Error when running the Python CHIP controller
I'm actually trying to run the Python CHIP controller in my PC but I got some errors.
I've successfully set up the Open Thread Border Router in a Raspberry PI and I'm using the Light Bulb Matter example flashed in a nRF5340 DK which is my Matter accessory.
I followed the tutorial https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.9.1/matter/python_chip_controller_building.html#using-python-chip-controller-for-matter-accessory-testing to create my Matter controller using the tool Python CHIP controller.
I used all the required commands here below for installation and building the Python CHIP controller.
Then I tried to run the tool as shown here below :
I successfully activated the Python virtual environment. Then I tried to run the Python CHIP controller using "sudo out/python_env/bin/chip-device-ctrl " but I got the following output :
:~/connectedhomeip$ sudo out/python_env/bin/chip-device-ctrl
[1647525260.928139][48172:48172] CHIP:CTL: Setting attestation nonce to random value
[1647525260.928241][48172:48172] CHIP:CTL: Setting CSR nonce to random value
[1647525260.930233][48172:48172] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-hoBbXJ)
[1647525260.930450][48172:48172] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1647525260.930478][48172:48172] CHIP:DL: NVS set: chip-counters/reboot-count = 6 (0x6)
[1647525260.930711][48172:48172] CHIP:DL: Got Ethernet interface: enp0s31f6
[1647525260.930868][48172:48172] CHIP:DL: Found the primary Ethernet interface:enp0s31f6
[1647525260.931027][48172:48172] CHIP:DL: Got WiFi interface: wlp1s0
[1647525260.931673][48172:48172] CHIP:DL: Found the primary WiFi interface:wlp1s0
[1647525260.931786][48172:48186] CHIP:DL: Platform main loop started.
2022-03-17 14:54:20 IMP-IT0087lx root[48172] CRITICAL Loading configuration from /tmp/chip-device-ctrl-storage.json...
2022-03-17 14:54:20 IMP-IT0087lx chip.IN[48172] INFO Loading from storage for fabric index 1
2022-03-17 14:54:20 IMP-IT0087lx chip.IN[48172] INFO Loading from storage for fabric index 2
2022-03-17 14:54:20 IMP-IT0087lx chip.IN[48172] INFO Loading from storage for fabric index 3
2022-03-17 14:54:20 IMP-IT0087lx chip.IN[48172] INFO Loading from storage for fabric index 4
2022-03-17 14:54:20 IMP-IT0087lx chip.IN[48172] INFO Loading from storage for fabric index 5
2022-03-17 14:54:20 IMP-IT0087lx chip.IN[48172] INFO Loading from storage for fabric index 6
2022-03-17 14:54:20 IMP-IT0087lx chip.IN[48172] INFO Loading from storage for fabric index 7
2022-03-17 14:54:20 IMP-IT0087lx chip.IN[48172] INFO Loading from storage for fabric index 8
2022-03-17 14:54:20 IMP-IT0087lx chip.IN[48172] INFO Loading from storage for fabric index 9
2022-03-17 14:54:20 IMP-IT0087lx chip.IN[48172] INFO Loading from storage for fabric index 10
2022-03-17 14:54:20 IMP-IT0087lx chip.IN[48172] INFO Loading from storage for fabric index 11
2022-03-17 14:54:20 IMP-IT0087lx chip.IN[48172] INFO Loading from storage for fabric index 12
2022-03-17 14:54:20 IMP-IT0087lx chip.IN[48172] INFO Loading from storage for fabric index 13
2022-03-17 14:54:20 IMP-IT0087lx chip.IN[48172] INFO Loading from storage for fabric index 14
2022-03-17 14:54:20 IMP-IT0087lx chip.IN[48172] INFO Loading from storage for fabric index 15
2022-03-17 14:54:20 IMP-IT0087lx chip.IN[48172] INFO Loading from storage for fabric index 16
2022-03-17 14:54:20 IMP-IT0087lx chip.DL[48172] INFO writing settings to file (/tmp/chip_counters.ini-23Pp4J)
2022-03-17 14:54:20 IMP-IT0087lx chip.DL[48172] ERROR renamed tmp file to file (/tmp/chip_counters.ini)
2022-03-17 14:54:20 IMP-IT0087lx chip.DL[48172] INFO NVS set: chip-counters/GlobalMCTR = 6000 (0x1770)
2022-03-17 14:54:20 IMP-IT0087lx root[48172] INFO SetSdkKey: gcc = b'\xd0\x07\x00\x00'
2022-03-17 14:54:20 IMP-IT0087lx root[48172] INFO SetSdkKey: gdc = b'\xd0\x07\x00\x00'
2022-03-17 14:54:20 IMP-IT0087lx chip.ZCL[48172] INFO Using ZAP configuration...
2022-03-17 14:54:20 IMP-IT0087lx chip.DL[48172] INFO Avahi connecting
2022-03-17 14:54:20 IMP-IT0087lx chip.IN[48172] INFO CASE Server enabling CASE session setups
2022-03-17 14:54:20 IMP-IT0087lx chip.DIS[48172] ERROR Failed to initialize advertiser: ../../src/platform/Linux/DnssdImpl.cpp:333: CHIP Error 0x00000003: Incorrect state
2022-03-17 14:54:20 IMP-IT0087lx chip.DIS[48172] INFO Failed to find a valid admin pairing. Node ID unknown
2022-03-17 14:54:20 IMP-IT0087lx chip.DIS[48172] INFO Start dns-sd server - no current nodeId
2022-03-17 14:54:20 IMP-IT0087lx chip.DIS[48172] INFO Advertise commission parameter vendorID=65521 productID=32769 discriminator=3840/15
2022-03-17 14:54:20 IMP-IT0087lx chip.DIS[48172] ERROR Failed to advertise unprovisioned commissionable node: ../../src/lib/dnssd/Discovery_ImplPlatform.cpp:473: CHIP Error 0x00000003: Incorrect state
2022-03-17 14:54:20 IMP-IT0087lx chip.DIS[48172] ERROR Failed to advertise commissioner: ../../src/lib/dnssd/Discovery_ImplPlatform.cpp:473: CHIP Error 0x00000003: Incorrect state
2022-03-17 14:54:21 IMP-IT0087lx chip.DL[48172] ERROR Avahi client failure
2022-03-17 14:54:21 IMP-IT0087lx chip.DIS[48172] ERROR DNS-SD error: ../../src/platform/Linux/DnssdImpl.cpp:405: CHIP Error 0x000000AC: Internal error
New FabricAdmin: FabricId: 1(1)
2022-03-17 14:54:21 IMP-IT0087lx root[48172] INFO SetReplKey: fabricAdmins = {'1': {'fabricId': 1}}
Allocating new controller with FabricId: 1(1), NodeId: 1
2022-03-17 14:54:21 IMP-IT0087lx chip.CTL[48172] INFO Setting attestation nonce to random value
2022-03-17 14:54:21 IMP-IT0087lx chip.CTL[48172] INFO Setting CSR nonce to random value
2022-03-17 14:54:21 IMP-IT0087lx chip.CTL[48172] INFO Generating NOC
Failed to bringup CHIPDeviceController CLI
Exception ignored in: <function ChipDeviceController.__del__ at 0x7f75f07d4040>
  File "/home/czena/connectedhomeip/out/python_env/lib/python3.8/site-packages/chip/ChipDeviceCtrl.py", line 186, in __del__
    self.Shutdown()
  File "/home/czena/connectedhomeip/out/python_env/lib/python3.8/site-packages/chip/ChipDeviceCtrl.py", line 150, in Shutdown
    if (self.isActive):
AttributeError: 'ChipDeviceController' object has no attribute 'isActive'
Segmentation fault
I would like to know why I got a segmentation fault. Could you help me please ?
I'm using OS Ubuntu 20.04.4 LTS and nRF Connect SDK v1.9.1
  • Have you made any progress here?  I am trying the same thing and hit that seg fault.  If I try again right away it works.... kind of.
    But then I get a repeating error saying that it "Failed to advertise commissioner" every minute or so.
    edit - oh, I am on raspian so that might be different but I'd be curious how you are working out.
    Thank you for your patience with this.
    I have not been able to reproduce this on windows, so I have submitted it to our Matter team which mostly work in Linux.
    I will update you as soon as I hear back from them.
    Karl
  • Hello again,
    I hope you have had a great weekend!
    Could you confirm that you have the Avahi-daemon up and running?
    Could you also tell me what
    systemctl status avahi-daemon
    and
    ps aux | grep avahi-daemon
    returns for you?
    Karl
  • For the first command I get :
    connectedhomeip$ systemctl status avahi-daemon
    ● avahi-daemon.service - Avahi mDNS/DNS-SD Stack
         Loaded: loaded (/lib/systemd/system/avahi-daemon.service; enabled; vendo>
         Active: failed (Result: exit-code) since Tue 2022-04-05 14:46:54 CEST; 1>
    TriggeredBy: ● avahi-daemon.socket
        Process: 79823 ExecStart=/usr/sbin/avahi-daemon -s (code=exited, status=2>
       Main PID: 79823 (code=exited, status=255/EXCEPTION)
         Status: "avahi-daemon 0.7 starting up."
    For the second command I get :
    connectedhomeip$ ps aux | grep avahi-daemon
    czena 81257 0.0 0.0 9052 656 pts/4 S+ 14:50 0:00 grep --color=auto avahi-daemon
    I tried to reinstall the Python CHIP controller. I followed steps from the Matter website : https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.9.1/matter/python_chip_controller_building.html#using-python-chip-controller-for-matter-accessory-testing
    I made all the 5 steps from the "Building and installing" section.
    When building and installing the Python CHIP controller using :
    scripts/build_python.sh -m platform
    I got the following messages :
    ACTIVATOR! This sets your shell environment variables.
    Activating environment (setting environment variables):
      Setting environment variables for CIPD package manager...done
      Setting environment variables for Python environment.....done
      Setting environment variables for pw packages............skipped
      Setting environment variables for Host tools.............done
    Checking the environment:
    20220405 14:58:42 INF Environment passes all checks!
    Environment looks good, you are ready to go!
    Done. Made 2965 targets from 243 files in 252ms
    ninja: Entering directory `./out/python_lib'
    [179/179] stamp obj/src/controller/python/python.stamp
    Then I tried to use the first command from the "Running the tool" section:
    source out/python_env/bin/activate
    but I realized that folder "python_env" does not exist as shown here bellow.
    Why folder "python_env" is not created ? How can I run Python CHIP controller without errors?
    Thanks!
  •  I am still having troubles with this but I can address one topic for you.  The lack of the env directory.   I put a documentation ticket in based on a change to the default options on one of the commands.
    devzone.nordicsemi.com/.../documentation-update-needed---matter-instructions
    scripts/build_python.sh -m platform        <------------  This command now requires the "  -i separate    " option to generate the env. See --help
