Hello, simple question regarding k_sleep(), to simplify, I've modified button example from Zephyr adding a k_sleep in button_pressed function, the k_sleep it's not working as espected, it returns immediatelly without waiting the sleep timeout. What I'm missing?
Thanks for the help
* Copyright (c) 2016 Open-RnD Sp. z o.o.
* Copyright (c) 2020 Nordic Semiconductor ASA
#include <zephyr.h>
#include <device.h>
#include <drivers/gpio.h>
#include <sys/util.h>
#include <sys/printk.h>
#include <inttypes.h>
#define SLEEP_TIME_MS 1
* Get button configuration from the devicetree sw0 alias. This is mandatory.
#define SW0_NODE DT_ALIAS(sw0)
#if !DT_NODE_HAS_STATUS(SW0_NODE, okay)
#error "Unsupported board: sw0 devicetree alias is not defined"
static const struct gpio_dt_spec button = GPIO_DT_SPEC_GET_OR(SW0_NODE, gpios,
{0});
static struct gpio_callback button_cb_data;
* The led0 devicetree alias is optional. If present, we'll use it
* to turn on the LED whenever the button is pressed.
static struct gpio_dt_spec led = GPIO_DT_SPEC_GET_OR(DT_ALIAS(led0), gpios,
{0});
void button_pressed(const struct device *dev, struct gpio_callback *cb,
uint32_t pins)
printk("Button pressed at %" PRIu32 "\n", k_cycle_get_32());
k_msleep(1000); //This is not working
printk("Do something");
void main(void)
int ret;
if (!device_is_ready(button.port)) {
printk("Error: button device %s is not ready\n",
button.port->name);
return;
ret = gpio_pin_configure_dt(&button, GPIO_INPUT);
if (ret != 0) {
printk("Error %d: failed to configure %s pin %d\n",
ret, button.port->name, button.pin);
return;
ret = gpio_pin_interrupt_configure_dt(&button,
GPIO_INT_EDGE_TO_ACTIVE);
if (ret != 0) {
printk("Error %d: failed to configure interrupt on %s pin %d\n",
return;
gpio_init_callback(&button_cb_data, button_pressed, BIT(button.pin));
gpio_add_callback(button.port, &button_cb_data);
printk("Set up button at %s pin %d\n", button.port->name, button.pin);
if (led.port && !device_is_ready(led.port)) {
printk("Error %d: LED device %s is not ready; ignoring it\n",
ret, led.port->name);
led.port = NULL;
if (led.port) {
ret = gpio_pin_configure_dt(&led, GPIO_OUTPUT);
if (ret != 0) {
printk("Error %d: failed to configure LED device %s pin %d\n",
ret, led.port->name, led.pin);
led.port = NULL;
} else {
printk("Set up LED at %s pin %d\n", led.port->name, led.pin);
printk("Press the button\n");
if (led.port) {
while (1) {
/* If we have an LED, match its state to the button's. */
int val = gpio_pin_get_dt(&button);
if (val >= 0) {
gpio_pin_set_dt(&led, val);
k_msleep(SLEEP_TIME_MS);
