PCB Design with nRF52840 SoC
First of all thank you for your support and suggestions.
As I am planning to use nRF52840 SoC in my design, (Project: BLE based Environmental sensor). The circuit mainly consist of the sensor (uses SPI), Battery Circuit, Antenna (Mostly U.FL Connector), nRF52840 SoC. Is there any similar PCB design template projects available in order to refer?
Reference Circuit: Nordic Semiconductor Infocenter
Also I have found some points which are not familiar to me,
  • Power supply: It found from the datasheet that use of DC/DC Regulator has san advantage on Current consumption. (USB is not included in my design) can I go with Circuit configuration no 5 for QIAA aQFN73 (by connecting VBUS to GND) in order to get advantages of DC/DC Regulator?
  • If so, can I design the entire circuit with 3V Battery power supply?
  • Regarding antenna, I would like to do design with U.FL Connector (easy to go with external Antenna), Can I follow the same ANtenna circuit provided in the reference circuit provided in product specification? (or is there any special design required?
  • If I am using only some GPIO pins specially for SPI communication, is it fine to make all other unused pins to float or unconnected?
  • How External Crystal oscillator helps my design in terms of power consumption?( I found HFXO helps in reducing current consumption) Is it recommended to use external clocks?
  • There are some capacitors (C10, C13..) which are mentioned as Not Mounted (NC) on the Bill of Material of the reference circuit. What it indicates? Do I need to avoid these capacitors from my design?
I am really interested and looking forward for  valuable suggestions and resposnes. I really do appreciate your help, time and effort.
Thanks and Regards,
Sreejith
