nRF9160dk - Cannot connect to target
I'm having issues using the debugger on the nRF9160dk.
Here is the log that is output when I try to program the on-board 9160 with the command, nrfjprog --program <path_to>/build_1/zephyr/merged.hex --chiperase -f NRF91 --snr 960086086 --log
[2022-Mar-14 19:27:41] [ info] --------------------------------------------------------------------------------
[2022-Mar-14 19:27:41] [ info] nrfjprog --program <path_to>/build_1/zephyr/merged.hex --chiperase -f NRF91 --snr 960086086 --log
[2022-Mar-14 19:27:41] [ info] nrfjprog version 10.15.4 external
[2022-Mar-14 19:27:41] [ info] Load library at /Applications/Nordic Semiconductor/lib/libnrfjprogdll.dylib.
[2022-Mar-14 19:27:41] [ info] Library loaded, loading member functions.
[2022-Mar-14 19:27:41] [ info] Member functions succesfully loaded.
[2022-Mar-14 19:27:41] [debug] [ Client] - open
[2022-Mar-14 19:27:41] [debug] [ Client] - start
[2022-Mar-14 19:27:41] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 3db66bfb-8b56-4fee-8727-0843e78e5dea.
[2022-Mar-14 19:27:41] [trace] [ Client] - Command open executed for 11 milliseconds with result 0
[2022-Mar-14 19:27:41] [debug] [ Client] - enum_emu_snr
[2022-Mar-14 19:27:41] [trace] [ Client] - Command enum_emu_con_info executed for 2 milliseconds with result 0
[2022-Mar-14 19:27:41] [debug] [ Client] - connect_to_emu_with_snr
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2022-Mar-14 19:27:41] [debug] [  JLink] - Logger sink registered in JLink logger
[2022-Mar-14 19:27:41] [debug] [  nRF91] - open
[2022-Mar-14 19:27:41] [debug] [  nRF91] - just_check_family
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - open_dll
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2022-Mar-14 19:27:41] [ info] [SeggerBackend] - Load library at /Applications/SEGGER/JLink/libjlinkarm.7.62.2.dylib.
[2022-Mar-14 19:27:41] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2022-Mar-14 19:27:41] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - dll_version
[2022-Mar-14 19:27:41] [ info] [SeggerBackend] - Segger dll version 7.62.b loaded.
[2022-Mar-14 19:27:41] [trace] [ Worker] - Command open executed for 7 milliseconds with result 0
[2022-Mar-14 19:27:41] [debug] [  nRF91] - enum_emu_con_info
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - is_connected_to_emu
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - enum_emu_con_info
[2022-Mar-14 19:27:41] [trace] [ Worker] - Command enum_emu_con_info executed for 2 milliseconds with result 0
[2022-Mar-14 19:27:41] [debug] [  nRF91] - connect_to_emu_with_snr
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - ---just_get_num_emus
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - Segger logging enabled.
[2022-Mar-14 19:27:41] [trace] [  JLink] - Firmware: J-Link OB-K22-NordicSemi compiled Dec  3 2021 15:46:55
[2022-Mar-14 19:27:41] [trace] [  JLink] - Hardware: V1.00
[2022-Mar-14 19:27:41] [trace] [  JLink] - S/N: 960086086
[2022-Mar-14 19:27:41] [trace] [  JLink] - OEM: SEGGER
[2022-Mar-14 19:27:41] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
[2022-Mar-14 19:27:41] [trace] [  JLink] - TELNET listener socket opened on port 19021
[2022-Mar-14 19:27:41] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2022-Mar-14 19:27:41] [trace] [  JLink] - WEBSRV Failed to put socket into listener state (port 19080)
[2022-Mar-14 19:27:41] [trace] [  JLink] - WEBSRV Webserver running on local port 19081
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 26.721ms returns "O.K."
[2022-Mar-14 19:27:41] [trace] [  JLink] - JLINK_HasError()
[2022-Mar-14 19:27:41] [trace] [  JLink] - JLINK_Lock()
[2022-Mar-14 19:27:41] [trace] [  JLink] - JLINK_GetHWStatus(...)
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.255ms returns 0
[2022-Mar-14 19:27:41] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.004ms returns 0x01
[2022-Mar-14 19:27:41] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.002ms returns 0x00
[2022-Mar-14 19:27:41] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2022-Mar-14 19:27:41] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
[2022-Mar-14 19:27:41] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.024ms returns 0
[2022-Mar-14 19:27:41] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.637ms returns 0x00
[2022-Mar-14 19:27:41] [trace] [  JLink] - JLINK_SetSpeed(2000)
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.085ms
[2022-Mar-14 19:27:41] [trace] [  JLink] - JLINK_GetSN()
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.003ms returns 960086086
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - read_debug_port_idr
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - read_debug_port_register
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - coresight_configure
[2022-Mar-14 19:27:41] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 100.522ms returns 0
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2022-Mar-14 19:27:41] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.599ms returns -1
[2022-Mar-14 19:27:41] [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - ---just_abort_debug_action
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2022-Mar-14 19:27:41] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.532ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.570ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.617ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.544ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.573ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.523ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.530ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.560ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.500ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.508ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.529ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.552ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.567ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.569ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.585ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.564ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.489ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.580ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.533ms returns -1
[2022-Mar-14 19:27:41] [trace] [ Client] - Command connect_to_emu_with_snr executed for 169 milliseconds with result -102
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.518ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.550ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.525ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.623ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.011ms
[2022-Mar-14 19:27:41] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 169 milliseconds with result -102
[2022-Mar-14 19:27:41] [debug] [  nRF91] - close
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - is_connected_to_device
[2022-Mar-14 19:27:41] [trace] [  JLink] - JLINK_IsOpen()
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.003ms returns 0x01
[2022-Mar-14 19:27:41] [trace] [  JLink] - JLINK_IsConnected()
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.002ms returns FALSE
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.002ms returns 0x01
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - close
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - disconnect_from_emu
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - ---just_disconnect_from_emu
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.003ms returns FALSE
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.519ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.486ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.520ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.517ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.483ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.498ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.538ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.590ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.593ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.524ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.472ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.513ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.531ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.557ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.509ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.510ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.558ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.562ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.588ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.527ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.512ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.628ms returns -1
[2022-Mar-14 19:27:41] [trace] [  JLink] - - 0.009ms
[2022-Mar-14 19:27:41] [trace] [  JLink] - JLINK_Close()
[2022-Mar-14 19:27:41] [trace] [ Client] - Command close executed for 44 milliseconds with result 0
[2022-Mar-14 19:27:41] [debug] [ Client] - terminate
[2022-Mar-14 19:27:41] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
[2022-Mar-14 19:27:41] [debug] [SeggerBackend] - Segger Backend closed.
[2022-Mar-14 19:27:41] [debug] [  nRF91] - nRF family DLL closed
[2022-Mar-14 19:27:41] [trace] [ Worker] - Command close executed for 44 milliseconds with result 0
[2022-Mar-14 19:27:41] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
[2022-Mar-14 19:27:41] [trace] [ Worker] - Executed 5 commands for 222 milliseconds
[2022-Mar-14 19:27:41] [debug] [ Client] - Child process terminated with result 0
[2022-Mar-14 19:27:41] [debug] [ Client] - Worker process exited with code: 0
[2022-Mar-14 19:27:41] [trace] [ Client] - Executed 5 commands for 226 milliseconds
Set-up details:
Running macOS 12.2.1.
Output when I run JLinkExe:
SEGGER J-Link Commander V7.62b (Compiled Mar  8 2022 15:11:09)
DLL version V7.62b, compiled Mar  8 2022 15:11:03
Connecting to J-Link via USB...O.K.
Hardware version: V1.00
S/N: xxxxxxxx
License(s): RDI, FlashBP, FlashDL, JFlash, GDB
VTref=3.300V
When I run the 'connect' command in JLinkEXE, I get the following error: "Cannot connect to target."
Things tried so far:
  • Tried to program other targets (external to nRF9160dk using "Debug Out" connector, and the on-board nRF52840
  • Upgraded J-LINK DLL to latest (V7.62b)
This feels like it might be a hardware issue, but it would be nice know for sure. I've seen in other posts that recommend re-flashing the interface MCU firmware, but this seems like it only applies to nRF5 dks (https://devzone.nordicsemi.com/f/nordic-q-a/24592/my-nrf52-nrf51-dk-kit-doesn-t-work/96836#96836). Any help would be greatly appreciated!
