The JLink device is detected and listed under connected Devices, but when selecting "Flash" or "Erase and flash" the "No devices connected" is shown.
Using "Debug" will program the device in debug mode as a work around, but that is inconvenient.
Attached is a screenshot showing this after pressing the "Flash" action..
Support Information:
"platform": {
"os": "win32",
"osVersion": "Windows 10 Pro",
"osKernel": "10.0.19044",
"vscode": "1.65.1",
"electron": "13.5.2",
"node": "v14.16.0"
"system": {
"date": "2022-03-10T06:24:24.225Z",
"vscodeRoot": "c:\\Users\\david\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
"vscodeUptime": "09:18:29",
"osUptime": "19:23:35",
"cpu": {
"model": "Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz",
"speed": "1992 MHz",
"count": 4
"memory": {
"total": "15.88 GB",
"free": "4.90 GB"
"workspace": {
"name": "workspace (Workspace)",
"workspaceFile": "c:\\Clients\\XXX\\Firmware\\workspace.code-workspace",
"folders": [
"c:\\Clients\\XXX\\XXXrProto\\firmware\\device100",
"c:\\Users\\david\\ncs\\v1.8.0"
"extensions": {
"internal": {
"version": "2022.3.70",
"path": "c:\\Users\\david\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2022.3.70",
"isActive": true
"version": "2022.3.16",
"path": "c:\\Users\\david\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2022.3.16",
"isActive": true
"nordic-semiconductor.devicetree": null,
"nordic-semiconductor.kconfig": null
"external": {
"marus25.cortex-debug": "1.2.2",
"ms-vscode.cpptools": "1.9.2",
"ms-vscode-remote.remote-wsl-recommender": "0.0.14",
"ms-vscode.js-debug": "1.65.0",
"ms-vscode.js-debug-companion": "1.0.15",
"ms-vscode.references-view": "0.0.85",
"ms-vscode.vscode-js-profile-table": "0.0.18",
"af4jm.vscode-m3u": "1.0.0",
"alefragnani.Bookmarks": "13.2.4",
"alefragnani.project-manager": "12.5.0",
"amazonwebservices.aws-toolkit-vscode": "1.36.0",
"cschlosser.doxdocgen": "1.4.0",
"dbaeumer.vscode-eslint": "2.2.2",
"felixfbecker.php-intellisense": "2.3.14",
"GitHub.vscode-pull-request-github": "0.38.0",
"jeff-hykin.better-cpp-syntax": "1.15.13",
"lextudio.restructuredtext": "176.0.0",
"marlinfirmware.auto-build": "2.1.37",
"ms-azuretools.vscode-docker": "1.20.0",
"ms-python.python": "2022.2.1924087327",
"ms-python.vscode-pylance": "2022.3.0",
"ms-toolsai.jupyter": "2022.2.1030672458",
"ms-toolsai.jupyter-keymap": "1.0.0",
"ms-toolsai.jupyter-renderers": "1.0.6",
"ms-vscode-remote.remote-containers": "0.224.2",
"ms-vscode-remote.remote-ssh": "0.76.1",
"ms-vscode-remote.remote-ssh-edit": "0.76.1",
"ms-vscode-remote.remote-wsl": "0.64.2",
"ms-vscode-remote.vscode-remote-extensionpack": "0.21.0",
"ms-vscode.cpptools-extension-pack": "1.1.0",
"ms-vscode.cpptools-themes": "1.0.0",
"ms-vsliveshare.vsliveshare": "1.0.5418",
"ms-vsliveshare.vsliveshare-audio": "0.1.91",
"nobuhito.printcode": "3.0.0",
"paragdiwan.gitpatch": "0.2.1",
"platformio.platformio-ide": "2.4.2",
"redhat.java": "1.4.0",
"redhat.vscode-yaml": "1.5.1",
"trond-snekvik.simple-rst": "1.5.2",
"VisualStudioExptTeam.vscodeintellicode": "1.2.17",
"vscjava.vscode-java-debug": "0.38.0",
"vscjava.vscode-java-dependency": "0.19.0",
"vscjava.vscode-java-pack": "0.22.0",
"vscjava.vscode-java-test": "0.34.2",
"vscjava.vscode-maven": "0.35.1",
"xdebug.php-debug": "1.25.0",
"xdebug.php-pack": "1.0.3",
"ZixuanWang.linkerscript": "1.0.2",
"zobo.php-intellisense": "1.0.5"
"tools": {
"C:\\Program Files\\SEGGER\\JLink\\JLink.exe": "7.62",
"C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.15.2",
"C:\\Users\\david\\AppData\\Local\\Programs\\Python\\Python36\\Scripts\\nrfutil.exe": null,
"c:\\Users\\david\\ncs\\v1.8.0\\toolchain\\opt\\bin\\cmake.exe": "3.20.5",
"c:\\Users\\david\\ncs\\v1.8.0\\toolchain\\opt\\bin\\Scripts\\west.exe": "0.12.0",
"c:\\Users\\david\\ncs\\v1.8.0\\toolchain\\opt\\bin\\python.exe": "3.8.2",
"c:\\Users\\david\\ncs\\v1.8.0\\toolchain\\opt\\bin\\ninja.exe": "1.9.0",
"c:\\Users\\david\\ncs\\v1.8.0\\toolchain\\opt\\bin\\gperf.exe": "3.1",
"c:\\Users\\david\\ncs\\v1.8.0\\toolchain\\opt\\bin\\dtc.exe": "1.4.7",
"c:\\Users\\david\\ncs\\v1.8.0\\toolchain\\opt\\bin\\arm-none-eabi-gcc.exe": "9-2019-q4-major",
"c:\\Users\\david\\ncs\\v1.8.0\\toolchain\\opt\\bin\\gn.exe": "1959",
"c:\\Users\\david\\ncs\\v1.8.0\\toolchain\\mingw64\\bin\\git.exe": "2.26.2.windows.1"
"sdks": [
"version": "1.4.0",
"path": "c:\\Users\\david\\ncs\\v1.4.0"
"version": "1.4.2",
"path": "c:\\Users\\david\\ncs\\v1.4.2"
"version": "1.4.99-dev1",
"path": "c:\\Users\\david\\ncs\\v1.4.99-dev1"
"version": "1.5.0",
"path": "c:\\Users\\david\\ncs\\v1.5.0"
"version": "1.5.1",
"path": "c:\\Users\\david\\ncs\\v1.5.1"
"version": "1.6.1",
"path": "c:\\Users\\david\\ncs\\v1.6.1"
"version": "1.7.0",
"path": "c:\\Users\\david\\ncs\\v1.7.0"
"version": "1.7.1",
"path": "c:\\Users\\david\\ncs\\v1.7.1"
"version": "1.8.0",
"path": "c:\\Users\\david\\ncs\\v1.8.0"
"version": "1.9.0",
"path": "c:\\Users\\david\\ncs\\v1.9.0"
"toolchains": [
"version": "1.4.0",
"path": "c:\\Users\\david\\ncs\\v1.4.0\\toolchain"
"version": "1.4.2",
"path": "c:\\Users\\david\\ncs\\v1.4.2\\toolchain"
"version": "1.4.0",
"path": "c:\\Users\\david\\ncs\\v1.4.99-dev1\\toolchain"
"version": "1.5.0",
"path": "c:\\Users\\david\\ncs\\v1.5.0\\toolchain"
"version": "1.5.1",
"path": "c:\\Users\\david\\ncs\\v1.5.1\\toolchain"
"version": "1.6.1",
"path": "c:\\Users\\david\\ncs\\v1.6.1\\toolchain"
"version": "1.7.0",
"path": "c:\\Users\\david\\ncs\\v1.7.0\\toolchain"
"version": "1.7.1",
"path": "c:\\Users\\david\\ncs\\v1.7.1\\toolchain"
"version": "1.8.0",
"path": "c:\\Users\\david\\ncs\\v1.8.0\\toolchain"
"version": "1.9.0",
"path": "c:\\Users\\david\\ncs\\v1.9.0\\toolchain"
"connectedDevices": [
"serialNumber": "850100615"
"deviceProviders": [
"nrfjprog"
"config": {
"topdir": "${nrf-connect.sdk:1.8.0}",
"toolchain": {
"path": "${nrf-connect.toolchain:1.8.0}"
"ozonePath": "",
"applications": [
"c:\\Clients\\XXX\\XXXProto\\firmware\\device100"
"kconfig": {
"interface": "kconfig"
"welcome": {
"showOnStartup": false
"west": {
"env": {
"$base": "terminal"
"boardRoots": [],
"enableTelemetry": false
"terminalMode": "character"
"nordic-semiconductor.devicetree": {
"modules": [
"${zephyrBase}",
"${zephyrBase}/../nrf",
"zephyr": "/cygdrive/c/Users/david/ncs/v1.8.0/zephyr",
"ctxFile": "",
"defaultBoard": "",
"west": "/cygdrive/c/Users/david/ncs/v1.8.0/toolchain/opt/bin/Scripts/west"
"nordic-semiconductor.kconfig": {
"root": "",
"env": {},
"cfiles": true,
"disable": false,
"zephyr": {
"base": "c:\\Users\\david\\ncs\\v1.7.0\\zephyr",
"west": "c:\\Users\\david\\ncs\\v1.7.0\\toolchain\\opt\\bin\\Scripts\\west.exe",
"board": {
"board": "gc_p1_nrf52840",
"arch": "arm",
"dir": "c:\\Clients\\XXX\\XXXProto\\firmware\\device100\\boards\\arm\\gc_p1_nrf52840"
"python": "",
"liveValue": true
"marus25.cortex-debug": {
"armToolchainPath": null,
"armToolchainPrefix": "arm-none-eabi",
"gdbPath": null,
"objdumpPath": null,
"JLinkGDBServerPath": null,
"openocdPath": null,
"pyocdPath": null,
"PEGDBServerPath": null,
"stutilPath": null,
"stlinkPath": null,
"stm32cubeprogrammer": null,
"enableTelemetry": true,
"flattenAnonymous": false,
"registerUseNaturalFormat": true,
"variableUseNaturalFormat": false,
"dbgServerLogfile": null,
"showDevDebugOutput": "none"
"environment": {
"westExe": "c:\\Users\\david\\ncs\\v1.8.0\\toolchain\\opt\\bin\\Scripts\\west.exe",
"westEnv": {
"ELECTRON_RUN_AS_NODE": "1",
"HOME": "C:\\SPB_Data",
"HOMEDRIVE": "C:",
"HOMEPATH": "\\Users\\david",
"Path": "c:\\Users\\david\\ncs\\v1.8.0\\toolchain\\mingw64\\bin;c:\\Users\\david\\ncs\\v1.8.0\\toolchain\\mingw64\\libexec\\git-core;c:\\Users\\david\\ncs\\v1.8.0\\toolchain\\opt\\bin;c:\\Users\\david\\ncs\\v1.8.0\\toolchain\\opt\\bin\\Scripts;C:\\Program Files (x86)\\VMware\\VMware Workstation\\bin\\;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files\\AdoptOpenJDK\\jre-11.0.10.9-openj9\\bin;C:\\Program Files\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files\\SlickEdit Pro 21.0.3\\win\\;C:\\Program Files (x86)\\Intel\\iCLS Client\\;C:\\Program Files\\Intel\\iCLS Client\\;C:\\windows\\system32;C:\\windows;C:\\windows\\System32\\Wbem;C:\\windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Program Files (x86)\\Intel\\Intel(R) Management Engine Components\\DAL;C:\\Program Files\\Intel\\Intel(R) Management Engine Components\\DAL;C:\\Program Files (x86)\\Intel\\Intel(R) Management Engine Components\\IPT;C:\\Program Files\\Intel\\Intel(R) Management Engine Components\\IPT;C:\\Program Files\\Intel\\WiFi\\bin\\;C:\\Program Files\\Common Files\\Intel\\WirelessCommon\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\STMicroelectronics\\STM32 ST-LINK Utility\\ST-LINK Utility;C:\\Program Files\\Docker\\Docker\\resources\\bin;C:\\ProgramData\\DockerDesktop\\version-bin;C:\\Program Files\\PuTTY\\;C:\\Program Files\\dotnet\\;C:\\Program Files\\nodejs\\;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\110\\Tools\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\120\\DTS\\Binn\\;C:\\Program Files (x86)\\Windows Kits\\8.1\\Windows Performance Toolkit\\;C:\\Go\\bin;C:\\Program Files (x86)\\GitExtensions\\;C:\\Program Files (x86)\\Gpg4win\\..\\GnuPG\\bin;C:\\Program Files\\Amazon\\AWSCLIV2\\;C:\\Program Files\\Amazon\\AWSSAMCLI\\bin\\;C:\\Program Files (x86)\\Bitvise SSH Client;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files (x86)\\GNU Tools Arm Embedded\\9 2019-q4-major\\bin;C:\\Users\\david\\AppData\\Local\\Programs\\Python\\Python36\\Scripts\\;C:\\Users\\david\\AppData\\Local\\Programs\\Python\\Python36\\;C:\\Users\\david\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\david\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Program Files\\Java\\jdk1.6.0_45\\bin;C:\\cygwin64\\bin;C:\\Users\\david\\AppData\\Roaming\\npm;C:\\Users\\david\\go\\bin;C:\\Program Files (x86)\\Nmap",
"ZEPHYR_BASE": "c:\\Users\\david\\ncs\\v1.8.0\\zephyr",
"GNUARMEMB_TOOLCHAIN_PATH": "c:\\Users\\david\\ncs\\v1.8.0\\toolchain\\opt",
"ZEPHYR_TOOLCHAIN_VARIANT": "gnuarmemb",
"PYTHONPATH": "c:\\Users\\david\\ncs\\v1.8.0\\toolchain\\opt\\bin;c:\\Users\\david\\ncs\\v1.8.0\\toolchain\\opt\\bin\\Lib;c:\\Users\\david\\ncs\\v1.8.0\\toolchain\\opt\\bin\\Lib\\site-packages",
"Python3_ROOT": "c:\\Users\\david\\ncs\\v1.8.0\\toolchain\\opt\\bin"
"toolchainPath": "c:\\Users\\david\\ncs\\v1.8.0\\toolchain",
"toolchainBinPath": "c:\\Users\\david\\ncs\\v1.8.0\\toolchain\\opt\\bin",
"toolchainVersion": "1.8.0"
"terminal": {
"shell": null,
"defaultProfile": null
