VS Code Suddenly will not build anything
I was working with VS code just fine and then upon booting it up today suddenly nothing will build anymore including sample projects. the only thing that i could tell that changed was VScode updated to 1.65, but I tried reverting the change back to 1.64 though that did not solve my issue
Here are support logs
IMPORTANT: The data below could contain sensitive or confidential information about your environment.
For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
  "platform": {
    "os": "win32",
    "osVersion": "Windows 10 Education",
    "osKernel": "10.0.19044",
    "vscode": "1.64.2",
    "electron": "13.5.2",
    "node": "v14.16.0"
  "system": {
    "date": "2022-03-17T04:31:04.487Z",
    "vscodeRoot": "c:\\Users\\jbclyde\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
    "vscodeUptime": "00:17:00",
    "osUptime": "01:13:33",
    "cpu": {
      "model": "AMD Ryzen 7 1700 Eight-Core Processor",
      "speed": "2994 MHz",
      "count": 8
    "memory": {
      "total": "15.93 GB",
      "free": "7.71 GB"
  "workspace": {
    "name": "peripheral_lbs_4",
    "workspaceFile": null,
    "folders": [
      "d:\\Work(skillz)\\peripheral_lbs_4"
  "extensions": {
    "internal": {
        "version": "2022.3.104",
        "path": "c:\\Users\\jbclyde\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2022.3.104",
        "isActive": true
        "version": "2022.3.16",
        "path": "c:\\Users\\jbclyde\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2022.3.16",
        "isActive": true
      "nordic-semiconductor.devicetree": null,
      "nordic-semiconductor.kconfig": null
    "external": {
      "marus25.cortex-debug": "1.2.2",
      "ms-vscode.cpptools": "1.8.4",
      "ms-vscode-remote.remote-wsl-recommender": "0.0.12",
      "ms-vscode.js-debug": "1.64.3",
      "ms-vscode.js-debug-companion": "1.0.15",
      "ms-vscode.references-view": "0.0.81",
      "ms-vscode.vscode-js-profile-table": "0.0.18",
      "austin.code-gnu-global": "0.2.2",
      "cschlosser.doxdocgen": "1.4.0",
      "eamodio.gitlens": "12.0.4",
      "jeff-hykin.better-cpp-syntax": "1.15.13",
      "ms-vscode-remote.remote-containers": "0.224.2",
      "ms-vscode-remote.remote-ssh": "0.76.1",
      "ms-vscode-remote.remote-ssh-edit": "0.76.1",
      "ms-vscode-remote.remote-wsl": "0.64.2",
      "ms-vscode.cmake-tools": "1.9.2",
      "ms-vscode.cpptools-extension-pack": "1.1.0",
      "ms-vscode.cpptools-themes": "1.0.0",
      "twxs.cmake": "0.0.17"
  "tools": {
    "C:\\Program Files (x86)\\SEGGER\\JLink\\JLink.exe": "7.60d",
    "C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.15.1",
    "nrfutil": "Not found",
    "c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain\\opt\\bin\\cmake.exe": "3.20.5",
    "c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain\\opt\\bin\\Scripts\\west.exe": "0.11.1",
    "c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain\\opt\\bin\\python.exe": "3.8.2",
    "c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain\\opt\\bin\\ninja.exe": "1.9.0",
    "c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain\\opt\\bin\\gperf.exe": "3.1",
    "c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain\\opt\\bin\\dtc.exe": "1.4.7",
    "c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain\\opt\\bin\\arm-none-eabi-gcc.exe": "9-2019-q4-major",
    "c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain\\opt\\bin\\gn.exe": "1940",
    "c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain\\mingw64\\bin\\git.exe": "2.26.2.windows.1"
  "sdks": [
      "version": "1.7.1",
      "path": "c:\\Users\\jbclyde\\ncs\\v1.7.1"
      "version": "1.7.0",
      "path": "c:\\Users\\jbclyde\\ncs\\v1.7.0"
      "version": "1.8.0",
      "path": "c:\\Users\\jbclyde\\ncs\\v1.8.0"
  "toolchains": [
      "version": "1.7.1",
      "path": "c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain"
      "version": "1.7.0",
      "path": "c:\\Users\\jbclyde\\ncs\\v1.7.0\\toolchain"
      "version": "1.8.0",
      "path": "c:\\Users\\jbclyde\\ncs\\v1.8.0\\toolchain"
  "connectedDevices": [
      "serialNumber": "51019558"
  "deviceProviders": [
    "nrfjprog"
  "config": {
      "topdir": "c:\\Users\\jbclyde\\ncs\\v1.7.1",
      "toolchain": {
      "ozonePath": "",
      "applications": [
      "kconfig": {
        "interface": "kconfig"
      "welcome": {
        "showOnStartup": false
      "west": {
        "env": {
          "$base": "terminal"
      "boardRoots": [],
      "enableTelemetry": false
      "terminalMode": "character"
    "nordic-semiconductor.devicetree": {
      "modules": [
        "${zephyrBase}",
        "${zephyrBase}/../nrf",
      "zephyr": "",
      "ctxFile": "",
      "defaultBoard": ""
    "nordic-semiconductor.kconfig": {
      "root": "",
      "env": {},
      "cfiles": true,
      "disable": false,
      "zephyr": {
        "base": ""
      "python": "",
      "liveValue": true
    "marus25.cortex-debug": {
      "armToolchainPath": null,
      "armToolchainPrefix": "arm-none-eabi",
      "gdbPath": null,
      "objdumpPath": null,
      "JLinkGDBServerPath": null,
      "openocdPath": null,
      "pyocdPath": null,
      "PEGDBServerPath": null,
      "stutilPath": null,
      "stlinkPath": null,
      "stm32cubeprogrammer": null,
      "enableTelemetry": true,
      "flattenAnonymous": false,
      "registerUseNaturalFormat": true,
      "variableUseNaturalFormat": true,
      "dbgServerLogfile": null,
      "showDevDebugOutput": "none"
  "environment": {
    "westExe": "c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain\\opt\\bin\\Scripts\\west.exe",
    "westEnv": {
      "ELECTRON_RUN_AS_NODE": "1",
      "HOME": "C:\\SPB_DATA",
      "HOMEDRIVE": "C:",
      "HOMEPATH": "\\Users\\jbclyde",
      "Path": "c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain\\mingw64\\bin;c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain\\mingw64\\libexec\\git-core;c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain\\opt\\bin;c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain\\opt\\bin\\Scripts;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\110\\Tools\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\120\\DTS\\Binn\\;C:\\Program Files (x86)\\Windows Kits\\8.1\\Windows Performance Toolkit\\;C:\\Program Files\\dotnet\\;C:\\Program Files\\Microsoft SQL Server\\130\\Tools\\Binn\\;C:\\Program Files (x86)\\mingw-w64\\i686-8.1.0-posix-dwarf-rt_v6-rev0\\mingw32\\bin;C:\\Program Files (x86)\\AOMEI\\AOMEI Backupper\\6.5.1;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\jbclyde\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\Users\\jbclyde\\AppData\\Local\\Programs\\Python\\Python37\\;C:\\Users\\jbclyde\\AppData\\Local\\Microsoft\\WindowsApps;C:\\ADB\\platform-tools;C:\\Program Files\\JetBrains\\PyCharm Community Edition 2020.3.2\\bin;;C:\\Users\\jbclyde\\ncs\\v1.7.1;C:\\ProgramData\\Microsoft\\Windows\\Start Menu\\Programs\\Git;C:\\Users\\jbclyde\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
      "ZEPHYR_BASE": "c:\\Users\\jbclyde\\ncs\\v1.7.1\\zephyr",
      "GNUARMEMB_TOOLCHAIN_PATH": "c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain\\opt",
      "ZEPHYR_TOOLCHAIN_VARIANT": "gnuarmemb",
      "PYTHONPATH": "c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain\\opt\\bin;c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain\\opt\\bin\\Lib;c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain\\opt\\bin\\Lib\\site-packages",
      "Python3_ROOT": "c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain\\opt\\bin"
    "toolchainPath": "c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain",
    "toolchainBinPath": "c:\\Users\\jbclyde\\ncs\\v1.7.1\\toolchain\\opt\\bin",
    "toolchainVersion": "1.7.1"
  "terminal": {
    "shell": null,
    "defaultProfile": null
When I try to build something it returns that I have +200 errors that are all in the NCS library
1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:51:16: error: expected expression before '_basic_sf_t'
   51 | GEN_OFFSET_SYM(_basic_sf_t, a3);
C:\Users\jbclyde\ncs\v1.7.1\zephyr\include\toolchain\gcc.h:439:46: note: in definition of macro 'GEN_ABSOLUTE_SYM'
  439 |   "\n\t.type\t" #name ",%%object" :  : "n"(~(value)))
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:51:1: note: in expansion of macro 'GEN_OFFSET_SYM'
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:52:16: error: expected expression before '_basic_sf_t'
   52 | GEN_OFFSET_SYM(_basic_sf_t, a4);
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:52:1: note: in expansion of macro 'GEN_OFFSET_SYM'
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:53:16: error: expected expression before '_basic_sf_t'
   53 | GEN_OFFSET_SYM(_basic_sf_t, ip);
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:53:1: note: in expansion of macro 'GEN_OFFSET_SYM'
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:54:16: error: expected expression before '_basic_sf_t'
   54 | GEN_OFFSET_SYM(_basic_sf_t, lr);
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:54:1: note: in expansion of macro 'GEN_OFFSET_SYM'
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:55:16: error: expected expression before '_basic_sf_t'
   55 | GEN_OFFSET_SYM(_basic_sf_t, pc);
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:55:1: note: in expansion of macro 'GEN_OFFSET_SYM'
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:56:16: error: expected expression before '_basic_sf_t'
   56 | GEN_OFFSET_SYM(_basic_sf_t, xpsr);
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:56:1: note: in expansion of macro 'GEN_OFFSET_SYM'
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:66:16: error: expected expression before '_callee_saved_t'
   66 | GEN_OFFSET_SYM(_callee_saved_t, v1);
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:66:1: note: in expansion of macro 'GEN_OFFSET_SYM'
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:67:16: error: expected expression before '_callee_saved_t'
   67 | GEN_OFFSET_SYM(_callee_saved_t, v2);
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:67:1: note: in expansion of macro 'GEN_OFFSET_SYM'
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:68:16: error: expected expression before '_callee_saved_t'
   68 | GEN_OFFSET_SYM(_callee_saved_t, v3);
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:68:1: note: in expansion of macro 'GEN_OFFSET_SYM'
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:69:16: error: expected expression before '_callee_saved_t'
   69 | GEN_OFFSET_SYM(_callee_saved_t, v4);
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:69:1: note: in expansion of macro 'GEN_OFFSET_SYM'
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:70:16: error: expected expression before '_callee_saved_t'
   70 | GEN_OFFSET_SYM(_callee_saved_t, v5);
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:70:1: note: in expansion of macro 'GEN_OFFSET_SYM'
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:71:16: error: expected expression before '_callee_saved_t'
   71 | GEN_OFFSET_SYM(_callee_saved_t, v6);
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:71:1: note: in expansion of macro 'GEN_OFFSET_SYM'
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:72:16: error: expected expression before '_callee_saved_t'
   72 | GEN_OFFSET_SYM(_callee_saved_t, v7);
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:72:1: note: in expansion of macro 'GEN_OFFSET_SYM'
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:73:16: error: expected expression before '_callee_saved_t'
   73 | GEN_OFFSET_SYM(_callee_saved_t, v8);
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:73:1: note: in expansion of macro 'GEN_OFFSET_SYM'
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:74:16: error: expected expression before '_callee_saved_t'
   74 | GEN_OFFSET_SYM(_callee_saved_t, psp);
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:74:1: note: in expansion of macro 'GEN_OFFSET_SYM'
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:85:16: error: expected expression before '_thread_stack_info_t'
   85 | GEN_OFFSET_SYM(_thread_stack_info_t, start);
C:\Users\jbclyde\ncs\v1.7.1\zephyr\arch\arm\core\offsets\offsets_aarch32.c:85:1: note: in expansion of macro 'GEN_OFFSET_SYM'
FATAL ERROR: command exited with status 1: 'c:\Users\jbclyde\ncs\v1.7.1\toolchain\opt\bin\cmake.EXE' --build 'd:\Work(skillz)\peripheral_lbs_4\build'
The terminal process terminated with exit code: 1.
