What are the API's can be used to send and receive packets on NIDD in NRF9160
Hi.
I'm using PDN example code on zephyr nrf sdk. Please take a look on below log.
Can somebody help me to figure out what are the API can be used to send and receive packets on NIDD.
15:27:22.791 -> *** Booting Zephyr OS build v2.6.99-ncs1-2245-g35654ffa6d06  ***
15:27:22.824 -> PDN sample started
15:27:22.824 -> AT+CNEC
15:27:22.824 -> AT+CGEREP
15:27:22.824 -> PDN Init
15:27:22.824 -> lte_lc_init_and_connect
15:27:23.822 -> [00:00:00.241,027] <dbg> lte_lc.init_and_config: System mode (2) and preference (0) are already configured
15:27:26.051 -> [00:00:02.446,319] <dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 2,"C084","003F7592",9
15:27:26.051 ->
15:27:26.051 -> [00:00:02.446,563] <dbg> lte_lc_helpers.parse_cereg: Network registration status: 2
15:27:26.051 -> [00:00:02.446,594] <dbg> lte_lc_helpers.parse_cereg: LTE mode: 9
15:27:26.051 -> [00:00:02.702,606] <dbg> lte_lc.at_handler: +CSCON notification
15:27:27.049 -> notify +CGEV: ME PDN ACT 0,1
15:27:27.049 -> Event: PDP context 0 activated
15:27:27.049 -> lte_lc_init_and_connect
15:27:27.049 -> Default APN is #####
15:27:27.049 -> Created new PDP context 1
15:27:27.049 -> PDP context 1 configured: APN #####, Family IPV4V6
15:27:27.082 -> notify +CGEV: ME PDN ACT 1,1
15:27:27.082 -> Event: PDP context 1 activated
15:27:27.215 -> notify +CGEV: IPV6 0
15:27:27.215 -> Event: PDP context 0 IPv6 up
15:27:27.215 -> notify +CGEV: IPV6 1
15:27:27.215 -> Event: PDP context 1 IPv6 up
15:27:28.046 -> [00:00:04.457,611] <dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 1,"C084","003F7592",9,,,"00100001","0~
15:27:28.079 -> [00:00:04.457,946] <dbg> lte_lc_helpers.parse_cereg: Network registration status: 1
15:27:28.079 -> [00:00:04.457,97PDP Context 0, PDN ID 0
15:27:28.079 -> 7]PDP Context 1, PDN ID 0
15:27:28.079 -> Bye
15:27:28.079 ->  <dbg> lte_lc_helpers.parse_cereg: LTE mode: 9
15:27:58.344 -> [00:00:34.742,767] <dbg> lte_lc.at_handler: +CSCON notification
    The PDN example, which it looks like you're running, will showcase how to setup a specific PDN. This seems to be successful at your end, which is a good starting point. However, it does not do anything wrt. NIDD.
    the modem_shell can do NIDD. Please see this thread on how to use NIDD with the modem shell:
    https://devzone.nordicsemi.com/f/nordic-q-a/76364/nidd-testing-with-modem-shell---nrf9160-nb-iot
    The above thread refers to the raw socket, as also listed with examples in the modem shell documentation:
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/nrf9160/modem_shell/README.html#id5
    Could you try this and see if that works at your end?
    Håkon
  • I have one doubt.
    When I configure the PDN example to Non-IP it shows "PDN type IPv6 only allowed". Is it mean that my SIM does not support NIDD?
    17:07:32.696 -> Created new PDP context 1
    17:07:32.729 -> PDP context 1 configured: APN ****, Family Non-IP
    17:07:32.729 -> Event: PDP context 1, PDN type IPv6 only allowed
    17:07:32.729 -> notify +CGEV: RESTR 3,1
    17:07:32.729 -> pdn_activate() failed, err -8 esm 51 PDN type IPv6 only allowed
    17:07:32.862 -> notify +CGEV: IPV6 0
    17:07:32.862 -> Event: PDP context 0 IPv6 up
    pdn_activate() returns -8 (ENOEXEC), which seems to indicate that enabling the specific APN is not successful:
    https://github.com/nrfconnect/sdk-nrf/blob/v1.9.1/lib/pdn/pdn.c#L345-L348
    The ESM cause code indicates that your APN only support ipv6.
    The activation of the other APN fails, indicating that you are having issues enabling the APN/PDN for NIDD. This could be due to wrong settings, or incorrect authentication (for instance SIM issues).
    Håkon
  • I followed Modem Shell example and this is my log,
    17:47:20.519 -> Functional mode set successfully: power off
    17:47:20.519 -> mosh:~$ link defcont -e -a "SimAPI" -f "non-ip"
    17:47:57.960 -> link defcont enabled
    17:47:57.960 -> link_sett_save_defcont_apn: key mosh_link_settings/defcont_apn with value SimAPI saved
    17:47:57.960 -> Key "mosh_link_settings/defcont_ip_family" with value "3" / "non-ip" saved
    17:47:57.960 -> mosh:~$ link funmode --normal
    17:48:20.462 -> Functional mode set successfully: normal
    17:48:20.462 -> mosh:~$ Network registration status: searching
    17:48:23.256 -> mosh:~$ LTE cell changed: Cell ID: 4158866, Tracking area: 49284
    17:48:23.256 -> mosh:~$ Currently active system mode: NB-IoT
    17:48:23.256 -> mosh:~$ RRC mode: Connected
    17:48:23.489 -> mosh:~$ RRC mode: Idle
    17:48:24.785 -> mosh:~$ sock connect -f packet -t raw
    17:49:07.080 -> Socket open and connect family=3, type=3, port=0, bind_port=0, pdn_cid=0, address=
    17:49:07.080 -> Socket created socket_id=0, fd=4
    17:49:07.080 -> mosh:~$ sock send -d foodata2 -i 0
    17:49:17.914 -> Socket data send:
    17:49:17.914 -> 	foodata2
    17:49:17.914 -> Error from socket id=0 (fd=4), closing
