Chip antenna recommendation
Do you have a suggestion for a 2.4GHz chip antenna? I sent a board to Ketil for RF tuning but the meander antenna ended up as too short. We would like to avoid a separate PCB revision round to set the length of an inverted-F or other PCB antenna.
The board is 90x66mm with the 2.4GHz radio section in one corner.
We need a 50Ohm node in the matching network to mux in an external antenna.
Børge
