Mesh custom reliable message reply not received
I'm trying to send a custom reliable message between two nRF52840 DKs, using the nRF5 SDK for Mesh v5.0.0 and nRF5 SDK 17.1.0, by modifying the light_switch examples.
So far i've been able to to send and receive a reliable message between the server and client, but the client keeps sending the message since it isn't receiving any acknowledged reply. I can't figure out what's wrong with my custom vendor model and would love some help.
Client main.c
/* Copyright (c) 2010 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
 * list of conditions and the following disclaimer.
#include <stdint.h>
#include <string.h>
/* HAL */
#include "boards.h"
#include "simple_hal.h"
#include "app_timer.h"
/* Core */
#include "nrf_mesh_config_core.h"
#include "nrf_mesh_gatt.h"
#include "nrf_mesh_configure.h"
#include "nrf_mesh_events.h"
#include "nrf_mesh.h"
#include "mesh_stack.h"
#include "device_state_manager.h"
#include "access_config.h"
#include "proxy.h"
/* Provisioning and configuration */
#include "mesh_provisionee.h"
#include "mesh_app_utils.h"
/* Models */
#include "generic_onoff_server.h"
#include "scene_setup_server.h"
#include "model_config_file.h"
/* Logging and RTT */
#include "log.h"
#include "rtt_input.h"
/* Example specific includes */
#include "app_config.h"
#include "example_common.h"
#include "nrf_mesh_config_examples.h"
#include "light_switch_example_common.h"
#include "app_onoff.h"
#include "ble_softdevice_support.h"
#include "app_dtt.h"
#include "app_scene.h"
/* Custom include */
#include "mesh_opt_core.h"
#include "access_reliable.h"
                 Forward declaration of static functions
                            Static variables
#define APP_FORCE_SEGMENTATION      (false)
#define APP_MIC_SIZE                (NRF_MESH_TRANSMIC_SIZE_SMALL)
#define ONOFF_SERVER_0_LED          (BSP_LED_0)
static access_model_handle_t msg_model_handle;
static bool m_device_provisioned;
                            Model definitions/callbacks
static void msg_server_reply_cb(access_model_handle_t handle, const access_message_rx_t * p_rx_msg, void * p_args)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Recieved reliable message: %02X [src: %04X, TTL: %02X]\n", p_rx_msg->p_data[0], p_rx_msg->meta_data.src.value, p_rx_msg->meta_data.ttl);
    hal_led_blink_ms(ONOFF_SERVER_0_LED, 300, 3);
    uint8_t data[] = {0xAB};
    access_message_tx_t reply_msg = {
      .opcode.opcode = p_rx_msg->opcode.opcode,
      .opcode.company_id = p_rx_msg->opcode.company_id,
      .p_buffer = &data[0],
      .length = ARRAY_SIZE(data),
      .force_segmented = false,
      .transmic_size = NRF_MESH_TRANSMIC_SIZE_SMALL,
      .access_token = nrf_mesh_unique_token_get()
    if(access_reliable_model_is_free(msg_model_handle))
      (void) access_model_reply(handle, p_rx_msg, &reply_msg);
      __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Replied with %02X\n", reply_msg.p_buffer[0]);
static void msg_server_status_cb(access_model_handle_t handle, const access_message_rx_t * p_rx_msg, void * p_args)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Recieved message: %02X [src: %04X, TTL: %02X]\n", p_rx_msg->p_data[0], p_rx_msg->meta_data.src.value, p_rx_msg->meta_data.ttl);
static const access_opcode_handler_t m_opcode_handlers[] =
    {ACCESS_OPCODE_VENDOR(0xC2, 0xF001), msg_server_reply_cb},
    {ACCESS_OPCODE_VENDOR(0xC4, 0xF001), msg_server_status_cb}
static void models_init_cb(void)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing and adding models\n");
    /*Instantiate custom models*/
    access_model_add_params_t init_params =
        .model_id = ACCESS_MODEL_VENDOR(0xC002, 0xF001),
        .element_index = 0,
        .p_opcode_handlers = &m_opcode_handlers[0],
        .opcode_count = ARRAY_SIZE(m_opcode_handlers),
        .p_args = NULL,
        .publish_timeout_cb = NULL
    ERROR_CHECK(access_model_add(&init_params, &msg_model_handle));
    ERROR_CHECK(access_model_subscription_list_alloc(msg_model_handle));
                         general application functions
static void node_reset(void)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset  -----\n");
    model_config_file_clear();
    hal_led_blink_ms(HAL_LED_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_RESET);
    /* This function may return if there are ongoing flash operations. */
    mesh_stack_device_reset();
static void config_server_evt_cb(const config_server_evt_t * p_evt)
    if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET)
        node_reset();
#if NRF_MESH_LOG_ENABLE
static const char m_usage_string[] =
    "\n"
    "\t\t-------------------------------------------------------------------------------\n"
    "\t\t Button/RTT 1) LED toggled locally.\n"
    "\t\t Button/RTT 2) -\n"
    "\t\t Button/RTT 3) -\n"
    "\t\t Button/RTT 4) Clear all the states to reset the node.\n"
    "\t\t-------------------------------------------------------------------------------\n";
static void button_event_handler(uint32_t button_number)
    /* Increase button number because the buttons on the board is marked with 1 to 4 */
    button_number++;
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
    switch (button_number)
        /* Pressing SW1 on the Development Kit will result in LED state to toggle and trigger
        the STATUS message to inform client about the state change. This is a demonstration of
        state change publication due to local event. */
        case 1:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Switch pressed locally\n");
            hal_led_pin_set(ONOFF_SERVER_0_LED, !hal_led_pin_get(ONOFF_SERVER_0_LED));
        case 2:
        case 3:
        /* Initiate node reset */
        case 4:
            /* Clear all the states to reset the node. */
            if (mesh_stack_is_device_provisioned())
#if MESH_FEATURE_GATT_PROXY_ENABLED
                (void) proxy_stop();
                mesh_stack_config_clear();
                node_reset();
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "The device is unprovisioned. Resetting has no effect.\n");
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, m_usage_string);
static void app_rtt_input_handler(int key)
    if (key >= '1' && key <= '4')
        uint32_t button_number = key - '1';
        button_event_handler(button_number);
static void device_identification_start_cb(uint8_t attention_duration_s)
    hal_led_mask_set(HAL_LED_MASK, false);
    hal_led_blink_ms(HAL_LED_MASK_HALF,
                     LED_BLINK_ATTENTION_INTERVAL_MS,
                     LED_BLINK_ATTENTION_COUNT(attention_duration_s));
static void provisioning_aborted_cb(void)
    hal_led_blink_stop();
static void unicast_address_print(void)
    dsm_local_unicast_address_t node_address;
    dsm_local_unicast_addresses_get(&node_address);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Node Address: 0x%04x \n", node_address.address_start);
static void provisioning_complete_cb(void)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
#if MESH_FEATURE_GATT_ENABLED
    /* Restores the application parameters after switching from the Provisioning
     * service to the Proxy  */
    gap_params_init();
    conn_params_init();
    unicast_address_print();
    hal_led_mask_set(HAL_LED_MASK, LED_MASK_STATE_OFF);
    hal_led_blink_ms(HAL_LED_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_PROV);
//------------------------------------- Initialization -------------------------------------------
static void mesh_init(void)
    /* Initialize the application storage for models */
    model_config_file_init();
    mesh_stack_init_params_t init_params =
        .core.irq_priority       = NRF_MESH_IRQ_PRIORITY_LOWEST,
        .core.lfclksrc           = DEV_BOARD_LF_CLK_CFG,
        .core.p_uuid             = NULL,
        .models.models_init_cb   = models_init_cb,
        .models.config_server_cb = config_server_evt_cb
    uint32_t status = mesh_stack_init(&init_params, &m_device_provisioned);
    if (status == NRF_SUCCESS)
        /* Check if application stored data is valid, if not clear all data and use default values. */
        status = model_config_file_config_apply();
    switch (status)
        case NRF_ERROR_INVALID_DATA:
            /* Clear model config file as loading failed */
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Data in the persistent memory was corrupted. Device starts as unprovisioned.\n");
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Reboot device before starting of the provisioning process.\n");
        case NRF_SUCCESS:
            ERROR_CHECK(status);
static void initialize(void)
    __LOG_INIT(LOG_SRC_APP | LOG_SRC_FRIEND, LOG_LEVEL_DBG1, LOG_CALLBACK_DEFAULT);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Server Demo -----\n");
    ERROR_CHECK(app_timer_init());
    hal_leds_init();
#if BUTTON_BOARD
    ERROR_CHECK(hal_buttons_init(button_event_handler));
    ble_stack_init();
    gap_params_init();
    conn_params_init();
    mesh_init();
static void start(void)
    rtt_input_enable(app_rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
    if (!m_device_provisioned)
        static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
        mesh_provisionee_start_params_t prov_start_params =
            .p_static_data    = static_auth_data,
            .prov_sd_ble_opt_set_cb = NULL,
            .prov_complete_cb = provisioning_complete_cb,
            .prov_device_identification_start_cb = device_identification_start_cb,
            .prov_device_identification_stop_cb = NULL,
            .prov_abort_cb = provisioning_aborted_cb,
            .p_device_uri = EX_URI_LS_SERVER
        ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
    mesh_app_uuid_print(nrf_mesh_configure_device_uuid_get());
    ERROR_CHECK(mesh_stack_start());
    hal_led_mask_set(HAL_LED_MASK_UPPER_HALF, LED_MASK_STATE_OFF);
    hal_led_blink_ms(HAL_LED_MASK_UPPER_HALF, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_START);
//----------------------------------- Main --------------------------------------------
    initialize();
    start();
    for (;;)
        (void)sd_app_evt_wait();
Server main.c
#include <stdint.h>
#include <string.h>
/* HAL */
#include "boards.h"
/* Core */
#include "proxy.h"
/* Models */
#include "log.h"
                            Static variables
        .element_index = 0,
        .p_args = NULL,
        node_reset();
    "\n"
    button_number++;
        case 1:
        case 2:
        case 3:
        case 4:
                node_reset();
    gap_params_init();
    conn_params_init();
    switch (status)
        case NRF_SUCCESS:
    hal_leds_init();
#if BUTTON_BOARD
    ble_stack_init();
    gap_params_init();
    conn_params_init();
    mesh_init();
    initialize();
    start();
    for (;;)
  • Seems like I uploaded the server code twice in the previous post. Here is the clients main.c....
    #include <stdint.h>
    #include <string.h>
    /* HAL */
    #include "boards.h"
    /* Core */
    /* Models */
    #include "generic_onoff_client.h"
    #include "log.h"
    /* Custom added includes */
     * Definitions
    #define APP_STATE_OFF                (0)
    #define APP_STATE_ON                 (1)
     * Forward declaration of static functions
     * Static variables
    static uint8_t data[] = {0x12};
    static void msg_client_reply_cb(access_model_handle_t handle, const access_message_rx_t * p_rx_msg, void * p_args)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Reply recieved [Handle:%04X] \n[Data: %02X, TTL:%02X] \n", handle, p_rx_msg->p_data[0], p_rx_msg->meta_data.ttl);
    static void reliable_status_cb(access_model_handle_t model_handle, void * p_args, access_reliable_status_t status)
        switch (status)
            case ACCESS_RELIABLE_TRANSFER_SUCCESS:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Reliable transfer success.\n");
            case ACCESS_RELIABLE_TRANSFER_TIMEOUT:
                __LOG(LOG_SRC_APP, LOG_LEVEL_WARN, "Reliable reply timed out\n");
            case ACCESS_RELIABLE_TRANSFER_CANCELLED:
                __LOG(LOG_SRC_APP, LOG_LEVEL_WARN, "Reliable transfer cancelled\n");
                /* Should not be possible. */
                NRF_MESH_ASSERT(false);
        {ACCESS_OPCODE_VENDOR(0xC3, 0xF001), msg_client_reply_cb}
            .model_id = ACCESS_MODEL_VENDOR(0xC001, 0xF001),
            .element_index = 0,
            .p_args = NULL,
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Model Handle is %04X\n", msg_model_handle);
    static void send_reliable_message(access_model_handle_t handle, const uint8_t * p_data, uint16_t length)
        const access_message_tx_t msg = {
            .opcode = ACCESS_OPCODE_VENDOR(0xC2, 0xF001), // Build the normal Message, with the Opcode that the Receiver should execute
            .p_buffer = p_data,
            .length = length,
        access_reliable_t reliable_msg = {
            .model_handle = handle,
            .message = msg,
            .reply_opcode = ACCESS_OPCODE_VENDOR(0xC3, 0xF001),
            .timeout = SEC_TO_US(5),
            .status_cb = reliable_status_cb
        if(access_reliable_model_is_free(handle))
        NRF_MESH_ERROR_CHECK(access_model_reliable_publish(&reliable_msg));
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Reliable message sent: %02X\n", reliable_msg.message.p_buffer[0]);
    static void send_message(access_model_handle_t handle, const uint8_t * p_data, uint16_t length)
            .opcode = ACCESS_OPCODE_VENDOR(0xC4, 0xF001), // Build the normal Message, with the Opcode that the Receiver should execute
            .p_buffer = p_data,
            .length = length,
        NRF_MESH_ERROR_CHECK(access_model_publish(handle, &msg));
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Message sent: %02X\n", msg.p_buffer[0]);
            node_reset();
        "\n"
        "\t\t------------------------------------------------------------------------------------\n"
        "\t\t Button/RTT 1) Send a custom reliable message\n"
        "\t\t Button/RTT 2) Send a custom message\n"
        "\t\t Button/RTT 3)-\n"
        "\t\t Button/RTT 4) Reset node\n"
        "\t\t------------------------------------------------------------------------------------\n";
        button_number++;
            case 1:
                send_reliable_message(msg_model_handle, &data[0], ARRAY_SIZE(data));
            case 2:
                send_message(msg_model_handle, &data[0], ARRAY_SIZE(data));
            case 3:
            case 4:
                node_reset();
    static void rtt_input_handler(int key)
        gap_params_init();
        conn_params_init();
                                Initialization
        switch (status)
            case NRF_SUCCESS:
        __LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS | LOG_SRC_BEARER, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Client Demo -----\n");
        hal_leds_init();
    #if BUTTON_BOARD
        ble_stack_init();
        gap_params_init();
        conn_params_init();
        mesh_init();
        rtt_input_enable(rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
                .p_device_uri = EX_URI_LS_CLIENT
        hal_led_blink_ms(HAL_LED_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_START);
        initialize();
        start();
        for (;;)
  • I just found the problem. The reply OpCode is wrong. When I hard code it to the right client OpCode it works. How do i access the reply.opcode.opcode that is sent fromt the client though?
  • Realized that reply_opcode isn't actually sent with the message, but just specifies which OpCode has to be in the reply message. Case closed....
