KConfig File Default path in SES Project
What is the default path of Kconfig in SES Project ? I testing Azure-Iot_Hub sample project. I define the AZURE_IOT_HUB_DEVICE_ID and AZURE_IOT_HUB_NAME in prj.conf file. When build is run, the error appears that : the device ID should be defined in Kconfig ... BUILS_ASSERT fails ...
where is this file with following type of commands ?
config AZURE_IOT_HUB_DEVICE_ID
    string "Device ID"
    depends on AZURE_IOT_HUB
    help
      Device ID to be used when connecting to IoT hub and optionally DPS.
      Providing a device ID can also be done run-time if
      AZURE_IOT_HUB_DEVICE_ID_APP is selected.
