Application suddenly stopped building
I'm having an extremely annoying problem. I have an application that uses Nordic NUS service.
(1) I created it from the peripheral UART example for NRF52-DK, and adapted it for use with NRF52805 (removed non-exiting buttons and LEDS)
(2) It was compiling and flashing fine yesterday noon. Last night I tried to add built in die temperature read, and noticed that my app doesn't compile.
(3) I removed the new code, and now my app builds but hangs (reset on startup I think) I enable the terminal and see the following error:
(4) I then tried to start from scratch, i.e. I thought this might have to do with my NRF connect version.
     (a) I installed 1.9.1 (was working with 1.9.0)
     (b) I added the peripheral_uart example
     (c) I notice that it no longer lists nrf52805 as supported board, but I again removed non-existing hardware
     (d) The board now hangs on "Starting Nordic UART Service Example" (infinite loop repeats)
(5) Looking with a debugger line by line it seems that the command that hangs, compared to the 52832 build is bt_enable(NULL). Any insights?
Attached is the main code
 * Copyright (c) 2018 Nordic Semiconductor ASA
/** @file
 *  @brief Nordic UART Bridge Service (NUS) sample
#include "uart_async_adapter.h"
#include <zephyr/types.h>
#include <zephyr.h>
#include <drivers/uart.h>
#include <usb/usb_device.h>
#include <drivers/gpio.h>
#include <device.h>
#include <soc.h>
#include <bluetooth/bluetooth.h>
#include <bluetooth/uuid.h>
#include <bluetooth/gatt.h>
#include <bluetooth/hci.h>
#include <bluetooth/services/nus.h>
#include <dk_buttons_and_leds.h>
#include <settings/settings.h>
#include <stdio.h>
#include <logging/log.h>
#define LOG_MODULE_NAME peripheral_uart
LOG_MODULE_REGISTER(LOG_MODULE_NAME);
#define STACKSIZE CONFIG_BT_NUS_THREAD_STACK_SIZE
#define PRIORITY 7
#define DEVICE_NAME CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN	(sizeof(DEVICE_NAME) - 1)
#define RUN_STATUS_LED DK_LED1
#define RUN_LED_BLINK_INTERVAL 1000
#define CON_STATUS_LED DK_LED2
#define KEY_PASSKEY_ACCEPT DK_BTN1_MSK
#define KEY_PASSKEY_REJECT DK_BTN2_MSK
#define UART_BUF_SIZE CONFIG_BT_NUS_UART_BUFFER_SIZE
#define UART_WAIT_FOR_BUF_DELAY K_MSEC(50)
#define UART_WAIT_FOR_RX CONFIG_BT_NUS_UART_RX_WAIT_TIME
static K_SEM_DEFINE(ble_init_ok, 0, 1);
static struct bt_conn *current_conn;
static struct bt_conn *auth_conn;
static const struct device *uart;
static struct k_work_delayable uart_work;
struct uart_data_t {
	void *fifo_reserved;
	uint8_t data[UART_BUF_SIZE];
	uint16_t len;
static K_FIFO_DEFINE(fifo_uart_tx_data);
static K_FIFO_DEFINE(fifo_uart_rx_data);
static const struct bt_data ad[] = {
	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static const struct bt_data sd[] = {
	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_NUS_VAL),
#if CONFIG_BT_NUS_UART_ASYNC_ADAPTER
UART_ASYNC_ADAPTER_INST_DEFINE(async_adapter);
#else
static const struct device *const async_adapter;
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
	ARG_UNUSED(dev);
	static uint8_t *current_buf;
	static size_t aborted_len;
	static bool buf_release;
	struct uart_data_t *buf;
	static uint8_t *aborted_buf;
	switch (evt->type) {
	case UART_TX_DONE:
		LOG_DBG("tx_done");
		if ((evt->data.tx.len == 0) ||
		    (!evt->data.tx.buf)) {
			return;
		if (aborted_buf) {
			buf = CONTAINER_OF(aborted_buf, struct uart_data_t,
					   data);
			aborted_buf = NULL;
			aborted_len = 0;
		} else {
			buf = CONTAINER_OF(evt->data.tx.buf, struct uart_data_t,
					   data);
		k_free(buf);
		buf = k_fifo_get(&fifo_uart_tx_data, K_NO_WAIT);
		if (!buf) {
			return;
		if (uart_tx(uart, buf->data, buf->len, SYS_FOREVER_MS)) {
			LOG_WRN("Failed to send data over UART");
	case UART_RX_RDY:
		LOG_DBG("rx_rdy");
		buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data);
		buf->len += evt->data.rx.len;
		buf_release = false;
		if (buf->len == UART_BUF_SIZE) {
			k_fifo_put(&fifo_uart_rx_data, buf);
		} else if ((evt->data.rx.buf[buf->len - 1] == '\n') ||
			  (evt->data.rx.buf[buf->len - 1] == '\r')) {
			current_buf = evt->data.rx.buf;
			buf_release = true;
			uart_rx_disable(uart);
	case UART_RX_DISABLED:
		LOG_DBG("rx_disabled");
		buf = k_malloc(sizeof(*buf));
		if (buf) {
			buf->len = 0;
		} else {
			LOG_WRN("Not able to allocate UART receive buffer");
			k_work_reschedule(&uart_work, UART_WAIT_FOR_BUF_DELAY);
			return;
		uart_rx_enable(uart, buf->data, sizeof(buf->data),
			       UART_WAIT_FOR_RX);
	case UART_RX_BUF_REQUEST:
		LOG_DBG("rx_buf_request");
		if (buf) {
			buf->len = 0;
			uart_rx_buf_rsp(uart, buf->data, sizeof(buf->data));
		} else {
	case UART_RX_BUF_RELEASED:
		LOG_DBG("rx_buf_released");
		buf = CONTAINER_OF(evt->data.rx_buf.buf, struct uart_data_t,
				   data);
		if (buf_release && (current_buf != evt->data.rx_buf.buf)) {
			k_free(buf);
			current_buf = NULL;
	case UART_TX_ABORTED:
			LOG_DBG("tx_aborted");
			if (!aborted_buf) {
				aborted_buf = (uint8_t *)evt->data.tx.buf;
			aborted_len += evt->data.tx.len;
					   data);
			uart_tx(uart, &buf->data[aborted_len],
				buf->len - aborted_len, SYS_FOREVER_MS);
static void uart_work_handler(struct k_work *item)
	if (buf) {
		buf->len = 0;
	} else {
		return;
	uart_rx_enable(uart, buf->data, sizeof(buf->data), UART_WAIT_FOR_RX);
static bool uart_test_async_api(const struct device *dev)
	const struct uart_driver_api *api =
			(const struct uart_driver_api *)dev->api;
	return (api->callback_set != NULL);
static int uart_init(void)
	int err;
	int pos;
	struct uart_data_t *rx;
	struct uart_data_t *tx;
	uart = device_get_binding(CONFIG_BT_NUS_UART_DEV);
	if (!uart) {
		return -ENXIO;
	if (IS_ENABLED(CONFIG_USB_DEVICE_STACK)) {
		err = usb_enable(NULL);
		if (err) {
			LOG_ERR("Failed to enable USB");
			return err;
	rx = k_malloc(sizeof(*rx));
	if (rx) {
		rx->len = 0;
	} else {
		return -ENOMEM;
	k_work_init_delayable(&uart_work, uart_work_handler);
	if (IS_ENABLED(CONFIG_BT_NUS_UART_ASYNC_ADAPTER) && !uart_test_async_api(uart)) {
		/* Implement API adapter */
		uart_async_adapter_init(async_adapter, uart);
		uart = async_adapter;
	err = uart_callback_set(uart, uart_cb, NULL);
	if (err) {
		LOG_ERR("Cannot initialize UART callback");
		return err;
	if (IS_ENABLED(CONFIG_UART_LINE_CTRL)) {
		LOG_INF("Wait for DTR");
		while (true) {
			uint32_t dtr = 0;
			uart_line_ctrl_get(uart, UART_LINE_CTRL_DTR, &dtr);
			if (dtr) {
			/* Give CPU resources to low priority threads. */
			k_sleep(K_MSEC(100));
		LOG_INF("DTR set");
		err = uart_line_ctrl_set(uart, UART_LINE_CTRL_DCD, 1);
		if (err) {
			LOG_WRN("Failed to set DCD, ret code %d", err);
		err = uart_line_ctrl_set(uart, UART_LINE_CTRL_DSR, 1);
		if (err) {
			LOG_WRN("Failed to set DSR, ret code %d", err);
	tx = k_malloc(sizeof(*tx));
	if (tx) {
		pos = snprintf(tx->data, sizeof(tx->data),
			       "Starting Nordic UART service example\r\n");
		if ((pos < 0) || (pos >= sizeof(tx->data))) {
			k_free(tx);
			LOG_ERR("snprintf returned %d", pos);
			return -ENOMEM;
		tx->len = pos;
	} else {
		return -ENOMEM;
	err = uart_tx(uart, tx->data, tx->len, SYS_FOREVER_MS);
	if (err) {
		LOG_ERR("Cannot display welcome message (err: %d)", err);
		return err;
	return uart_rx_enable(uart, rx->data, sizeof(rx->data), 50);
static void connected(struct bt_conn *conn, uint8_t err)
	if (err) {
		LOG_ERR("Connection failed (err %u)", err);
		return;
	LOG_INF("Connected %s", log_strdup(addr));
	current_conn = bt_conn_ref(conn);
	//dk_set_led_on(CON_STATUS_LED); //matan remove for nrf52805
	LOG_INF("Disconnected: %s (reason %u)", log_strdup(addr), reason);
	if (auth_conn) {
		bt_conn_unref(auth_conn);
		auth_conn = NULL;
	if (current_conn) {
		bt_conn_unref(current_conn);
		current_conn = NULL;
		//dk_set_led_off(CON_STATUS_LED); //matan remove for nrf52805
#ifdef CONFIG_BT_NUS_SECURITY_ENABLED
static void security_changed(struct bt_conn *conn, bt_security_t level,
			     enum bt_security_err err)
	if (!err) {
		LOG_INF("Security changed: %s level %u", log_strdup(addr),
			level);
	} else {
		LOG_WRN("Security failed: %s level %u err %d", log_strdup(addr),
			level, err);
//BT_CONN_CB_DEFINE(conn_callbacks) = {
static struct bt_conn_cb conn_callbacks = {
	.connected    = connected,
	.disconnected = disconnected,
	.security_changed = security_changed,
#if defined(CONFIG_BT_NUS_SECURITY_ENABLED)
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
	LOG_INF("Passkey for %s: %06u", log_strdup(addr), passkey);
static void auth_passkey_confirm(struct bt_conn *conn, unsigned int passkey)
	auth_conn = bt_conn_ref(conn);
	LOG_INF("Press Button 1 to confirm, Button 2 to reject.");
static void auth_cancel(struct bt_conn *conn)
	LOG_INF("Pairing cancelled: %s", log_strdup(addr));
static void pairing_complete(struct bt_conn *conn, bool bonded)
	LOG_INF("Pairing completed: %s, bonded: %d", log_strdup(addr),
		bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
	LOG_INF("Pairing failed conn: %s, reason %d", log_strdup(addr),
		reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.passkey_display = auth_passkey_display,
	.passkey_confirm = auth_passkey_confirm,
	.cancel = auth_cancel,
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed
#else
static struct bt_conn_auth_cb conn_auth_callbacks;
static void bt_receive_cb(struct bt_conn *conn, const uint8_t *const data,
			  uint16_t len)
	int err;
	char addr[BT_ADDR_LE_STR_LEN] = {0};
	bt_addr_le_to_str(bt_conn_get_dst(conn), addr, ARRAY_SIZE(addr));
	LOG_INF("Received data from: %s", log_strdup(addr));
	for (uint16_t pos = 0; pos != len;) {
		struct uart_data_t *tx = k_malloc(sizeof(*tx));
		if (!tx) {
			LOG_WRN("Not able to allocate UART send data buffer");
			return;
		/* Keep the last byte of TX buffer for potential LF char. */
		size_t tx_data_size = sizeof(tx->data) - 1;
		if ((len - pos) > tx_data_size) {
			tx->len = tx_data_size;
		} else {
			tx->len = (len - pos);
		memcpy(tx->data, &data[pos], tx->len);
		pos += tx->len;
		/* Append the LF character when the CR character triggered
		 * transmission from the peer.
		if ((pos == len) && (data[len - 1] == '\r')) {
			tx->data[tx->len] = '\n';
			tx->len++;
		if (err) {
			k_fifo_put(&fifo_uart_tx_data, tx);
static struct bt_nus_cb nus_cb = {
	.received = bt_receive_cb,
void error(void)
	dk_set_leds_state(DK_ALL_LEDS_MSK, DK_NO_LEDS_MSK);
	while (true) {
		// Spin for ever
		k_sleep(K_MSEC(1000));
static void num_comp_reply(bool accept)
	if (accept) {
		bt_conn_auth_passkey_confirm(auth_conn);
		LOG_INF("Numeric Match, conn %p", (void *)auth_conn);
	} else {
		bt_conn_auth_cancel(auth_conn);
		LOG_INF("Numeric Reject, conn %p", (void *)auth_conn);
	auth_conn = NULL;
void button_changed(uint32_t button_state, uint32_t has_changed)
	uint32_t buttons = button_state & has_changed;
	if (auth_conn) {
		if (buttons & KEY_PASSKEY_ACCEPT) {
			num_comp_reply(true);
		if (buttons & KEY_PASSKEY_REJECT) {
			num_comp_reply(false);
#endif /* CONFIG_BT_NUS_SECURITY_ENABLED */
static void configure_gpio(void)
	int err;
	err = dk_buttons_init(button_changed);
	if (err) {
		LOG_ERR("Cannot init buttons (err: %d)", err);
#endif // CONFIG_BT_NUS_SECURITY_ENABLED
	err = dk_leds_init(); //matan remove for nrf52805
	if (err) {
		LOG_ERR("Cannot init LEDs (err: %d)", err);
void main(void)
	int blink_status = 0;
	int err = 0;
	configure_gpio();
	err = uart_init();
	if (err) {
		error();
	bt_conn_cb_register(&conn_callbacks);
	if (IS_ENABLED(CONFIG_BT_NUS_SECURITY_ENABLED)) {
		bt_conn_auth_cb_register(&conn_auth_callbacks);
	err = bt_enable(NULL);
	if (err) {
		error();
	LOG_INF("Bluetooth initialized");
	k_sem_give(&ble_init_ok);
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
	err = bt_nus_init(&nus_cb);
	if (err) {
		LOG_ERR("Failed to initialize UART service (err: %d)", err);
		return;
	err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), sd,
			      ARRAY_SIZE(sd));
	if (err) {
		LOG_ERR("Advertising failed to start (err %d)", err);
		return;
	for (;;) {
		//dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
		k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
void ble_write_thread(void)
	// Don't go any further until BLE is initialized
	k_sem_take(&ble_init_ok, K_FOREVER);
	for (;;) {
		// Wait indefinitely for data to be sent over bluetooth
		struct uart_data_t *buf = k_fifo_get(&fifo_uart_rx_data,
						     K_FOREVER);
		if (bt_nus_send(NULL, buf->data, buf->len)) {
			LOG_WRN("Failed to send data over BLE connection");
		k_free(buf);
K_THREAD_DEFINE(ble_write_thread_id, STACKSIZE, ble_write_thread, NULL, NULL,
		NULL, PRIORITY, 0, 0);
What is going on ??!!
Please help,
Cheers,
  • (1) Thanks, I will keep that in mind.
    nrfjprog --eraseall
    So.. the simple "Erase and flash" option doesn't completely delete the flash?
    (2) To complete the picture - I tried to program my standalone NRF52805 with my OLD PC. I started with programming the peripheral_uart sample which still kept hanging on bt_enable.
    (3) I then programmed the peripheral_lbs (led-button service). This worked. I was able to connect to the module via my phone and run the app.
    (4) Afterwards, I reprogrammed the NRF52805 module with the same peripheral_uart app. This time it was working fine!
    (5) Afterwards, all my previously failing apps started to work.
    (6) I hope this doesn't happen again. It was very time consuming, but I appreciate the assistance and advice.
    Cheers
