Still having Eclipse problems
My problems with Eclipse Luna continue. Going on holiday for a week I assumed the good fairies would sort it out, but no,,, Anyhow, I'm sure it's some path error somewhere, because if I open a command window in the project\armgcc folder and type "make", everything builds fine, but when I try to build the project under Eclipse I get this error:
process_begin: CreateProcess(C:\Windows\make4428-1.bat, C:\Windows\make4428-1.bat, ...) failed.
make[1]: Leaving directory `C:/nRF51822/nRF51_SDK_9.0.0_2e23562/examples/ble_peripheral/ble_app_hrs/pca10028/s110_with_dfu/armgcc'
make (e=267): The directory name is invalid.
make[1]: *** [_build] Error 267
make: *** [all] Error 2
and I can't work out what directory name is being referred to.
I sure an Eclipse expert could find this quickly, or even a make expert who knew how to find the invalid path, but I'm totally stuck!"
  • Would put a coin on the slash/backslash issues: it seems you are under Windows, but make refers to path with / (even though it should be working).
  • Maybe. The weird thing is that it seems to work from Eclipse if I configure an External Tool to run make, it works if I run make from a command line box, just not if I build the project under Eclipse. I've tried using -n, but that seems to work in any event. The whole thing seems to break when make is trying to create the _build directory, as far as I can tell, but I've still got no idea why. If anyone has a clue as to how I can isolate the problem, I'd be grateful.
  • plesae try this type settings for "gcc tool chain setup in eclipse"
    (1) right click on projrct ---> properties (2) And then click on "C/C++ Build" (3) And goes in to "Builder settings"
    and set this type settings at below.. image description
    Build Command = Make Build Directory = choose your "armgcc" folder by use option "Workspace.."
    (4) Next goes in to "Behaviour" Tab and set this type settings at below..
    image description
