Current Measurement on nRF5340 DK
Hi there,
We are currently doing current measurements on the nRF5340 DK with a Power Profiler Kit 2.
To do this, we simply use the PPK as a source meter and connect it to the "External Supply" pin. We also set SW10 to on (VEXT->nRF).
We leave the the USB connected to the interface MCU in order to communicate via UART.
However, we are measuring a current of 6mA for this which is quite high, as the only peripheral we are running is the RTC and the watchdog.
Could you please confirm whether this is the recommended way of measuring the current.
We have also tried measuring using the PPK as a ammeter, and connecting it to the measurement pin (p22) while using the USB as power source, however we are getting even higher readings using that method.
Please advise.
Frikkie
