Hardware setup for nRF52811 on PTR9611 for arduino
I am a university student that is currently working on a project regarding an indoor RTLS proposed using BLE beacon system to track down an object.
After some research, i got my hands on the ptr9611 module with the NRF52811 Soc. Im thinking is it possible for me to interface with the module using the an arduino uno to extract RSSI value and AoD/AoA for distance and angle between devices as the PTR9611 actually includes an pcb antenna on board. Through triangulation method with location of multiple beacons known, eventually come out with a result for the location of the tracked device is applicable right? So how should i connect my arduino and the PTR9611 module so that i can make use of the SDK provided to configure it later?
  • Hello Henry, sorry about the delay.
    This does sound like a plan, though it would depend a bit on the ptr9611 module and what it includes. Does it come with the code for a complete AoA/AoD solution, and what your project focuses on is mainly combining it to do a triangulation? Or are you making your own AoA/AoD solution as well?
    Elfving
  • the ptr9611 datasheet provides the specification of the module only. Example code and connection are not found, I emailed the manufacturing company and they recommend me to find solutions from nordic. Below attached the datasheet of ptr9611. So now my priorities are to set up the module to make 3 of them to be beacon nodes and 1 that is on a moving object that will be receiving these signal from the nodes and analyze the location of itself. afterwards the signals from the 3 nodes must be identified correctly so once the 3 nodes are placed accordingly around the room with just the distance between each node and the tracked module known given the rssi value, simple triangulation method can be used to find its location. Until this part the AoA/AoD then steps in to further increase the accuracy of the result by the angle between the modules to be found out. So to start things off which pins of the module do I connect them to my arduino so that i can configure it to be the beacons and which for collecting the data of the signal connection once its made since theres 36pins on the module 32 of them are GPIO pins. Is it necessarily to have all of them connected to the arduino? if just few of them are needed then which few are recommend to allow the usage and control of the anthena array used in the Aoa/AoD method?
    UM-4803261.pdf
  • It is unfortunately not that easy.
    Are you planning on basing this one locator node on the same module? It seems to me that these ptr9611 modules are only Beacons (transmitters). You would need a locator as well, with which you would also need an antenna matrix/array (though you did get one of those?). The nRF52833 is what we would recommend to use as a Locator.
    And when it comes to our solutions for direction finding you can have a look at our beacon and locator samples available in the nRF Connect SDK. However, what we provide in these samples is a way of getting the I/Q data, not the algorithm for processing it. In order to get the angles themselves you need to work on the I/Q values using the information available in our whitepaper on DF.
    This is possible, but it seems to me that what you are looking for is a complete plug-and-play AoA solution, which is not what we are providing.
    Elfving
  • OK. As for the locator, is it posible for the same module to be used if an antenna matrix/array externally is provided? Other than that, is there a way to hook up the module straight to a pc to program/configure it?
    It would depend a bit on the module. I believe it would at least need more RAM to be used for it. I would recommend you to use an nRF52833DK instead.
    The datasheet from ABLUE Technology explains that you would have to use the SWD interface, though I think this is a question you could ask them. Did you get an external programmer along with it?
    Have you had a look at the UBLOX AoA solution btw? That might be a bit more ready-made and closer to what you are looking for.
    Elfving
