SYSTEM ON mode: RAM retention RTC VS NO RAM retention RTC
void func_ram_power_off(void)
uint8_t i = 0;
for(i = 0; i < 8; i++)
NRF_POWER->RAM[i].POWERCLR = (POWER_RAM_POWER_S0POWER_Off << POWER_RAM_POWER_S0POWER_Pos) |
(POWER_RAM_POWER_S1POWER_Off << POWER_RAM_POWER_S1POWER_Pos) |
(POWER_RAM_POWER_S0RETENTION_Off << POWER_RAM_POWER_S0RETENTION_Pos) |
(POWER_RAM_POWER_S1RETENTION_Off << POWER_RAM_POWER_S1RETENTION_Pos);
* @brief Function for application main entry.
leds_config();
lfclk_config();
rtc_config();
//func_ram_power_off();
#if 0
NRF_POWER->RAMON |= (POWER_RAMON_OFFRAM0_RAM0On << POWER_RAMON_OFFRAM0_Pos) |
(POWER_RAMON_OFFRAM1_RAM1On << POWER_RAMON_OFFRAM1_Pos);
__DSB();
__NOP();
while (true)
__WFE();
when my code func_ram_power_off() enable is NO RAM retention,func_ram_power_off() disable is  RAM retention,but the power same is 1.6uA,
why?
thanks you!
  • Hi there,
    Can you use the debugger in SES and show me screenshot of the RAM[i].POWERCLR registers, as I've shown below:
    regards
    Jared
  • NRF_POWER->RAM[i].POWERCLR = (POWER_RAM_POWER_S0POWER_Off << POWER_RAM_POWER_S0POWER_Pos) |
    or
    NRF_POWER->RAM[i].POWERCLR = 0x03FF;
    the result  NRF_POWER->RAM[i].POWERCLR is 0x0000;my chip is nrf52832,i  want to kown my code is ok??
    or how to do it(RAM ON/OFF)?
    thanks you!
    RAM retention is by default OFF.
    You're mixing the correct bitfields, the ones that you're using is for the POWER register not the POWERCLR register. The correct code for testing retention off versus retention on:
    #include <stdbool.h>
    #include <stdint.h>
    #include "nrf_delay.h"
    #include "boards.h"
    //#define POWER_OFF_RETENTION_OFF
    #define POWER_ON_RETENTION_ON
    //#define POWER_ON_RETENTION_OFF
        for(int i = 0; i <= 8; i++)
          #ifdef POWER_OFF_RETENTION_OFF
          NRF_POWER->RAM[i].POWERCLR = (POWER_RAM_POWERCLR_S0POWER_Off << POWER_RAM_POWERCLR_S0POWER_Pos) |
          (POWER_RAM_POWERCLR_S1POWER_Off << POWER_RAM_POWERCLR_S1POWER_Pos) |
          (POWER_RAM_POWERCLR_S0RETENTION_Off << POWER_RAM_POWERCLR_S0RETENTION_Pos) |
          (POWER_RAM_POWERCLR_S1RETENTION_Off << POWER_RAM_POWERCLR_S1RETENTION_Pos);
          #ifdef POWER_ON_RETENTION_ON
          NRF_POWER->RAM[i].POWER = (POWER_RAM_POWER_S0POWER_On << POWER_RAM_POWER_S0POWER_Pos) |
          (POWER_RAM_POWER_S1POWER_On << POWER_RAM_POWER_S1POWER_Pos) |
          (POWER_RAM_POWER_S0RETENTION_On << POWER_RAM_POWER_S0RETENTION_Pos) |
          (POWER_RAM_POWER_S1RETENTION_On << POWER_RAM_POWER_S1RETENTION_Pos);
          #ifdef POWER_ON_RETENTION_OFF
         //Go to System Off sleep
         NRF_POWER->SYSTEMOFF = 1;
        while(true)
    best regards
    Jared
