sd_flash_page_erase cause hardfault
hi,
    We are currently having some problems erasing flash,The problem recurrence rate was 1%,the recurrence rate of specify chip problems is 100%,Here are some scenarios as flow.Windows/KEIL/SDK17.0.2
---------scenarios 1--------------
sd_softdevice_enable()      return NRF_SUCCESS
sd_flash_page_erase()     return NRF_SUCCESS
wating sd_flash_page_erase()  event    --> cause hardfault
sd_ble_cfg_set()
sd_ble_enable()
advertising_init()
->Problems occur, specify chip  100% recurrence rate
-----------scenarios 2----------------------
nrf_delay_ms(100)
sd_ble_cfg_set()
sd_ble_enable()
advertising_init()
-> specify chip Problems disappear
-----------scenarios 3----------------------
sd_ble_cfg_set()
sd_ble_enable()
advertising_init()
  • hi,
        NRF_SDH_CLOCK_LF_RC_CTIV   is 32,The other configuration is the same
    This is above the recommended value, but I do not believe it is enough to explain the assertion, unfortunately.
    Here is from the Softdevice API documentation:
    For nRF52, the application must ensure calibration at least once every 8 seconds to ensure +/-500 ppm clock stability. The recommended configuration for NRF_CLOCK_LF_SRC_RC on nRF52 is rc_ctiv=16 and rc_temp_ctiv=2. This will ensure calibration at least once every 8 seconds and for temperature changes of 0.5 degrees Celsius every 4 seconds. See the Product Specification for the nRF52 device being used for more information.
    I'm currently working on a test application I was hoping you could run on your "bad" chip to time the flash erase. Now I'm wondering what would be the best way for you to measure this. Do you have an IO that could serve as a debug output pin and a logic analyzer to monitor its state, or would it better if I used a TIMER and printed the result out on RTT?
  • hi,
        Thanks for your help. We have a solution
