handling PM_CONN_SEC_ERROR_SMP_TIMEOUT
Hey.
In production we are logging PM error events to try to determine the root cause for some unstable connection that keep showing up.
We are seeing with high occurrence error code 4353 which is the SMP timeout.
This is often found when reported unstable connections or failure to start OTA DFU.
From the Bluetooth Core:
From Nordic Info Center:
#define 	PM_CONN_SEC_ERROR_SMP_TIMEOUT   (PM_CONN_SEC_ERROR_BASE + 0x101)
/* Pairing/bonding could not start because an SMP time-out has already happened on this link.
* This means that no more pairing or bonding can happen on this link.
* To be able to pair or bond, the link must be disconnected and then reconnected.
* See Bluetooth Core Specification 4.2 section 3.H.3.4 (Bluetooth Core Specification).
Can you provide the advised strategy to recover a stable BLE link whenever this occurs?
SDK: 17.0.2
SD: s140 - 7.2.0
bluetoothctl: 5.48
  • I understand your point and I am quite aligned with it. The BLE management when app is in background could be enough to explain the difference between iOS and Android
    However there's this specific case where our clients are asked to be close to the device and the app is on foreground to perform OTA DFU. It happens that sometime we get complaints that DFU is unstable or just hard to perform and this PM error can be seen in some of those reports.
    Can you think of any situation where this might happen?
  • Well, the nRF will reset during a DFU session (several times). This is expected, but if you have some custom app not expecting that, it may be "surprised". I don't know.
    Edvin said:
    Do you know exactly where in the application this error code shows up? Is it as a return value from a function call on the nRF? Or does it show up in your app?
    Do you know this?
    BR,
    Edvin
  • its a return value from a function call on nRF
  • So what call is it? Do you know, or doesn't it say in the report?
    I can't really say much more than what I already did. I guess it is calling some function that returns PM_CONN_SEC_ERROR_DISCONNECT. As the description of that value says:
    "Pairing or encryption did not finish before the link disconnected for an unrelated reason."
    So the devices are disconnected when this occurs, and it is not the reason for the disconnect (at least not from the nRF's side).
    BR,
    Edvin
