Battery Service reading adc value from other GPIO
Hi everyone,
I have connected a potentiometer to a GPIO pin (AIN2) and would like to show the varying values in the battery service.
I was wondering if there's any way for me to amend the battery service so that the service can read other ADC/voltage value from other GPIO pins.
Tools:
  • nRF52832
  • nRF52DK
  • nRF5_SDK_17.1.0
  • 132 softdevice
Zachary
    A good start would be to merge the SAADC example into the battery service example. You should also take a look at our ble_app_uart__saadc_timer_driven__scan_mode example on GitHub which shows how you can use the SAADC with the Softdevice,
    regards
    Jared
  • Hi Jared,
    thanks for the reply. I have actually tried to merge the saadc and battery service together.
    What I’ve encountered during connection, was that the battery level from the battery service will always be 100%. I’ve also tried powering up the DK with the USB or external power supply (2.6V), but it also still 100%.
    I have also seen some old post regarding this however, the author did not further explain his solution.( https://devzone.nordicsemi.com/f/nordic-q-a/2377/battery-level-service-on-custom-profile)
    My concerns are:
    1. Why the battery level is always at 100%
    2. Is there a way for me to input the adc reading from a GPIO pins into the battery service.
    Zachary
  • Zachary16 said:
    I've realised that the problem in my code was that the SAMPLE_BUFFER_LENS was at 5 hence causing the battery level to display only 0%.
    Ok, so the problem is solved? What does the battery level show now?
    Zachary16 said:
    I have tried to do this however, it seems like the debugger did not stop at the breakpoint and the callback function is still running. I have attached a screenshot for reference.
    Could you kindly explain to me how debugging actually work? Does debugging only stops when there is an error in the code? and what information I can get from doing a debugging?
    Where is the breakpoint in the screenshot that you've shared? I was interested to see the value of p_event->data.done.p_buffer[i] when the callback handler is returned:
    Jared said:
    Could you set the breakpoint at line 120, and check the value of p_event->data.done.p_buffer[i]? You can check it by adding it to watch:
    See this for an explanation on debugging.
    regards
    Jared
  • Hi Jared,
    Yes, the problem have been partially solved. The problem i faced now is that every time I established a connection between the DK and nRF Connect App, the initial battery level (100%) will appear and only change the value after 20 secs (below 100% depending on the voltage input/adc reading). Is there a way that I can omit the 100% and allow the DK to show the accurate value immediately after connection.
    Apologies for uploading the wrong image. I have attached a photo with the proper breakpoint.
    Thank you for sharing this link. I've watched this video hence, I've assume that the debugger will only stops if there's an error in the code. Whereas, during my trial of debug of my own code, the callstack will keep running and do not stop at the breakpoint.
    Zachary
    The sampling in your application is started by the saadc timer, you can do a sample right after a connection by calling nrf_sample() in the BLE_GAP_EVT_CONNECTED event in the ble event handler.
    The debugger should stop at the breakpoint. Are you sure the program reach the breakpoint? Try to output a log in the handler and see if it's printed out in the terminal.
    regards
    Jared
  • Hi Jared,
    Thank you for this advice. I no longer see 100% in the nRF Connect App.
    Sorry if this may sound silly, but how do I tell if the program reach the breakpoint. In other program that I've run, the debugger will reach the breakpoint within seconds. Was I supposed to let it run for a couple of mins or hours?
    Zachary
    If the program never stops at the set breakpoint within reasonable time, you can assume that the program never reaches that breakpoint. How long depends on your application, and when you start sampling. You can try to pause the program and see where it's currently at. In the code that you shared I see that you have commented out the line which starts the SAADC timer, have you remembered to include this line when you test?
    regards
    Jared
    regards
    Jared
