems to me there is something wrong with CMake + west + zephyr magic build system. I noticed when I remove MCUboot overlay, the problem goes away.
    I have found a workaround. Instead of using MCUboot overlay, I am using child image. The disadvantage of this is that I have to completely duplicate MCUboot configuration since it is not merged with default.
    Steps to perform a workaround:
    1. Crete a folder in the root of your project child_images/mcuboot/
    2. Copy zephyr/bootloader/mcuboot/boot/zephyr/prj.conf to that folder
    3. Make required modifications to prj.conf according to your mcuboot-overlay.conf
    4. Delete your mcuboot-overlay.conf and reference to it from CMakeLists.txt
    Edit: I just noticed you mention child_image in on of your comments, unfortunately the link to your previous ticket does not work for me, so I can't verify if suggested workaround was the same.
    The suggestion to use child_image was found in the following issue:
    I tried the solution given there, but without any success.
    For time being, I have just updated the build-script to build two times - crude but works ...
    Cheers,
    Thomas
