DFU-OTA project main file to assembly language file transition.
    I am working on the sample DFU OTA project as recommended below,
https://devzone.nordicsemi.com/guides/nrf-connect-sdk-guides/b/software/posts/ncs-dfu?CommentId=3cb5df69-fd8f-4160-9171-74b6e8246c1a
I am getting the prints as below upon dfu on my nrf52833dk board.
Upon reboot i can see the logs , "starting bootloader" which are being generated from mcuboot source file main.c (v1.8.0\bootloader\mcuboot\boot\zephyr).
after this the logs furthur like "Primary image", are being generated from the file 4452.zephyr.lst
Kindly help me in understanding how the execution is entering zephyr.lst from main.c . after printing "starting bootloader". Attached below is the main() code.
void main(void)
    struct boot_rsp rsp;
    int rc;
    fih_int fih_rc = FIH_FAILURE;
    MCUBOOT_WATCHDOG_FEED();
#if !defined(MCUBOOT_DIRECT_XIP)
    BOOT_LOG_INF("Starting bootloader");
#else
    BOOT_LOG_INF("Starting Direct-XIP bootloader");
#ifdef CONFIG_MCUBOOT_INDICATION_LED
    /* LED init */
    led_init();
    os_heap_init();
    ZEPHYR_BOOT_LOG_START();
    (void)rc;
#if (!defined(CONFIG_XTENSA) && defined(DT_CHOSEN_ZEPHYR_FLASH_CONTROLLER_LABEL))
    if (!flash_device_get_binding(DT_CHOSEN_ZEPHYR_FLASH_CONTROLLER_LABEL)) {
        BOOT_LOG_ERR("Flash device %s not found",
		     DT_CHOSEN_ZEPHYR_FLASH_CONTROLLER_LABEL);
        while (1)
#elif (defined(CONFIG_XTENSA) && defined(JEDEC_SPI_NOR_0_LABEL))
    if (!flash_device_get_binding(JEDEC_SPI_NOR_0_LABEL)) {
        BOOT_LOG_ERR("Flash device %s not found", JEDEC_SPI_NOR_0_LABEL);
        while (1)
#ifdef CONFIG_MCUBOOT_SERIAL
    if (detect_pin(CONFIG_BOOT_SERIAL_DETECT_PORT,
                   CONFIG_BOOT_SERIAL_DETECT_PIN,
                   CONFIG_BOOT_SERIAL_DETECT_PIN_VAL,
                   CONFIG_BOOT_SERIAL_DETECT_DELAY) &&
            !boot_skip_serial_recovery()) {
        gpio_pin_set(led, LED0_GPIO_PIN, 1);
        BOOT_LOG_INF("Enter the serial recovery mode");
        rc = boot_console_init();
        __ASSERT(rc == 0, "Error initializing boot console.\n");
        boot_serial_start(&boot_funcs);
        __ASSERT(0, "Bootloader serial process was terminated unexpectedly.\n");
#if defined(CONFIG_BOOT_USB_DFU_GPIO)
    if (detect_pin(CONFIG_BOOT_USB_DFU_DETECT_PORT,
                   CONFIG_BOOT_USB_DFU_DETECT_PIN,
                   CONFIG_BOOT_USB_DFU_DETECT_PIN_VAL,
                   CONFIG_BOOT_USB_DFU_DETECT_DELAY)) {
        rc = usb_enable(NULL);
        if (rc) {
            BOOT_LOG_ERR("Cannot enable USB");
        } else {
            BOOT_LOG_INF("Waiting for USB DFU");
            wait_for_usb_dfu(K_FOREVER);
            BOOT_LOG_INF("USB DFU wait time elapsed");
#elif defined(CONFIG_BOOT_USB_DFU_WAIT)
    if (rc) {
    } else {
        wait_for_usb_dfu(K_MSEC(CONFIG_BOOT_USB_DFU_WAIT_DELAY_MS));
    FIH_CALL(boot_go, fih_rc, &rsp);
    if (fih_not_eq(fih_rc, FIH_SUCCESS)) {
        BOOT_LOG_ERR("Unable to find bootable image");
        FIH_PANIC;
    BOOT_LOG_INF("Bootloader chainload address offset: 0x%x",
                 rsp.br_image_off);
#if defined(MCUBOOT_DIRECT_XIP)
    BOOT_LOG_INF("Jumping to the image slot");
#else
    BOOT_LOG_INF("Jumping to the first image slot");
#if USE_PARTITION_MANAGER && CONFIG_FPROTECT
#ifdef PM_S1_ADDRESS
/* MCUBoot is stored in either S0 or S1, protect both */
#define PROTECT_SIZE (PM_MCUBOOT_PRIMARY_ADDRESS - PM_S0_ADDRESS)
#define PROTECT_ADDR PM_S0_ADDRESS
#else
/* There is only one instance of MCUBoot */
#define PROTECT_SIZE (PM_MCUBOOT_PRIMARY_ADDRESS - PM_MCUBOOT_ADDRESS)
#define PROTECT_ADDR PM_MCUBOOT_ADDRESS
    rc = fprotect_area(PROTECT_ADDR, PROTECT_SIZE);
    if (rc != 0) {
        BOOT_LOG_ERR("Protect mcuboot flash failed, cancel startup.");
        while (1)
#endif /* USE_PARTITION_MANAGER && CONFIG_FPROTECT */
#if defined(CONFIG_SOC_NRF5340_CPUAPP) && defined(PM_CPUNET_B0N_ADDRESS)
    pcd_lock_ram();
    ZEPHYR_BOOT_LOG_STOP();
    do_boot(&rsp);
    BOOT_LOG_ERR("Never should get here");
    while (1)
