Hi all,
I'm trying to connect an ESP32 with an nRF52-DK (nRF52832) through I2C. I'm using the ESP32 I2C Slave example (https://www.arduino.cc/reference/en/libraries/esp32-i2c-slave/).
For the ESP32 I'm using a code based on the slave_sender.ino and the master_reader.ino for the nRF52-DK.
When I connect the ESP32 to the pins SCL(P.027) and SDA(P.026) of the nRF52-DK I don't receive anything and if (when connected) I reset the ESP32 I receive this error
rst:0x10 (RTCWDT_RTC_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT) flash read err, 1000 ets_main.c 371
the rest of the time I receive "slave not found"
The code in ESP32 is:
#include <Arduino.h>
#include <Wire.h>
#include <WireSlave.h>
#define I2C_SDA 12
#define I2C_SCL 13
#define I2C_SLAVE_ADDR 0x04
int table[] = {0, 0, 0};
void requestEvent();
void setup()
Serial.begin(115200);
WireSlave.begin(I2C_SDA, I2C_SCL, I2C_SLAVE_ADDR);
Serial.printf("Slave joined I2C bus with addr #%d\n", I2C_SLAVE_ADDR);
void loop()
int x = 120;
int y = 1200; // gets converted to an strange # because is larger than 255
int z = 3;
table[0] = x;
table[1] = y;
table[2] = z;
WireSlave.onRequest(requestEvent); // register event
// function that runs whenever the master sends an empty packet.
// this function is registered as an event, see setup().
// do not perform time-consuming tasks inside this function,
// do them elsewhere and simply read the data you wish to
// send inside here.
void requestEvent()
uint8_t Buffer[3];
Buffer[0] = table[0];
Buffer[1] = table[1];
Buffer[2] = table[2];
WireSlave.write(Buffer, 3);
In the nRF52-DK the related part of the code is:
#include "I2Cdev.h"
#include "Wire.h"
#include <WireCrc.h>
int table[] = {0, 0, 0, 0};
#define SDA_PIN 12
#define SCL_PIN 13
#define MAX_SLAVE_RESPONSE_LENGTH 64
void setup(){
Wire.begin();
void loop{
ESP32_Connect();
void ESP32_Connect(){
static unsigned long lastReadMillis = 0;
// request data from Slave every 1000 ms
if (millis() - lastReadMillis > 1000) {
// first create a WireSlaveRequest object
// first argument is the Wire bus the slave is attached to (Wire or Wire1)
WireSlaveRequest slaveReq(Wire, I2C_SLAVE_ADDR, MAX_SLAVE_RESPONSE_LENGTH);
// optional: set delay in milliseconds between retry attempts.
// the default value is 10 ms
slaveReq.setRetryDelay(5);
// attempts to read a packet from an ESP32 slave.
// there's no need to specify how many bytes are requested,
// since data is expected to be packed with WirePacker,
// and thus can have any length.
bool success = slaveReq.request(I2C_SLAVE_ADDR);
if (success) {
for (int i = 0; i < 4; i++) //organizes the data from the slave in the table
uint8_t c = slaveReq.read(); // receive a byte as character
table[i] = c;
//displays the data
Serial.print('\n');
Serial.print(table[0]);
Serial.print('\t');
Serial.print(table[1]);
Serial.print('\t');
Serial.print(table[2]);
Serial.print('\t');
Serial.print(table[3]);
Serial.print('\n');
delay (500);
else {
// if something went wrong, print the reason
Serial.println(slaveReq.lastStatusToString());
lastReadMillis = millis();
