Two questions about the smart beacon PCB that is not in the design file.
1.) What PCB material did you use exactly?
2.) What type of solder mask did you use
Thank you.
Thank you.
We use FR4 1,6mm PCBs.
Øyvind
What is the IPC spec for the PCB?
The material is FR4 -- IPC-4101C/21. The boards are in compliance with IPC 6012A and IPC-A-600 Class 2 specifications.
Rune
