PPK2 not present in 'Select Device' List
I have been using the PPK2 with older software (nRF connect for desktop 3.7.?) on Windows 7 64bit.
Initially all was working correctly then on the next day, the Power Profiler 'scope view' of current did not appear (all other functions appeared to work).
In this level of software the PPK2 could be selected from the 'SELECT DEVICE' window.
I was prompted to download version 3.10.0 - which I did and now I there is no PPK2 device shown in the 'SELECT DEVICE' window.
I have seen other posts where connecting TP34 to ground on power up has worked  - I have tried this and although the system re installed the USB driver for the PPK2 , this has not solved the problem.
Regards
Glyn
The data logger shows this on start up:-
13:58:23.292
Using @nordicsemiconductor/nrf-device-lib-js version: 0.4.3
13:58:23.294
Using nrf-device-lib version: 0.10.3
13:58:23.294
Using nrfjprog dll version: 10.15.1
13:58:23.295
Using JLink version: JLink_V7.58b
13:58:24.638
Application data folder: C:\Users\User\AppData\Roaming\nrfconnect\pc-nrfconnect-ppk
