how to send a char to bluetooth to mobile
Hi i am new to nrf52840 i want to send a char continuously through bluetooth to mobile, im using sdk 17.1.0 and i have tried ble_app_uart in the example but the blue tooth is not advertising where do i miss i donot know, can any body help me out by suggesting a good example for sending the character to mobile continuously.
  • From your logs it seems like your flash downloads are failing, are you certain that the programming succeeds as expected?
    The image i shared you is just to show you how do I erase and load a program in the nrf52840 dk board. The below is the log which i get for erasing and loading the program.
    Are you getting any logs at all, or is the device behaving anything like you would have expected?
    yes when i load a uart program it works fine but for ble app it is not advertising any bluetooth.
    I think you should try to run an unmodified example first, to make sure that your setup is correct, before you try to run your modified example.
    The example which i load is not modified it is exactly the same example in the sdk i just copied and pasted into my folder.
    Furthermore, it seems that your path to your project is very long. This could cause issues on a Windows based machine because windows has a path limit of 266 characters. I would recommend that you reduce your projects path length and also make sure not to use blank spaces in the path to your project.
    yes sure i will consider this point.
    Thank you for clarifying this.
    Then it is quite strange that you are not seeing it function as expected.
    Could you try to run this in a debug session to see if the program unexpectedly is getting stuck anywhere?
    Could you also open an RTT terminal, like the Segger RTT Viewer to see if there are any unexpected logs being written there?
    The 'UART example started' message should appear in a regular Serial terminal, but all error loggings etc. will require an RTT terminal to view.
    Great, I am happy to hear that!
    Karl
  • Hi i just now got the bluetooth advertising the issue is because of the softdevices i uploaded the latest version of the softdevices into the nrf52840 now it is advertising but the thing is it is not paring to my mobile and i want to know what is the exact functionality of the "ble_app_uart" example cany you please help me out in that
  • Oh, yes, in Keil you will need to flash the SoftDevice separatly, apologies for not being explicit about this earlier.
    You can read about how the example functions in the example documentation. The example does not utilize any security, so you only need to connect to it in order to access its services. The device will output anything it received in the NUS RX characteristic on it's UART - so if your device is connected to a PC with a serial monitor it will display the received message there.
    Karl
  • You can read about how the example functions in the example documentation. The example does not utilize any security, so you only need to connect to it in order to access its services. The device will output anything it received in the NUS RX characteristic on it's UART - so if your device is connected to a PC with a serial monitor it will display the received message there.
    Yes thankyou Karl i will go through the article, and now i got the message recieving in both serial monitor and in my mobile only thing is i need to find out which function is responsible for sending the message through bluetooth and i need to find where the handlers are available in the example code.
