RAM retention failure
Hello
I am trying to figure out the ram retention on my nRF52-DK using SES and SDK v17.1.0. I've run through the example ram_retention, and studied a topic in Nordic's documentation, as well as a couple of threads here in DevZone, like this one, and this one. I adapted my code to implement RAM retention using the given examples, but it didn't work for me.
I did all the mentioned steps:
  • declared the variable I want to retain in the .non_init section ( static uint32_t ble_activate __attribute__((section(".non_init"))); )
  • turned the RAM powered on during the SystemOFF sleepmode:
    // Configure the RAM retention parameters
    uint8_t i;
    for(i = 0; i < 8; i++) // Retain RAM 0 - RAM 7
        sd_power_ram_power_set(i, (POWER_RAM_POWER_S0POWER_On << POWER_RAM_POWER_S0POWER_Pos) |
                                  (POWER_RAM_POWER_S1POWER_On << POWER_RAM_POWER_S1POWER_Pos) |
                                  (POWER_RAM_POWER_S0RETENTION_On << POWER_RAM_POWER_S0RETENTION_Pos) |
                                  (POWER_RAM_POWER_S1RETENTION_On << POWER_RAM_POWER_S1RETENTION_Pos));
    // Delay for one second
    nrf_delay_ms(1000);
  • And checking up the NRF_POWER->GPREGRET  for a pre-set value upon every wakeup.
However, I see that value is not preserved since I am outputting it using printf and it returns back as a nonsense number. Please, find my main.c attached. The crucial steps are implemented in void mers_ram_retention(void). The code is loosely based on ble_app_uart example, that is, in configures BLE stack as per original method and then starts advertising, and finally, goes to SystemOFF.
 * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
 * All rights reserved.
#include <stdint.h>
#include <string.h>
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_delay.h"
#include "MERS_BLE.h"
#include "MERS_LoRaWAN.h"
#include "MERS_fstorage.h"
/* Project global variables */
extern uint8_t key_cnt;
extern bool keys_received;
extern bool ble_connected;
/**@brief Function for initializing the timer module.
static void timers_init(void){
 * @param[in]   event   Event generated by button press.
void bsp_event_handler(bsp_event_t event){
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            //err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            //if (err_code != NRF_ERROR_INVALID_STATE)
            //    APP_ERROR_CHECK(err_code);
        case BSP_EVENT_WHITELIST_OFF:
            //if (m_conn_handle == BLE_CONN_HANDLE_INVALID)
            //    err_code = ble_advertising_restart_without_whitelist(&m_advertising);
            //    if (err_code != NRF_ERROR_INVALID_STATE)
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
void uart_event_handle(app_uart_evt_t * p_event){
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            //if ((data_array[index - 1] == '\n') ||
            //    (data_array[index - 1] == '\r') ||
            //    (index >= m_ble_nus_max_data_len))
            //    if (index > 1)
            //        NRF_LOG_DEBUG("Ready to send data over BLE NUS");
            //        NRF_LOG_HEXDUMP_DEBUG(data_array, index);
            //        do
            //            uint16_t length = (uint16_t)index;
            //            err_code = ble_nus_data_send(&m_nus, data_array, &length, m_conn_handle);
            //            if ((err_code != NRF_ERROR_INVALID_STATE) &&
            //                (err_code != NRF_ERROR_RESOURCES) &&
            //                (err_code != NRF_ERROR_NOT_FOUND))
            //        } while (err_code == NRF_ERROR_RESOURCES);
            //    index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void){
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .rts_pin_no   = 0,
        .cts_pin_no   = 0,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
static void buttons_leds_init(bool * p_erase_bonds){
    bsp_event_t startup_event;
     uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void){
static void power_management_init(void){
    ret_code_t err_code;
static void idle_state_handle(void){
        nrf_pwr_mgmt_run();
/**@brief A function to fetch LoRaWAN keys
mers_ble_keys_t mers_ble_obtain_keys(void){
    /* Check if the LoRa keys have been received and store them in the Flash */
    if (keys_received){
        NRF_LOG_INFO("Received 4 keys.");
        NRF_LOG_FLUSH();
        mers_store_lora_keys();
        ble_activate = false;
        /* Keys are received, we can disconnect and disable BLE */
        //mers_ble_disconnect();       // <--- Leave the disconnect decision to the Smartphone
        ble_connected = false;
        return MERS_KEYS_RECEIVED_OK;
        return MERS_KEYS_RECEIVED_NOT_OK;
void mers_ram_retention(void){
    // Check if chip is waking up after a SoftReset.
    if(NRF_POWER->GPREGRET == 0xBB){
        printf("\n\rble_activate value: %d", ble_activate);
        // Reset GPREGRET register
        // NRF_POWER->GPREGRET = 0x00;
    else {
        ble_activate = 0x01UL;
        // Store magic number in GPREGRET register to indicate that the content should be checked upon reset.
        NRF_POWER->GPREGRET = 0xBB;
    uint8_t i;
    nrf_delay_ms(1000);
/**@brief Application main function.
int main(void){
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    fstorage_init();
    // Start execution.
    printf("\n\r*********************************");
    printf("\n\r       MarineEye Remote Sensor"   );
    printf("\n\r          Pero, 2022"             );
        Add Git version printout
    NRF_LOG_INFO("Debug logging for MERS over RTT started.");
    NRF_LOG_FLUSH();
    mers_ram_retention();
    printf("\n\rkeys_received value: %d", keys_received);
    /* Activate the BLE radio and start advertising */
    if (ble_activate){
        mers_ble_init();
        printf("\n\rBLE Advertising started.\n\r");
    else{
        printf("\n\rBLE not activated.");
    ///* Check for the keys in the Flash */
    //if (mers_read_lora_keys() != LORA_KEYS_IN_FLASH_OK){
    //      ble_activate = true;
    //      /* Activate BLE radio and get the keys */
    //      mers_ble_obtain_keys();
    //else{
    //    NRF_LOG_INFO("\n\rLoRaWAN Keys found.\n\rBLE radio not started.");
    //    Do the job with Lora keys
    //NRF_LOG_INFO("\n\rDevice going to sleep");
    //NRF_LOG_FLUSH();
    uint32_t dummy_cntr = 0;
    while(1){
        if (ble_connected){
            if(mers_ble_obtain_keys() == MERS_KEYS_RECEIVED_OK){
                printf("\n\rLoRaWAN Keys received.");
                sleep_mode_enter();
            ble_activate = 0UL;
        else{
            dummy_cntr++;
            if ((dummy_cntr % 40) == 0)
        idle_state_handle();
Could you please tell me what went wrong?
Best,
W
    The RAM configuration looks to be correct. However, when the noinit section gets corrupted it usually is because there is a bootloader overwriting the section on startup. Could that be the case here? If not, I will try to set up a test tomorrow and see if I can replicate the issue on my side.
    Vidar
  • Hello Vidor, thanks for the reply. I'm not using the bootloader, as far as I know. I have started from ble_app_uart and built upon it, never including any bootloader.
    Hey, if it helps, I have uploaded you a complete project -  I've stripped down all functionality except ble-uart and ram retention to demonstrate the issue. It should run on PCA10040:
    MERS.zip
    Best, P
  • You can see where the .non_init section is located in RAM from the memory usage view in SES here (or from the *.map output):
    Can you believe, I did exaxtly that last night? I found out that my variable lives at 0x20003F00, i.e in the section RAM 1. When I turned off all sections except that one, it worked just fine! How cool is that?
    Important: the .non_init section does not start at a fixed address. So it may change between builds. E.g. when you turn off or enable compiler optimization.
    This is what I also noticed. Is there a way to fix a variable at the given section and make sure it stays there every time?
  • Yes, you can specify a fixed start address for the non_init section in your flash_placemecement.xml file.
    e.g.
    Note that this fixed address must be somewhere between .tbss and   .heap (or .stack if you don't use heap).
  • Cool. One last question: in short words, how does the compiler (linker?) determine the addresses of all those sections? I always though it was pregiven in the .ld file (though I never bothered to look it up there)
  • The linker starts with the first sections and sequentially works its way up one section at a time. So the start address of a section is usually dependent on the size of previous sections. You may, for instance, notice that .non_init gets shifted up when you add more static zero initialized variables in your code (placed in .bss)
    SES generates the actual linker script from the flash_placement.xml file. The generated linker script can be found together with the other output files.
