nRF5340 low power on example peripheral_lbs ncs v1.6.1
Dear,
        I followed the ticket below to set peripheral_lbs for nRF5340.
but still cannot see the 8uA in power consumption.Would you help?
I also use nRF5340DK and multi-meter to measure the current in ncs v1.6.1.
https://devzone.nordicsemi.com/f/nordic-q-a/79490/nrf5340-dk-low-power-configuration-issues
  Attached my main.c and prj.conf and prj_minimal.conf.
at least I simply setup the BLE and handlers and then call:
for (;;) {
k_cpu_idle();
I am not sure whether need to add spm.conf and add add below change to the CMakeLists.txt
set(spm_CONF_FILE ${CMAKE_CURRENT_SOURCE_DIR}/spm.conf)
          I also not sure whether need to make the 3 change below:
Would you teach me how to add if need ?
1...I have added hci_rpmsg.conf in a folder in named child_image as described, copied ncs\v1.6.1\zephyr\samples\bluetooth\hci_rpmsg in and changed LOG and SERIAL to n
2.Added the following to my prj.conf
CONFIG_PM=y
CONFIG_PM_DEVICE=y
3.Disabled Uart0 and Uart1 in nrf5340dk_nrf5340_cpuappns.overlay
&uart0{
status="disabled";
&uart1{
status="disabled";
4.CONFIG_PM
void pm_power_state_set(struct pm_state_info info)
 * Copyright (c) 2018 Nordic Semiconductor ASA
#include <zephyr/types.h>
#include <stddef.h>
#include <string.h>
#include <errno.h>
#include <sys/printk.h>
#include <sys/byteorder.h>
#include <zephyr.h>
#include <drivers/gpio.h>
#include <soc.h>
#include <bluetooth/bluetooth.h>
#include <bluetooth/hci.h>
#include <bluetooth/conn.h>
#include <bluetooth/uuid.h>
#include <bluetooth/gatt.h>
#include <bluetooth/services/lbs.h>
#include <settings/settings.h>
#include <dk_buttons_and_leds.h>
#include <device.h>
#include "power/power.h"
#define DEVICE_NAME             CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN         (sizeof(DEVICE_NAME) - 1)
#define RUN_STATUS_LED          DK_LED1
#define CON_STATUS_LED          DK_LED2
#define RUN_LED_BLINK_INTERVAL  1000
#define USER_LED                DK_LED3
#define USER_BUTTON             DK_BTN1_MSK
#define BT_LE_ADV_CONN_TEST BT_LE_ADV_PARAM(BT_LE_ADV_OPT_CONNECTABLE, \
				            BT_GAP_ADV_SLOW_INT_MAX, \
				            BT_GAP_ADV_SLOW_INT_MAX, NULL)
const struct device *console, *uart1;
static bool app_button_state;
static const struct bt_data ad[] = {
	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static const struct bt_data sd[] = {
	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_LBS_VAL),
static void connected(struct bt_conn *conn, uint8_t err)
	if (err) {
		printk("Connection failed (err %u)\n", err);
		return;
	printk("Connected\n");
	dk_set_led_on(CON_STATUS_LED);
	printk("Disconnected (reason %u)\n", reason);
	dk_set_led_off(CON_STATUS_LED);
#ifdef CONFIG_BT_LBS_SECURITY_ENABLED
static void security_changed(struct bt_conn *conn, bt_security_t level,
			     enum bt_security_err err)
	if (!err) {
		printk("Security changed: %s level %u\n", addr, level);
	} else {
		printk("Security failed: %s level %u err %d\n", addr, level,
			err);
static struct bt_conn_cb conn_callbacks = {
	.connected        = connected,
	.disconnected     = disconnected,
	.security_changed = security_changed,
#if defined(CONFIG_BT_LBS_SECURITY_ENABLED)
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
	printk("Passkey for %s: %06u\n", addr, passkey);
static void auth_cancel(struct bt_conn *conn)
	printk("Pairing cancelled: %s\n", addr);
static void pairing_confirm(struct bt_conn *conn)
	bt_conn_auth_pairing_confirm(conn);
	printk("Pairing confirmed: %s\n", addr);
static void pairing_complete(struct bt_conn *conn, bool bonded)
	printk("Pairing completed: %s, bonded: %d\n", addr, bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
	printk("Pairing failed conn: %s, reason %d\n", addr, reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.passkey_display = auth_passkey_display,
	.cancel = auth_cancel,
	.pairing_confirm = pairing_confirm,
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed
#else
static struct bt_conn_auth_cb conn_auth_callbacks;
static void app_led_cb(bool led_state)
	dk_set_led(USER_LED, led_state);
static bool app_button_cb(void)
	return app_button_state;
static struct bt_lbs_cb lbs_callbacs = {
	.led_cb    = app_led_cb,
	.button_cb = app_button_cb,
static void button_changed(uint32_t button_state, uint32_t has_changed)
	if (has_changed & USER_BUTTON) {
		bt_lbs_send_button_state(button_state);
		app_button_state = button_state ? true : false;
static int init_button(void)
	int err;
	err = dk_buttons_init(button_changed);
	if (err) {
		printk("Cannot init buttons (err: %d)\n", err);
	return err;
void main(void)
        int blink_status = 0;
	int err;
	printk("Starting Bluetooth Peripheral LBS example\n");
	err = dk_leds_init();
	if (err) {
		printk("LEDs init failed (err %d)\n", err);
		return;
	err = init_button();
	if (err) {
	    printk("Button init failed (err %d)\n", err);
	    return;
	bt_conn_cb_register(&conn_callbacks);
	if (IS_ENABLED(CONFIG_BT_LBS_SECURITY_ENABLED)) {
	    bt_conn_auth_cb_register(&conn_auth_callbacks);
	err = bt_enable(NULL);
	if (err) {
		printk("Bluetooth init failed (err %d)\n", err);
		return;
	printk("Bluetooth initialized\n");
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
	err = bt_lbs_init(&lbs_callbacs);
	if (err) {
		printk("Failed to init LBS (err:%d)\n", err);
		return;
	err = bt_le_adv_start(BT_LE_ADV_CONN_TEST, ad, ARRAY_SIZE(ad),
			      sd, ARRAY_SIZE(sd));
	if (err) {
		printk("Advertising failed to start (err %d)\n", err);
		return;
	printk("Advertising successfully started\n");
	for (;;) {
		//dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
                //dk_set_led(RUN_STATUS_LED, 0);
		//k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
                k_cpu_idle();
27227.prj.conf
prj_minimal.conf
