Re-installing nRF Connect SDK
How do I remove nRF Connect SDK from Windows before re-installing?
And are there something that needs to be done, if you have used cmake and Visual Studio Code for other projects?
I installed the tools via nRF Connect Desktop / Toolchain Manager in a project directory, but it looked like the paths got too long. Then I uninstalled the stuff via nRF Connect Desktop / Toolchain Manager, uninstalled the nRF Connect Desktop, removed the stuff from the project directory and rebooted. Then I re-installed everything at C:/ncs, but when I try to do something, it still defaults to the deleted project directory.
Also, when I tried (after re-install) to create the shell_bt_nus from an example and into another folder, I got the ELF-files (ARM code), but the Visual Studio Code shows errors:
    "resource": "/C:/Users/ett15110/Documents/Projects/xxxy/test/shell_bt_nus/src/main.c",
    "owner": "C/C++",
    "code": "1696",
    "severity": 8,
    "message": "cannot open source file \"alloca.h\" (dependency of \"logging/log.h\")",
    "source": "C/C++",
    "startLineNumber": 17,
    "startColumn": 1,
    "endLineNumber": 17,
    "endColumn": 25
    "resource": "/C:/Users/ett15110/Documents/Projects/xxx/test/shell_bt_nus/src/main.c",
    "owner": "C/C++",
    "code": "1696",
    "severity": 8,
    "message": "cannot open source file \"alloca.h\" (dependency of \"zephyr.h\")",
    "source": "C/C++",
    "startLineNumber": 11,
    "startColumn": 1,
    "endLineNumber": 11,
    "endColumn": 20
    "owner": "C/C++",
    "code": "1696",
    "severity": 8,
    "message": "#include errors detected. Consider updating your compile_commands.json or includePath. Squiggles are disabled for this translation unit (C:\\Users\\ett15110\\Documents\\Projects\\xxx\\test\\shell_bt_nus\\src\\main.c).",
    "source": "C/C++",
    "startColumn": 1,
    "endColumn": 20
The first two seems to happen, because __GNUC__ seems to not been defined.
And in the target folder it generated .vscode-file with this content:
    "configurations": [
            "name": "Win32",
            "includePath": [
                "${workspaceFolder}/**"
            "defines": [
                "_DEBUG",
                "UNICODE",
                "_UNICODE"
            "windowsSdkVersion": "10.0.19041.0",
            "compilerPath": "C:/Program Files (x86)/Microsoft Visual Studio/2019/BuildTools/VC/Tools/MSVC/14.29.30037/bin/Hostx64/x64/cl.exe",
            "cStandard": "c17",
            "cppStandard": "c++17",
            "intelliSenseMode": "windows-msvc-x64",
            "compileCommands": "${workspaceFolder}/build/compile_commands.json",
            "configurationProvider": "nrf-connect"
    "version": 4
I don't think it should use that compiler for anything.
It also found some errors from code for other HW!
Is there a way to "make clean"? I didn't find any.
  • So whom should I contact about those? I'm quite convinced that it wasn't Microsoft that came up with the idea of adding these:
    nordic-semiconductor.nrf-connect-2022.3.104/
    nordic-semiconductor.nrf-devicetree-2022.3.68/
    nordic-semiconductor.nrf-kconfig-2022.1.78/
    nordic-semiconductor.nrf-terminal-2022.3.16/
    trond-snekvik.gnu-mapfiles-1.1.0/
    to the /.vscode/extensions/
    Or should I whine about some of these things to Zephyr project?
    Also, is there a separate forum for nRF Connect for Desktop?
  • Hi
    Are you able to right click that notification to get information on what extension that notification comes from exactly?
    Simon
  • No. The only thing it gives me is "copy text".
    BTW, how do you update that "NCS master"?
    I did
    PS C:\ncs\v1.9.1> west update
    and I still got the Z_FOR_LOOP_1 errors.
     MINGW64 /c/ncs/v1.9.1/zephyr ((v2.7.99-ncs1-1))
    $ git fetch origin
    fatal: 'origin' does not appear to be a git repository
    fatal: Could not read from remote repository.
    Please make sure you have the correct access rights
    and the repository exists.
    AHA: even if the web pages don't tell that, there's a menu item in the toolchain manager "Update SDK".
    That didn't remove the Z_FOR_LOOP_1 errors, though.
  • Looks like some update (probably windows update) fixed the changes watcher. It doesn't seem to crash anymore.
    AFTER noticing that, I, once again, removed the SDK and desktop, downloaded the latest desktop version and installed everything again. The Z_FOR_LOOP_1 errors are still there.
  • Hi again
    To get the NCS master, you will have to install NCS manually as explained here and get the code from our git repo, as the master branch haven't been included in the toolchain manager yet. I think the Z_FOR_LOOP_1 errors should be taken care of in the next release of the nRF Connect SDK for the Toolchain manager.
    Simon
