How to add custom service to the Ble_app_template example
Hello i am using nrf52810 with SDK version 17.0.2 , i want to add custom service to the ble_app_template example and i followed this tutorial link https://github.com/edvinand/custom_ble_service_example so at first debug i got this error as expected
next i have change the RAM_START AND RAM_SIZE as per the memory size mentioned in the error then i DEBUG it again so the i got
so i don't know what's happening please help me to resolve this .
thank you.
    How does this function look?
    the service_init() function is look this.
    ret_code_t err_code;
    /* YOUR_JOB: Add code to initialize the services used by the application.
    ble_xxs_init_t xxs_init;
    ble_yys_init_t yys_init;
    // Initialize XXX Service.
    memset(&xxs_init, 0, sizeof(xxs_init));
    xxs_init.evt_handler = NULL;
    xxs_init.is_xxx_notify_supported = true;
    xxs_init.ble_xx_initial_value.level = 100;
    err_code = ble_bas_init(&m_xxs, &xxs_init);
    // Initialize YYY Service.
    memset(&yys_init, 0, sizeof(yys_init));
    yys_init.evt_handler = on_yys_evt;
    yys_init.ble_yy_initial_value.counter = 0;
    err_code = ble_yy_service_init(&yys_init, &yy_init);
    ble_cus_init_t cus_init;
    // Initialize CUS Service.
    memset(&cus_init, 0, sizeof(cus_init));
    err_code = ble_cus_init(&m_cus, &cus_init);
    printf("err_code:%d",err_code);
    next, like i want to send some data from
    aa-ble_app_template - Custom_service1.zip
    nrf_connect mobile app to the device. If i am not wrong i need to add custom_service to my code right.?? so for this i used this code please have look at the zip.file
    thank you.
    The error seems to be returned by the ble_cus_init not services_init, please show ble_cus_init instead so I may take a look.
    Please also try to find out for yourself why it would return the INVALID_PARAM by checking its API reference - or the API reference of any function which error code is forwarded - and let me know what you think.
    Karl
    uint32_t ble_cus_init(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init)
    if (p_cus == NULL || p_cus_init == NULL)
    return NRF_ERROR_NULL;
    uint32_t err_code;
    ble_uuid_t ble_uuid;
    // Initialize service structure
    p_cus->evt_handler = p_cus_init->evt_handler;
    p_cus->conn_handle = BLE_CONN_HANDLE_INVALID;
    // Add Custom Service UUID
    ble_uuid128_t base_uuid = {CUSTOM_SERVICE_UUID_BASE};
    err_code = sd_ble_uuid_vs_add(&base_uuid, &p_cus->uuid_type);
    VERIFY_SUCCESS(err_code);
    ble_uuid.type = p_cus->uuid_type;
    ble_uuid.uuid = CUSTOM_SERVICE_UUID;
    // Add the Custom Service
    err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_cus->service_handle);
    if (err_code != NRF_SUCCESS)
    return err_code;
    // Add Custom Value characteristic
    return custom_value_char_add(p_cus, p_cus_init);
    i think the UUID which we are passing to the function is wrong.
    Hi mr.Karl i think first error is resolved like now its advertising Device name and i can able to connect while debugging also its working fine without any errors with custom_service tutorial code not mine.
    then i have add read and write characteristics to the service but its not added. for more information please have look
    here unknown service is added but read and write characteristics not added even when i debug there is no error as you can see in the first picture.
    the ble_cus_init() look like this
    ret_code_t ble_cus_init(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init)
            return err_code;    // This seems redundant, but we'll add more later
        return err_code;
         // Add the Custom Value Characteristic
    next the characteristics add function is
    static ret_code_t custom_value_char_add(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init)
        ble_gatts_char_md_t char_md;
        ble_gatts_attr_md_t cccd_md;
        ble_gatts_attr_t    attr_char_value;
        ble_gatts_attr_md_t attr_md;
        memset(&cccd_md, 0, sizeof(cccd_md));
        char_md.char_props.read   = 1;
        char_md.char_props.write  = 1;
        char_md.char_props.notify = 1;
        char_md.p_char_user_desc  = NULL;
        char_md.p_char_pf         = NULL;
        char_md.p_user_desc_md    = NULL;
        char_md.p_cccd_md         = &cccd_md;
        char_md.p_sccd_md         = NULL;
        ble_uuid.uuid             = CUSTOM_VALUE_CHAR_UUID;
        memset(&attr_md, 0, sizeof(attr_md));
        attr_md.read_perm         = p_cus_init->custom_value_char_attr_md.read_perm;
        attr_md.write_perm        = p_cus_init->custom_value_char_attr_md.write_perm;
        attr_md.vloc              = BLE_GATTS_VLOC_STACK;
        attr_md.rd_auth           = 0;
        attr_md.wr_auth           = 0;
        attr_md.vlen              = 0;
        memset(&attr_char_value, 0, sizeof(attr_char_value));
        attr_char_value.p_uuid    = &ble_uuid;
        attr_char_value.p_attr_md = &attr_md;
        attr_char_value.init_len  = sizeof(uint8_t);
        attr_char_value.init_offs = 0;
        attr_char_value.max_len   = sizeof(uint8_t);
        err_code = sd_ble_gatts_characteristic_add(p_cus->service_handle, &char_md,
                                                  &attr_char_value,
                                                  &p_cus->custom_value_handles);
            return err_code;
        return NRF_SUCCESS;
    thank you.
    I am happy to hear that the initial issue is resolved!
    How did you resolve it?
    Could you also tell me which step of the tutorial you are currently working on?
    Could you confirm that you pass all the returned error codes to an APP_ERROR_CHECK?
    Furthermore, I see that you use a lot of breakpoints in your code - please be advised that you may not use breakpoints while the SoftDevice is enabled, since they will halt the CPU and cause the SoftDevice to assert immediately upon resuming the program. This is because the SoftDevice keeps track of upcoming BLE events using a timer instances, and so it will assert if it for some reason is unable to process them.
    Karl
