Can not restart UART RX after one error
When I get the first error in UART, the receiving of new characters stops (the transmittion continue working)
and I didn't find any solution to make RX (receiving characters) works again without CPU reset.
I create the error by disconnecting the UART cable and reconnecting it again.
the ERROR register is set to 1. thr ERRORSRC show framing and/or break error.
I tried to call:
nrfx_uart_uninit(&m_uart0);
and the init the UART
void hal_init_uart(void)
   ret_code_t err_code;
   nrfx_uart_config_t uart_config = NRFX_UART_DEFAULT_CONFIG;
   uart_config.pseltxd = HAL_USART0_TX;
   uart_config.pselrxd = HAL_USART0_RX;
   err_code = nrfx_uart_init(&m_uart0, &uart_config, uart0_event_handler);
   if (NRFX_SUCCESS != err_code)
      NRFX_LOG_ERROR("%s nrfx_uart_init failed: %s", __func__, NRFX_LOG_ERROR_STRING_GET(err_code));
I tried also to delete the error using
nrfx_uart_errorsrc_get(&m_uart0);
the error was cleared from ERROR and ERROORSRC registers, but stil after uart reinit , the charaters are not received.
the RX interrupt didn't occur. only transmit works,
Only cpu reset fix it, but I want to avoid unnecessary reset.
currently I fixed the problem by canceling the error interrupt by fixing the nrf_sdk function:  nrfx_uart_rx
nrf_uart_int_enable(p_instance->p_reg, NRF_UART_INT_MASK_RXDRDY /* |
NRF_UART_INT_MASK_ERROR */);
I realy want to find a way to reset the UART with no global CPU reset
