For a while I have been trying to alter the HTTPS client example to access another example.
No matter what I do, when I try to connect to any other host like google.com or my own website, I always get a connection refused error (111).
I have tried to provide the proper certificates using SSLabs as specified in your documentation, but with no luck.
* Copyright (c) 2020 Nordic Semiconductor ASA
#include <string.h>
#include <zephyr.h>
#include <stdlib.h>
#include <net/socket.h>
#include <modem/nrf_modem_lib.h>
#include <net/tls_credentials.h>
#include <modem/lte_lc.h>
#include <modem/modem_key_mgmt.h>
#define HTTPS_PORT 443
#define HTTPS_HOSTNAME "elsys2.tangane.no"
//#define HTTPS_HOSTNAME "example.com"
//#define HTTPS_HOSTNAME "google.no"
#define HTTP_HEAD \
"GET / HTTP/1.1\r\n" \
"Host: " HTTPS_HOSTNAME ":443\r\n" \
"Connection: close\r\n\r\n"
#define HTTP_HEAD_LEN (sizeof(HTTP_HEAD) - 1)
#define HTTP_HDR_END "\r\n\r\n"
#define RECV_BUF_SIZE 2048
#define TLS_SEC_TAG 42
static const char send_buf[] = HTTP_HEAD;
static char recv_buf[RECV_BUF_SIZE];
/* Certificate for `example.com` */
static const char cert[] = {
//#include "../cert/DigiCertGlobalRootCA.pem"
//#include "../cert/gsr4.pem"
#include "../cert/elsys.pem"
//#include "../cert/google.pem"
BUILD_ASSERT(sizeof(cert) < KB(4), "Certificate too large");
/* Provision certificate to modem */
int cert_provision(void)
int err;
bool exists;
int mismatch;
/* It may be sufficient for you application to check whether the correct
* certificate is provisioned with a given tag directly using modem_key_mgmt_cmp().
* Here, for the sake of the completeness, we check that a certificate exists
* before comparing it with what we expect it to be.
err = modem_key_mgmt_exists(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN, &exists);
if (err) {
printk("Failed to check for certificates err %d\n", err);
return err;
if (exists) {
mismatch = modem_key_mgmt_cmp(TLS_SEC_TAG,
cert, strlen(cert));
if (!mismatch) {
printk("Certificate match\n");
return 0;
printk("Certificate mismatch\n");
err = modem_key_mgmt_delete(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN);
if (err) {
printk("Failed to delete existing certificate, err %d\n", err);
printk("Provisioning certificate\n");
/* Provision certificate to the modem */
err = modem_key_mgmt_write(TLS_SEC_TAG,
cert, sizeof(cert) - 1);
if (err) {
printk("Failed to provision certificate, err %d\n", err);
return err;
return 0;
/* Setup TLS options on a given socket */
int tls_setup(int fd)
int err;
int verify;
/* Security tag that we have provisioned the certificate with */
const sec_tag_t tls_sec_tag[] = {
TLS_SEC_TAG,
#if defined(CONFIG_SAMPLE_TFM_MBEDTLS)
err = tls_credential_add(tls_sec_tag[0], TLS_CREDENTIAL_CA_CERTIFICATE, cert, sizeof(cert));
if (err) {
return err;
/* Set up TLS peer verification */
enum {
NONE = 0,
OPTIONAL = 1,
REQUIRED = 2,
verify = REQUIRED;
err = setsockopt(fd, SOL_TLS, TLS_PEER_VERIFY, &verify, sizeof(verify));
if (err) {
printk("Failed to setup peer verification, err %d\n", errno);
return err;
/* Associate the socket with the security tag
* we have provisioned the certificate with.
err = setsockopt(fd, SOL_TLS, TLS_SEC_TAG_LIST, tls_sec_tag,
sizeof(tls_sec_tag));
if (err) {
printk("Failed to setup TLS sec tag, err %d\n", errno);
return err;
err = setsockopt(fd, SOL_TLS, TLS_HOSTNAME, HTTPS_HOSTNAME, sizeof(HTTPS_HOSTNAME) - 1);
if (err) {
printk("Failed to setup TLS hostname, err %d\n", errno);
return err;
return 0;
void main(void)
int err;
int fd;
char *p;
int bytes;
size_t off;
struct addrinfo *res;
struct addrinfo hints = {
.ai_family = AF_INET,
.ai_socktype = SOCK_STREAM,
printk("HTTPS client sample started\n\r");
#if !defined(CONFIG_SAMPLE_TFM_MBEDTLS)
/* Provision certificates before connecting to the LTE network */
err = cert_provision();
if (err) {
return;
printk("Waiting for network.. ");
err = lte_lc_init_and_connect();
if (err) {
printk("Failed to connect to the LTE network, err %d\n", err);
return;
printk("OK\n");
err = getaddrinfo(HTTPS_HOSTNAME, NULL, &hints, &res);
if (err) {
printk("getaddrinfo() failed, err %d\n", errno);
return;
((struct sockaddr_in *)res->ai_addr)->sin_port = htons(HTTPS_PORT);
if (IS_ENABLED(CONFIG_SAMPLE_TFM_MBEDTLS)) {
fd = socket(AF_INET, SOCK_STREAM | SOCK_NATIVE_TLS, IPPROTO_TLS_1_2);
} else {
fd = socket(AF_INET, SOCK_STREAM, IPPROTO_TLS_1_2);
if (fd == -1) {
printk("Failed to open socket!\n");
goto clean_up;
/* Setup TLS socket options */
err = tls_setup(fd);
if (err) {
printk("We have tls errors... \n");
goto clean_up;
printk("Error in tls setup: %d\n", err);
printk("Connecting to %s\n", HTTPS_HOSTNAME);
err = connect(fd, res->ai_addr, sizeof(struct sockaddr_in));
if (err) {
printk("Error in connect setup: %d\n", err);
printk("connect() failed, err: %d\n", errno);
goto clean_up;
off = 0;
do {
bytes = send(fd, &send_buf[off], HTTP_HEAD_LEN - off, 0);
if (bytes < 0) {
printk("send() failed, err %d\n", errno);
goto clean_up;
off += bytes;
} while (off < HTTP_HEAD_LEN);
printk("Sent %d bytes\n", off);
off = 0;
do {
bytes = recv(fd, &recv_buf[off], RECV_BUF_SIZE - off, 0);
if (bytes < 0) {
printk("recv() failed, err %d\n", errno);
goto clean_up;
off += bytes;
} while (bytes != 0 /* peer closed connection */);
printk("Received %d bytes\n", off);
/* Print HTTP response */
p = strstr(recv_buf, "\r\n");
if (p) {
off = p - recv_buf;
recv_buf[off + 1] = '\0';
printk("\n>\t %s\n\n", recv_buf);
printk("Finished, closing socket.\n");
clean_up:
freeaddrinfo(res);
(void)close(fd);
lte_lc_power_off();
The error I'm getting: connect() failed, err: 111
Could someone please give me some direction in how to debug this? I've tried to replicate others who have posted that they have gotten further than this, but I find it hard to track down where my fault lies.
Thanks in advance.
