Softdevice - WDT event not occurring when it hangs
I am using nRF52833 based BE33 (Celium Devices) and using nRF52SDK17.0.2. I am trying to implement WDT and expecting to occur its event when the module becomes hang or any unexpected error occurred. I am purposely written the code where BLE is advertising and after every 1 second I am trying to update BLE advertise data below is the code that does this.
void advertising_update(uint8_t loadcellnumber,uint8_t loadcell_data[])
uint32_t err;
  err=  sd_ble_gap_adv_stop(m_advertising.adv_handle);
    APP_ERROR_CHECK(err);
    switch(loadcellnumber){
    case 1:{
      loadcellData[0]=loadcell_data[0];
      loadcellData[1]=loadcell_data[1];
      loadcellData[2]=loadcell_data[2];
      loadcellData[3]=loadcell_data[3];
    case 2:{
      loadcellData[4]=loadcell_data[0];
      loadcellData[5]=loadcell_data[1];
      loadcellData[6]=loadcell_data[2];
      loadcellData[7]=loadcell_data[3];
    case 3:{
      loadcellData[8]=loadcell_data[0];
      loadcellData[9]=loadcell_data[1];
      loadcellData[10]=loadcell_data[2];
      loadcellData[11]=loadcell_data[3];
advertising_init();
advertising_start();
WDT code in main.c
#include "nrf_drv_wdt.h"
nrf_drv_wdt_channel_id m_channel_id;
//Configure WDT.
    nrf_drv_wdt_config_t config = NRF_DRV_WDT_DEAFULT_CONFIG;
    err_code = nrf_drv_wdt_init(&config, wdt_event_handler);
    err_code = nrf_drv_wdt_channel_alloc(&m_channel_id);
    nrf_drv_wdt_enable();
for (;;)
       idle_state_handle();
       nrf_drv_wdt_feed();
I have added below in sdk_config.h file:
// <e> NRFX_WDT_ENABLED - nrfx_wdt - WDT peripheral driver
#ifndef NRFX_WDT_ENABLED
#define NRFX_WDT_ENABLED 1
// <o> NRFX_WDT_CONFIG_BEHAVIOUR  - WDT behavior in CPU SLEEP or HALT mode
// <1=> Run in SLEEP, Pause in HALT
// <8=> Pause in SLEEP, Run in HALT
// <9=> Run in SLEEP and HALT
// <0=> Pause in SLEEP and HALT
#ifndef NRFX_WDT_CONFIG_BEHAVIOUR
#define NRFX_WDT_CONFIG_BEHAVIOUR 1
// <o> NRFX_WDT_CONFIG_RELOAD_VALUE - Reload value in ms  <1-131072000>
#ifndef NRFX_WDT_CONFIG_RELOAD_VALUE
#define NRFX_WDT_CONFIG_RELOAD_VALUE 20000
// <o> NRFX_WDT_CONFIG_NO_IRQ  - Remove WDT IRQ handling from WDT driver
// <0=> Include WDT IRQ handling
// <1=> Remove WDT IRQ handling
#ifndef NRFX_WDT_CONFIG_NO_IRQ
#define NRFX_WDT_CONFIG_NO_IRQ 0
// <o> NRFX_WDT_CONFIG_IRQ_PRIORITY  - Interrupt priority
// <0=> 0 (highest)
// <1=> 1
// <2=> 2
// <3=> 3
// <4=> 4
// <5=> 5
// <6=> 6
// <7=> 7
#ifndef NRFX_WDT_CONFIG_IRQ_PRIORITY
#define NRFX_WDT_CONFIG_IRQ_PRIORITY 6
// <e> NRFX_WDT_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRFX_WDT_CONFIG_LOG_ENABLED
#define NRFX_WDT_CONFIG_LOG_ENABLED 0
// <o> NRFX_WDT_CONFIG_LOG_LEVEL  - Default Severity level
// <0=> Off
// <1=> Error
// <2=> Warning
// <3=> Info
// <4=> Debug
#ifndef NRFX_WDT_CONFIG_LOG_LEVEL
#define NRFX_WDT_CONFIG_LOG_LEVEL 3
// <o> NRFX_WDT_CONFIG_INFO_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef NRFX_WDT_CONFIG_INFO_COLOR
#define NRFX_WDT_CONFIG_INFO_COLOR 0
// <o> NRFX_WDT_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef NRFX_WDT_CONFIG_DEBUG_COLOR
#define NRFX_WDT_CONFIG_DEBUG_COLOR 0
// </e>
When when I try to connect to BLE from nRF connect App immediately after 1 seconds below error occurs.
<info> app: GATT ATT MTU on connection 0x0 changed to 247.
<error> app: ERROR 8 [NRF_ERROR_INVALID_STATE] at /home/neeraj/Applications/EmbeddedStudio_ARM_Nordic_v568_linux_x64/nRF5SDK1702d674dde/nRF5_SDK_17.0.2_d674dde/examples/peripheral/iotians_device_loadcell/IG_BLE.c:524 (line number 524 is line number 5 in above example)
PC at: 0x0002B885
<error> app: End of error report
Here was I expecting that the WDT event should occur but it was not.
Please help me. Am I expecting wrong? Please correct me if I am wrong.
Thanks and regards,
Neeraj Dhekale
